Old 01-14-2021, 03:39 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Lightbulb Today I Learned...
Starting a thread for things we learn. Anything. GO
Today I learned that cam lobe edges are extremely sharp.
Edit- added photo for @gen3v8
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (08-06-2021), gen3v8 (01-15-2021), Ultramaroon (01-16-2021), x808drifter (01-15-2021)
Old 01-14-2021, 03:50 PM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Old 01-14-2021, 03:54 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Dude I could post something a couple times a week. My chimp brain is always learning something new. Like did you know you could make fire rubbing two pieces of wood together? Amazing.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
spike021 (01-14-2021), Ultramaroon (01-14-2021)
Old 01-14-2021, 03:56 PM   #4
DarkPira7e
DarkPira7e's Avatar
That's the intent
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
NoHaveMSG (01-14-2021), spike021 (01-14-2021), Ultramaroon (01-14-2021)
Old 01-14-2021, 04:03 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by DarkPira7e View Post
That's the intent
Dude watch your hands when you are retiming the engine. You time passenger side bank first with the cams on the base circle but then have to rotate the driver side cams so they are under valve spring tension when you put that side together and they will want to flip over on you.
EDIT: Actually I think I am confusing the FA with the EJ. On the FA you assemble the timing for the passenger bank, then rotate the crank set the timing on the driver cams on the base circle too but they are not set at TDC timing. The EJ you have one or both driver side cams off the base circle since it has one timing belt to run the whole thing and each bank can't be timed separately It has been almost a year since I have had one apart.
DarkPira7e (01-14-2021), Ultramaroon (01-14-2021)
Old 01-14-2021, 04:56 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Today I learned I'm not alpha as fuck
MS, CSCS, TSAC-F, CPT
The Following 4 Users Say Thank You to weederr33 For This Useful Post:
alphasaur (09-14-2021), humfrz (01-15-2021), NoHaveMSG (01-14-2021), Ultramaroon (01-15-2021)
Old 01-15-2021, 01:27 AM   #7
Today, I learned from my 4 ager granddaughter how old I was.
I have a bad habit of using a paper towel tube as a bullhorn to startle my 12 year old granddaughter. Today, as I was engrossed reading on the forum, the 12 year old got me back but good. I bolted back from the computer, about falling off my chair and yelled a very loud F word!
Th 4 ager scolded the 12 year old and said it wasn't nice to scare me that way because I was an old man, and then came up to me, put her arms around me and asked "pa-pa are you alright - are you sure you are alright?"
As she walked away, mrs humfrz asked the 4 ager "how old do you think your pa-pa is?"
She replied "oh, about a 100".
The Following 18 Users Say Thank You to humfrz For This Useful Post:
BigTuna (01-15-2021), Dadhawk (01-15-2021), DarkPira7e (01-15-2021), gen3v8 (01-15-2021), HKz (05-03-2021), KR-S (01-19-2021), Lantanafrs2 (01-18-2021), MICHAEL450f (01-15-2021), mrg666 (02-15-2021), new2subaru (01-17-2021), NoHaveMSG (01-15-2021), Silviacrazed (01-15-2021), soundman98 (01-15-2021), spike021 (01-15-2021), Spuds (01-15-2021), Stephen W. (01-15-2021), Ultramaroon (01-15-2021), wbradley (01-15-2021)
Old 01-15-2021, 09:50 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Cute
wbradley is online now   Reply With Quote
Old 01-15-2021, 10:50 AM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So she was a couple weeks off..
The Following 10 Users Say Thank You to Sapphireho For This Useful Post:
DarkPira7e (01-15-2021), humfrz (01-15-2021), KR-S (01-19-2021), Lantanafrs2 (01-18-2021), mrg666 (02-15-2021), NoHaveMSG (01-15-2021), Silviacrazed (01-15-2021), soundman98 (01-15-2021), spike021 (01-15-2021), Ultramaroon (01-15-2021)
Old 01-15-2021, 03:05 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by gen3v8 View Post
He's only gone and fucked up his phone/keyboard operating finger!! Obviously only applies to certain aged persons..
The Following User Says Thank You to JD001 For This Useful Post:
Old 01-15-2021, 03:43 PM   #11
DarkPira7e
DarkPira7e's Avatar
Nah it's still attached ot my hand, so I can type without issue. Just needed to stop the bleeding for a few minutes.
Just to re-affirm though; this post isn't meant to be about me, but it's a place for people to post what THEY'VE learned. I don't mind being picked on for being a dumb ass, but I also want people to share things in the spirit of learning.
Here's something I learned today-
Radium fuel rails for our cars have a bottom port for the fuel pulse damper- but Radium doesn't sell an aftermarket damper for that location. They want you to put one on the end of the rail, or in-line.
Old 01-15-2021, 04:09 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Well, I learned that bleeding stops after a few minutes.. but if it's your phone/keyboard operating finger then you're fucked..
The Following 3 Users Say Thank You to JD001 For This Useful Post:
Old 01-15-2021, 06:40 PM   #13
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Today I learned that a Rubik's Cube has 26 blocks (8 corners, 6 centers, 12 edges). I only found 24...
The Following 5 Users Say Thank You to Spuds For This Useful Post:
DarkPira7e (01-15-2021), JD001 (01-16-2021), NoHaveMSG (01-15-2021), soundman98 (01-15-2021), Ultramaroon (01-15-2021)
Old 01-15-2021, 06:42 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Vendor sent us a sample voltage gauge. What I learned was that this is a zener diode wired for over voltage protection. I thought it was for reverse current protection but that is a Schottky diode that you need for that. I think everyone can guess what happened.
DarkPira7e (01-15-2021), Ultramaroon (01-15-2021)
OFT KC learned Nah Software Tuning 3 03-17-2016 12:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 02:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 02:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-15-2014 11:37 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 08:15 PM
