View Poll Results: Coilover
CSG Flex A 10 29.41%
RCE SS1 18 52.94%
Fortune Auto 500 5 14.71%
Tein Flex A 3 8.82%
Tein Flex Z 4 11.76%
Multiple Choice Poll. Voters: 34. You may not vote on this poll
Old 01-01-2021, 12:54 AM   #29
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I decided to go with the SS-1 on my car. They have performed great and they do not feel any harsher than stock. It is hard to argue with KW suspension for $1,500!
RCE is also local if you are in VA. They provide awesome support.
Mike_ZN6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post:
CSG Mike (01-01-2021), Racecomp Engineering (01-01-2021)
Old 01-01-2021, 01:01 AM   #30
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
Yep - at the end of the day, I decided to go with RCE over CSG solely because RCE is local. It was super close!
jkamelo is offline   Reply With Quote
The Following 2 Users Say Thank You to jkamelo For This Useful Post:
DarkPira7e (01-01-2021), Racecomp Engineering (01-01-2021)
Old 01-03-2021, 08:31 AM   #31
jflogerzi
jflogerzi's Avatar
You really can not go wrong with either choice imo. Enjoy
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (01-04-2021), Racecomp Engineering (01-04-2021)
Old 01-03-2021, 10:50 AM   #32
TommyW
TommyW's Avatar
Drives: '13 Whiteout
LOL at the girlfriend approval comments. Don’t marry these women, it will only get worse..
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
MrSkubi (01-11-2021), strat61caster (01-04-2021)
Old 01-03-2021, 05:26 PM   #33
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Now you tell us!
I LIKE TIRES!
Old 01-04-2021, 09:51 AM   #34
M0nk3y
ALL dampers, zero exceptions, need regular rebuilds to maintain peak performance.
Dampers work by controlling motion, by pushing oil through controlled passages. This oil wears out, and needs changing, just how your engine, transmission, and differential all need oil changes.
+1000
Not only the oil inside, shims which control the oil flow wear down and valving dynamics also will change as the shims wear. In addition, the shaft guide (which surrounds the shaft and seals the shock) wears down overtime due to McPherson front suspension and lateral load it sees. Add dirt and grime these seals break down, thus contaminating the oil and causing increased wear. Shaft plate on a lateral plane will increase when shaft guides wear down and need to be addressed as well.
$400/rebuild is cheap. My shocks cost $250/shock + Material + Shipping. It's expensive, but if you want to maintain performance out of the shock it's a maintenance interval item. No way around it
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
CSG Mike (01-04-2021), Turdinator (01-04-2021)
Old 01-04-2021, 11:10 AM   #35
Ohio Enthusiast
Drives: 2018 BRZ
Do shock manufacturers have a suggested service interval? Or even a chart of time/miles vs. degradation?
Ohio Enthusiast is online now   Reply With Quote
Old 01-04-2021, 03:06 PM   #36
CSG Mike
CSG Mike's Avatar
If you want to maintain peak track performance, most coilovers will need rebuilds every 25-50 race hours, or 15k miles.
A more relaxed interval is 30-60k miles.
Stock dampers degrade on track in less than 5 hours, and by 20 hours, are typically dead. The degredation is gradual, and is usually not noticed by less experienced drivers, but the moment they go from old stock dampers to a fresh set (found easily on facebook, etc., from folks who buy the car and immediately put on coilovers), they realize how degraded their old dampers are.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
JAS4 (02-22-2021), Leonardo (01-04-2021), Ohio Enthusiast (01-04-2021), Racecomp Engineering (01-04-2021)
Old 01-04-2021, 03:20 PM   #37
M0nk3y
From my experience, my shocks (Motion Control 2-Way External Reservoir) were sent in at 15k miles. The front guide shafts were the biggest issue, and needed to be replaced. The shims were actually in excellent condition however which even surprised them. They said I "could" have extended maybe another season, but they agreed a rebuild was substantiated.
I run Eibach Spring dust boots which I think contributes to maintaining a good seal around the shock and restricting dust and dirt that may compromise the seals. I'll be due at the end of 2021 for another rebuild cycle.
Kyle H. - #89 STX
Old 01-04-2021, 03:43 PM   #38
It does depend on the shock as well.
Higher end motorsports shocks are typically designed to be rebuilt more frequently, in part due to lower friction being an important design criteria.
- Andrew
Old 01-04-2021, 03:48 PM   #39
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes.
Bilstein is going to be your longest life option, 100k street miles is pretty typical, iirc you certainly see them degrade before that (might've been spec miata guys getting rebuilds every season or two before they switched to Penske?), but they are not aggressive shocks as they come off the shelf targeting a more street compliant ride. They used to have a crazy warranty but I can't find it any more so they might have backed off on that.
Which, OP didn't want a race damper anyway.
Ohlins is ~20k street miles, and 10-20 race hours as mike said is pretty common. You can google that one as I found it in a pdf I won't link.
I found Feal reccommending 50k street miles or 1,000 track miles;
https://fealsuspension.com/coilover-services/
Too many factors to actually chart degradation effectively, the guy playing rally hero on a dirt backroad probably wears his dampers out faster then a track rat miata that's kept extremely clean and well inspected and is run on tracks with nice smooth pavement.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (01-04-2021), Ohio Enthusiast (01-04-2021)
coilover, csg, decision, rce, tein
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Coilover/Spring recommendation? PaoloJR CANADA 17 10-10-2018 05:32 PM
Yet another coilover recommendation thread Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-27-2015 08:03 PM
Coilover decision help. StormMcCloud Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-23-2014 08:18 PM
MR2 to FR-S?? Help with decision serge627 Mid-Atlantic 8 09-28-2013 06:08 PM
