Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 01-14-2021, 03:48 AM   #1289
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
YES, ALREADY POSTED, YET ELSEWHERE:
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
StE92ve (01-14-2021)
Old 01-14-2021, 08:23 AM   #1290
Lantanafrs2
Drives: 2013 frs red
Originally Posted by beltax90 View Post
will wait until they find 5 extra hp with the red manifold for the 2027 refreshed model thank you very much!
If this car is still around in 2027 it will probably have batteries and 500hp.
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
Dadhawk (01-14-2021), Vides990 (01-14-2021)
Old 01-14-2021, 09:44 AM   #1291
Sasquachulator
Pavement Grey
I think in 2027 the normal cars of the world has to do 0-60 in less than 4 seconds to be considered "competitive".....
The Following 2 Users Say Thank You to Sasquachulator For This Useful Post:
Lantanafrs2 (01-14-2021), Vides990 (01-14-2021)
Old 01-14-2021, 11:47 AM   #1292
joro2
joro2's Avatar
Drives: 2017 BRZ Premium MT (DGM)
Heh.
The red crinkle aluminum intake on the >= ‘17 refresh makes for one of the best looking stock engine bays available at any price.
Modern e.g. Porsches, can’t even take a peek under the hood anymore, same for electric vehicles - no box of bolts to marvel at. And hence no mechanical geek fun.
joro2 is offline   Reply With Quote
The Following 5 Users Say Thank You to joro2 For This Useful Post:
Bristecom (01-14-2021), Dake (01-14-2021), ng-86 (01-14-2021), solidONE (01-14-2021), Vides990 (01-14-2021)
Old 01-14-2021, 05:00 PM   #1293
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yeah definitely something about red plenum and valve covers highlighting the engine. It just looks nice.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
joro2 (01-15-2021)
Old 01-14-2021, 05:56 PM   #1294
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by StE92ve View Post
What is the purpose of fender vents?
The main purpose of fender vents is to relieve built-up air pressure from inside the wheel arches which causes aerodynamic lift. Typically, there are air intakes in the front of the bumper directing air over the brakes to cool them. This air gets trapped in the wheel arches and creates high pressure. High pressure results in lift over the front wheels reducing traction. Relieving this built up high-pressure system in the wheel arches reduces front axle lift thus increasing safety and grip.
In addition to high pressure, trapped air in the wheel arches also creates aerodynamic drag. Drag is the force of air pushing in the opposite direction of the vehicle, reducing efficiency. Some research suggests wheel arches account for up to 30% of aerodynamic drag of a vehicle. With fuel efficiency ratings becoming increasingly more strict on modern vehicles, you can understand why so much attention is being directed towards the reduction of this inefficiency. Efficiently routing air into and out of the wheel arches increases fuel economy through the reduction of drag.
Another benefit of fender vents is to efficiently vent hot air generated by heavy breaking out in the air stream. Quickly relieving hot air generated from the brakes makes room for more cool air to pass over the brakes, thus increasing efficiency. Finally, it is worth mentioning that trapped air in the wheel arches also contributes to cabin noise. Reduction of cabin noise is more pleasant to drivers on long trips reduces driver fatigue.
Yes, all good points. However, the downside of such vents is they are typically more likely to break and are harder to clean, and being plastic also usually means they're more likely to corrode down the line. Probably not a big deal for people planning to own the car for around 100k miles but could be a problem for those keeping it or getting it after 5 years or 100k or so. So personally I'm mixed about it. I like clean simple designs but I also like aerodynamic advancements.
For me, the biggest disappointment of this new design as I mentioned before is the tire diameter. On rough American roads, we need a bigger diameter to keep the car more stable and comfortable. 215/45/18 (at 650mm diameter) would have been perfect. 225/40/18 would have been good too to give it more of a grip bias. With the old 2L engine, larger diameters make it feel too slow but I would think with this new engine they could get away with at least a 10-20mm boost in diameter. (And for those who say, "Just slap bigger tires on it!" - That causes the speedo to be off and handling or clearance issues sometimes so no.)
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 01-14-2021, 10:29 PM   #1295
soundman98
ProCrastinationConsultant
soundman98's Avatar
I keep seeing honda accord in that back end
Ever try hitting on a girl at a bar with " nice, you've got a mom butt"?...
Dadhawk (01-15-2021)
Old 01-15-2021, 03:51 AM   #1296
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Pleased to see the new BRZ 's designers did not follow the current trend to smaller/squintier/highly segmented headlights that the use of LEDs makes possible, but have instead opened them up. It seems that the pattern recognition circuitry in our brains "sees" headlights as eyes, and when those eyes become too misshapen relative to biological norms, at least to me they just don't look right.
Sport-Tech is offline   Reply With Quote
The Following User Says Thank You to Sport-Tech For This Useful Post:
JesseG (01-15-2021)
Old 01-15-2021, 09:16 AM   #1297
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Where did you find this?
StE92ve is offline   Reply With Quote
The Following User Says Thank You to StE92ve For This Useful Post:
HachiRokuX (01-15-2021)
Old 01-15-2021, 09:58 AM   #1298
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
I love the integrated duckbill wing! The more I look at the 2nd gen BRZ the more I like it. Can’t wait to see the 86.
JesseG is offline   Reply With Quote
Old 01-15-2021, 10:02 AM   #1299
JesseG
JesseG's Avatar
I think that is true. My daughter always points out the “face” different cars have. She sees them as a face, and the headlights are the eyes. She says my FR-S looks like it’s angry.
The Following User Says Thank You to JesseG For This Useful Post:
Sport-Tech (01-16-2021)
Old 01-15-2021, 10:19 AM   #1300
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
1st world problems
HKz is offline   Reply With Quote
Old 01-15-2021, 09:18 PM   #1301
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I love the more sculpted rear quarter panel.
Very pleased.
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
beltax90 (01-15-2021)
Old 01-16-2021, 12:34 PM   #1302
TheDonEffect
Drives: A mix
mine!
Lol I actually switched to that one too lol.
TheDonEffect is offline   Reply With Quote
The Following User Says Thank You to TheDonEffect For This Useful Post:
beltax90 (01-16-2021)
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 230 01-03-2023 01:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) — General Topics 10 07-11-2016 09:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) — General Topics 4 06-15-2012 01:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
