Old 12-28-2020, 11:14 AM   #29
czellers
czellers's Avatar
Drives: 2K19 GT86
Originally Posted by gpvecchi View Post
I searched around a lot, but I didn't fint an answer: is this part effective for performance in a NA car or not?
The Skunk2 CAI actually has something similar built-in, and since its all one piece, its more of the "air tight" type setup that all the others talk about when mating mix/match pieces, or even the OEM stuff and its foam type seals.. I have the skunk2 CAI, but havent installed it yet.
czellers is offline   Reply With Quote
The Following User Says Thank You to czellers For This Useful Post:
gpvecchi (12-28-2020)
Old 12-28-2020, 08:50 PM   #30
Ernest72
Hate to say it, but just do a drop in filter and be done. If you want to get rid of the sound stuff like me, just get a Perrin inlet tube or equivalent. In 4 years of owning the car, every year I think about getting the GS intake or another intake, and I do some searches and then it’s never really worth it other than for looks. I have headers and a tune. Not spending 300 bucks for looks, although I have come close a few times. Probably do it again next year, but then read my post and not do it.
Old 12-28-2020, 09:10 PM   #31
czellers
czellers's Avatar
Drives: 2K19 GT86
I just paid 233.00 for the Skunk2 (havent installed it yet) considering the price of a K&N drop in at an avg of $50, I really paid 180.00 for the skunk2. I really think it differs for every car. For example, line up 10 BRZs and install the same intake on all and I bet we'd all be shocked at the variations in results. I still think they're probably worth it if you can get a custom tune..
Old 12-29-2020, 12:17 AM   #32
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
A custom tune with a drop in and a tune with the Skunk2, dyno both after waiting for the car to learn the new settings. I am 100% sure there will be so so little difference between the two that it'd fall into the +/- area of a dyno.
Try and justify it all you want but there is a reason why a lot of people say to save the money and just get a drop in filter.
Also you CANT compare one car to another, that's not how that works.
The cars are going to vary wildly period.
The Following User Says Thank You to x808drifter For This Useful Post:
Ernest72 (12-29-2020)
Old 12-29-2020, 07:02 PM   #33
Ernest72
It’s only money. It won’t hurt.
Old 12-29-2020, 08:54 PM   #34
jflogerzi
jflogerzi's Avatar
Meh intakes are a waste. Remove the sound generator tube and get a drop in filter and call it a day...
2013 Series 10 FRS #553
Old 12-29-2020, 09:16 PM   #35
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Got a good deal on the V1. Did it for the swag points and to hear some nice whooshing noises. Not sure I would pay full price though
Even pros seem to like it, even if it admittedly doesn't really add all that much.
--There is a tune and dyno comparison at the end, though apparently the car already has a header so it doesn't really say much about the intake duct itself
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
botbs (02-08-2021)
Old 12-29-2020, 09:17 PM   #36
czellers
czellers's Avatar
Drives: 2K19 GT86
I'm not really trying to justify anything, I'm only addressing the original question regarding the intake duct.. also if you can't line up 2 brz/frs/86 respectively and compare (one stock and one with an intake) then that would be proof saying it does nothing is irrelevant, its only relevant to the one it was tested and confirmed on..
Tons of claims on intakes both ways, yet no dynos... so yea, basically were all just speculating.. until someone produces dyno test results that is.. until then though.....
Old 01-03-2021, 02:45 PM   #37
Ernest72
This debate was done years ago for the WRX. Plenty of data said the stock air box was good until 400 hp, but so many wanted an intake. In the twins case the intake will not hurt, but on the WRX it definitively could hurt and did for many who tried it. Spending money on a tune for an intake is wasteful and many did not do it, Most that wanted added am intake to other changes before they got a tune, which was fine. Still some tuners had trouble with the maf.
Simple thing is if you want one, get it. Just don’t expect any real gains over a drop in filter, other than looks and sound.
Old 01-03-2021, 07:11 PM   #38
new2subaru
Weight Weenie
Drives: 15 FR-S
https://www.ft86club.com/forums/showthread.php?t=35125
Old 03-24-2021, 10:14 PM   #39
Alfs
Drives: Mr.Happy
Smile
Originally Posted by Jdmjunkie View Post
I have the Greddy one that picks up air from the bumper opening. It keeps intake temps surprisingly low when the car is moving.
Nice, I was looking at that too, the place of the stock snorkel will much help on keep suck the cleaning air, but the intk temp will be higher than if it could suck directly on the frontal face.
Just ordered from Jp, I hope it will drop the intk temp and gives me more consistent power output when I'm on the track.
Alfs is offline   Reply With Quote
The Following User Says Thank You to Alfs For This Useful Post:
Jdmjunkie (03-24-2021)
Old 03-24-2021, 10:21 PM   #40
Jdmjunkie
Drives: Scion FR-S 10 Series
Awesome! My intake temps are within 10° of ambient when moving.
Jdmjunkie is offline   Reply With Quote
Old 03-24-2021, 10:42 PM   #41
Alfs
Drives: Mr.Happy
Thumbs up
Old 03-09-2022, 05:10 AM   #42
dexterchock
Drives: Toyota 86
why not 3d print one yourself and test it out https://cults3d.com/en/3d-model/tool...duct-mikasalim
dexterchock is offline   Reply With Quote
Grimmspeed Intake / HKS Intake Duct / JDL Catted UEL / HKS Hi Power V2 Cat Back ANUSTART Engine, Exhaust, Bolt-Ons 9 03-02-2020 12:15 AM
HKS Intake Duct Akuma13 Engine, Exhaust, Bolt-Ons 5 01-25-2017 04:22 PM
FS: HKS Intake Duct 1Cor10:23 Canada Classifieds 0 10-27-2015 12:07 PM
Crawford BPB Nib, perrin intake tube, and hks intake duct AlexBinJackson Engine, Exhaust, Bolt-Ons 6 08-04-2015 04:19 AM
