Old 12-26-2020, 11:48 PM   #15
TheFugitiveMind
Originally Posted by churchx View Post
Well, should work just fine for most including ones that track.
But if i may suggest, that while that extra -1.3dg front camber is obviously better then "nothing", better then rather understeer-biased OE alignment of 0dg front camber, if you do track car on regular basis, it seems insufficient for even contact patch, to not rip mostly outside of tires. Most that track twins usually go for something like -3 to -3.5dg front camber and -2.5dg rear. I also don't like uneven rear toe, that even is toe-out on right side. In left turns you may see excessive oversteer, also under floored gas, especially if with lack of grip, you may see tendency of car rear to always slip to right.
Yeah totally, if it was more of a true weekend track car I’d totally up the front camber to -2.5 but I do DD it a lot on the freeways and don’t really want to prematurely kill my tires. I see about 5-6 track days a year and I’m not really pushing It hard those days. Maybe. 7/10ths
I am also not a fan of the uneven toe in the rear, while the whiteline LCA are from SPC they didn’t come with the offset bushing for the toe, so I guess that’s as as close as the tech could get it (unless he was lazy). I work in the “industry” so I get pretty significant discounts from companies so I might do some toe links later down the line
TheFugitiveMind is offline   Reply With Quote
Old 12-27-2020, 11:25 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
TheFugitiveMind: tech definitely was lazy. Only adjustment twins suspension has in stock is toe one. Tells a bit about importance of getting toe right.
Imho error might be, as toe & camber linked a bit, for tech to be overly concentrated on dialing camber, and leaving toe whatever ended up with. I'd prefer other way around, accepting 0.3dg+/- difference in camber between sides, but preferring toe as even as possible (hopefully within 0.01dg+/-), and a bit more toe-in rear. Also might be, that within available adjustment ranges tech was tasked with to dial eg. camber that much, with which toe-adjustment range was insufficient. Again .. in this case i'd prefer maybe less camber (or more) then asked/wished, but toe right, but in future consider adjustable toe-arms, that usually offer more range then stock eccentric toe adjustment.
Old 12-27-2020, 04:48 PM   #17
jflogerzi
jflogerzi's Avatar
Originally Posted by TheFugitiveMind View Post
Installed whiteline rear lower control arms and got it re aligned. Happy to report that steering wheel is centered and tracks straight. For now...
I do have the SPC crash bolts of the front (upper position) has any of you guys experienced it slipping? I had them on my 2005 WRX back in the day and they would always slip which is why I’m kinda against those and would rather have plates.
Get the peddler top plates. You won't loose any travel and get camber built in. I believe -1.5 camber. Pretty cheap but you will need a front alignment as the struts would need to come out to install
2013 Series 10 FRS #553
Old 12-27-2020, 04:53 PM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
jflogerzi: imho more like 0.75 extra negative camber. Then again that + camberbolts in both holes, and aprox. -3dg (nice starting point for tracked twin) should be reachable.
Old 12-27-2020, 05:19 PM   #19
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
They are advertised at - .75 deg, but i got about a full degree out of em. I also use the SPC cam bolts in conjunction and -2.5 is pretty much my max.
BlueWhelan is offline   Reply With Quote
Old 12-27-2020, 05:38 PM   #20
jflogerzi
jflogerzi's Avatar
I was able to get about 2.4 out of the se setup. Just done remember if it was oem crash bolts or camber bolts with the peddlers
Window Alignment Issue BDubbs4Bama Issues | Warranty | Recalls / TSB 3 02-21-2019 11:24 AM
SPC LCA Alignment Issue? ssidd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-15-2018 01:58 PM
Pulling FRS Rear Fenders sal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-18-2015 10:09 AM
Do I just need an alignment or... (scraping issue) IDFWU 420 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-26-2014 01:26 AM
Alignment issue guscab Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-08-2014 11:26 PM
