Old 12-29-2020, 10:53 PM   #15
Mhm. Doesn't going from a smaller pipe to a larger pipe reduce pressure?
It reduces resistance to flow. Less pressure drop. Would you rather drink through a swizzle stick, or a big fat mcdonald's straw?
If you were stuck with swizzle sticks, you could tape a bunch of them together to get the same effect.
Old 12-29-2020, 10:57 PM   #16
Ashikabi
Ashikabi's Avatar
Ohhh I see. Less pressure drop because there is less pressure to begin with
Sent from my ONEPLUS A5010 using Tapatalk
Old 12-29-2020, 11:34 PM   #17
Not exactly but closer. Try thinking of the oiling system as a closed circuit. Pressure is zero as soon as it gets past the journals. Pressure is at its highest at the output of the pump - say 50 PSI just to give it a number.
That 50 PSI is our pressure budget to work with. It will always end up at zero past the journals but they are not the only things that resist flow (drop pressure). They could be if there was a short fat pipe between pump and journals but that's only for imagination.
Now start adding stuff like corners and narrow galleries to resist flow. If we feed the journals through a swizzle stick, the swizzle stick would take up most of that pressure budget because the cross sectional area of the swizzle stick hole is similar to the journal clearance. Let's say that the journals see only half of that total pressure - 25 psi.
How could we get back to that fat pipe? We can add a bunch of swizzle sticks together. Now oil flows more easily through that part of the circuit. Less pressure drop because more cross-sectional area.
Ashikabi (12-30-2020), new2subaru (12-31-2020)
Old 12-29-2020, 11:41 PM   #18
ermax
ermax's Avatar
Where can I get some swizzle sticks?
Old 12-29-2020, 11:55 PM   #19
From the swizzle stick store duh
ermax (12-30-2020), NoHaveMSG (12-30-2020), vintagemxer (12-30-2020)
Old 12-30-2020, 09:56 AM   #20
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by DarkPira7e View Post
With a thermostatic plate, my oil cooler still overcooked my oil in negative temps. I couldn't get my oil over 150 in highway driving
Get a higher rated thermostat.
Old 12-30-2020, 10:38 AM   #21
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I chose to uninstall the sandwich plate. Plan going forward yearly is to uninstall in October and re-install in May when temps get above freezing consistently. The oil cooler itself and lines remain installed but tucked away, much easier this way
finch1750 (12-31-2020)
Old 12-30-2020, 11:34 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Without it was was hitting 180s-190s. With cardboard over it I was back in the 170s
I have the same issue, it is even worse if you have a splitter and ducted hood. I left my house once in July for a track day at 4am and drove nearly 3 hours. It was a little over 50F and even my coolant temp Couldn't hit 160F
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (12-30-2020), norcalpb (12-30-2020)
Old 12-30-2020, 11:39 AM   #23
DarkSunrise
DarkSunrise's Avatar
Even on my 13 row Perrin kit (Setrab 613), my highway oil temps were below 170 F when it was cold out. I've mounted my front license plate as a block-off plate and it works fairly decently. I just pull the front plate off at the track or in the canyons.
At the track, the 13 row is what I'd call barely sufficient for NA. I would hit occasional peaks of 240-245 F.
My suggestion would be to get the 19 row and create a block-off plate for the highway.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
ninjan00dles (12-30-2020)
Old 12-30-2020, 11:56 AM   #24
ZDan
ZDan's Avatar
Drives: '23 BRZ
Have you considered that you might not need an oil cooler?
Old 12-30-2020, 12:30 PM   #25
norcalpb
norcalpb's Avatar
Very informative video on oil cooling for our cars.
Old 12-30-2020, 12:45 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
I remember this vid. Where he says "we've established the fact that you need an oil cooler" without presenting any evidence whatsoever that we do...
Old 12-30-2020, 01:23 PM   #27
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think this is more representative of cooler vs. no cooler data. To me it is not entirely conclusive as I have not observed the same behavior on my car. I will be switching to a setup to log oil temps and pressure on my car next year.
https://www.ft86club.com/forums/showthread.php?t=91820
Old 12-30-2020, 01:55 PM   #28
86TOYO2k17
I switched the standard 180F thermostat that starts to open around 150-160F. to a a 197F thermostat that starts to open around 167-177F.
I also used the oem forester water to oil heat exchanger, both of these combined let the oil warm up to 170s fairly quickly regardless of weather.
Also unless relocated the sensor is post oil cooler, and the oil could be a solid 30F hotter in other parts of the engine / pre oil cooler.
Air to Oil Cooler or Radiator with Integrated Oil Cooler? George Rosebush Tracking / Autocross / HPDE / Drifting 7 02-17-2020 03:49 PM
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
AT Trans Cooler: Performance cooler vs Standard Faulkner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-30-2018 11:34 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
