Old 01-13-2021, 01:47 PM   #15
czellers
czellers's Avatar
Drives: 2K19 GT86
Originally Posted by shu5892001 View Post
Why not get it ceramic coated?
Paint correction ceramic coating is the only service I seem to be able to source around me. Is being able to get metal objects ceramic coated a readily available service in your area?
czellers is offline   Reply With Quote
Old 01-13-2021, 03:31 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Try calling exhaust shops in your area and asking if they know anyone that does it. Some of the commercial coating companies in my area do offer it, but it is not readily apparent that they do.
czellers (01-13-2021)
Old 01-13-2021, 04:01 PM   #17
czellers
czellers's Avatar
Drives: 2K19 GT86
Hahaha I may, but i'll be honest.. thats already sounding expensive.. Prob charge me more than the header is worth.
Old 01-13-2021, 04:49 PM   #18
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Try this:
https://www.google.com/search?source...QWaB7UQ4dUDCAg
LimitedSlip is offline   Reply With Quote
Old 01-13-2021, 09:18 PM   #19
Compelica
Compelica's Avatar
Drives: 86 GT
Originally Posted by gpvecchi View Post
My two cents, 86 GRMN has catless headers as stock, without any wrapping or heat shield. If Toyota didn't put protection on, I'd say that wrapping helps, but it's not necessary.
Do you have a picture of it?
Compelica is offline   Reply With Quote
Old 01-14-2021, 12:56 AM   #20
gpvecchi
gpvecchi's Avatar
The Following User Says Thank You to gpvecchi For This Useful Post:
Compelica (01-14-2021)
Old 01-14-2021, 01:32 AM   #21
PulsarBeeerz
Drives: JRSC BRZ SOLD
The GRMN 86 also came with decently sized hood vents so the heat from the header is mitigated quite a bit. GRMN is like STi, they don't have to play by all the production rules with super low volume vehicles..
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
czellers (01-14-2021)
Old 01-14-2021, 07:11 AM   #22
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
One option is to make a sort of heat shield using something like Design Engineering Form-A-Shield.
Unlike heat wraps, it still allows the pipes to "breathe" and not trap any oil, grease, or liquids that can damage the pipes while managing engine bay heat. Moreover, you can use the excess sheet to wrap the other pipes like front & mid pipes that contribute to cabin heat and event the muffler/resonator that traps the heat even more. Wrapping these pipes also absorb the pipe's natural vibrations therefore affecting the tone of exhaust. On my 2019 TRD SE exhaust for example, it muffled the mid & high notes leaving behind a bassy hum & also reduced cabin noise.
I've tried using high-temp spray ceramic coating for headers before I installed the FT86 UEL & even coated it several times. However, the heat was still significant.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 01-14-2021, 10:42 AM   #23
czellers
czellers's Avatar
Drives: 2K19 GT86
Whats a GRMN/86 GRMN? Is that a new 86 Trim offered by Toyota?
Old 01-14-2021, 11:08 AM   #24
czellers
czellers's Avatar
Drives: 2K19 GT86
Hoping to get this soon > https://86speed.com/seibon-vt-style-carbon-fiber-hood
Old 01-14-2021, 04:25 PM   #25
gpvecchi
gpvecchi's Avatar
86 GRMN is a very limited serie for JDM with A LOT of improvements to standard cars. It doubles the price...
Old 01-14-2021, 04:28 PM   #26
gpvecchi
gpvecchi's Avatar
I don't think that there is much difference while running.
The stock heatshields are for cat, that can reach very high temperatures. No cat, lower temperatures.
Old 01-14-2021, 04:43 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hood ducts make a big difference in under hood, coolant and oil temps. Even with a non catted header. I am running uncatted with a ceramic coated header and noticed about 10F difference in oil temp in a 20min track session.
Old 01-17-2021, 02:53 PM   #28
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
I won't comment on any of the downsides of wrapping the headers as I have no experience with its potential effects, however I did notice that after wrapping my new catless headers, it does feel like the heat went down significantly within the engine bay. May or may not be placebo, but I feel it reduces heat even better than when I had my stock headers/heatshield.
ItsReiko is offline   Reply With Quote
How to cure silicone coating for exhaust wrap? Stomachbuzz Engine, Exhaust, Transmission 9 01-07-2020 01:11 AM
Wrap exhaust side pipes on turbo? drz400dude Forced Induction 3 05-29-2017 04:21 PM
Impressive Wrap Vinyl wrap Thread Discounts For Forum Members ImpressiveWrap Southern California 4 05-26-2017 01:59 AM
Good carbon fiber vinyl wrap for ABS spoiler to wrap it? dssence Cosmetic Modification (Interior/Exterior/Lighting) 15 02-07-2014 04:31 PM
