Old 07-29-2020, 04:29 PM   #267
ArrrBussiere
ArrrBussiere's Avatar
Drives: 2014 Subaru BRZ SC & 2018 Tacoma
This was an incredibly fun read today - definitely excited to see where it ends up as a finished produt. Phenomenal work!!
ArrrBussiere is offline   Reply With Quote
The Following User Says Thank You to ArrrBussiere For This Useful Post:
DIY (07-30-2020)
Old 10-19-2020, 04:29 AM   #268
DIY
DIY's Avatar
Drives: BRZ, WRX
It has been a long time since I have made any updates to this thread, not a lot has happened with the car but I have been collecting some parts and investing in more fabrication tools.
Today I picked up a set of tyres which I will need to have so I can modify the body for the new ride height and make some new panels to suit. These tyres are way past their use by date but I got them dirt cheap. No point buying new tyres unless I was planning to drive this thing some time soon.
I couldn't resist the opportunity to mock up what the car might look like with some wheels on, speaking of wheels, they will be my next purchase.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following 13 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-02-2021), Busybee (12-26-2020), CrowsFeast (10-19-2020), DustinS (10-24-2020), Dzmitry (10-19-2020), fika84 (10-19-2020), Kiske (10-19-2020), Lonewolf (10-20-2020), NoHaveMSG (10-19-2020), NWFRS (11-29-2020), solidONE (10-23-2020), WORKS (01-19-2021), Zer0 (10-25-2020)
Old 10-19-2020, 02:34 PM   #269
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
That thing looks mean! I love it!
ShibusaTouge is offline   Reply With Quote
The Following User Says Thank You to ShibusaTouge For This Useful Post:
DIY (10-20-2020)
Old 11-29-2020, 08:14 PM   #270
DIY
DIY's Avatar
Drives: BRZ, WRX
Hey guys, a few things have been happening.
To start with I have taken delivery of my new AC/DC dedicated TIG welder. Up until now I have been doing all my welding using a multi-purpose MIG welder that has a lift-arc TIG function in DC only.
Now that I have a welder that can weld any type of metal I can save a lot of money by making my own catch cans, dry sump tank, swirl pots for example. So it has cost a fair bit up front for the welder but over the long run it should pay for itself.
After a fair bit of back and forth with measurements I have also ordered a set of wheels from Japan. The wheels are 18 x 10.5 but I have had to be very careful with the offset because I am in danger of the car being too wide to fit on my trailer. I won't spoil the surprise and say what they are but as soon as they arrive there will be lots of photos. Unfortunately due to Covid they are going to take a fair while to arrive.
The last thing is I have ordered a pair of genuine Subaru rear wheel bearings off the 08 onwards STi to convert the rear end to 5x114.3 pcd. The front RX8 uprights are already 5x114.3 so this has given me larger wheel bearings and a much wider selection of wheels to choose from.
My Build Thread
The Following 5 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-02-2021), Code Monkey (11-30-2020), Dzmitry (11-30-2020), Lonewolf (12-09-2020), solidONE (11-29-2020)
Old 11-30-2020, 02:26 PM   #271
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
Been following this on NASIOC, didn't realize it was on here too. Your build has given me a lot of great ideas, keep up the awesome work!
TunaNoCrust is offline   Reply With Quote
The Following User Says Thank You to TunaNoCrust For This Useful Post:
DIY (11-30-2020)
Old 12-09-2020, 04:50 AM   #272
DIY
DIY's Avatar
Drives: BRZ, WRX
Rear wheel bearings arrived today, brand new genuine Subaru from the 08+ STi. Got these to convert the rear to 5x114.3 PCD so when my new wheels arrive I can bolt them straight on.
The front PCD is already 5x114.3 with the Mazda RX8 front uprights.
Next to the old wheel bearings you can easily see the size difference.
My Build Thread
Busybee (12-26-2020), Code Monkey (12-09-2020), new2subaru (12-26-2020), Racecomp Engineering (12-10-2020), solidONE (12-11-2020)
Old 12-26-2020, 05:40 PM   #273
DIY
DIY's Avatar
Drives: BRZ, WRX
Hey guys, Merry Christmas to you all.
I have been modifying the Honda K24 valve cover so that the motor is less tall and dry sump ready. The design is based on the Honda Racing HPD valve cover.
I'll do a more detailed post once the work is done but here is a teaser for now.
I am also hoping to have a gearbox coming within the next few weeks.
My Build Thread
The Following 3 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-02-2021), NoHaveMSG (12-26-2020), solidONE (12-26-2020)
Old 12-26-2020, 06:34 PM   #274
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Cast aluminum welding is not for the feint of heart. Glad to see you excited about the new Tig.
Intent > Content
Old 12-26-2020, 10:35 PM   #275
DIY
DIY's Avatar
Drives: BRZ, WRX
There is a good chance the valve cover will end up in the bin
My Build Thread
The Following User Says Thank You to DIY For This Useful Post:
Old 12-26-2020, 11:47 PM   #276
solidONE
solidONE's Avatar
Clean the shit out of the material before, and pin a 4 leaf clover on your welding helmet. lol
Intent > Content
Old 12-27-2020, 03:49 AM   #277
DIY
DIY's Avatar
Drives: BRZ, WRX
Good thing is that I have a lot of offcuts from the trimming I did to practice with. The welds will be ground smooth anyway so I can do short runs to minimise heat without worrying how it looks. I will use large chill bars and I may even use pulse for even less heat.
My Build Thread
solidONE (12-27-2020)
Old 12-27-2020, 03:22 PM   #278
solidONE
solidONE's Avatar
I'm sure you will figure it out. With aluminum, If I can get away with using alumiweld, I'll use alumiweld rods and gas. Its more like brazing than welding. Though I sense you are not looking for a easy way.
Intent > Content
Old 12-28-2020, 10:34 PM   #279
DIY
DIY's Avatar
Drives: BRZ, WRX
Some exciting news, I finally got a trans for the car! It's a ZF 5 speed S5D 320Z from a BMW. Good for 320Nm of torque which should be plenty behind my turbo K24 engine. I weighed the box at around 37kg (82lbs) which is rather light considering the strength, its very compact too.
Now I just need to get an adapter plate and I will be able to get a lot more fabrication done, engine mounts, trans mount, steering rack mounts etc.
My Build Thread
DustinS (01-02-2021), Irace86.2.0 (08-24-2021), solidONE (12-28-2020)
Old 01-01-2021, 08:48 PM   #280
DIY
DIY's Avatar
Drives: BRZ, WRX
I did some test welding yesterday on some of the scrap cast aluminum I cut off the valve cover just to see how it welds and how well it might clean up after with a flap disc and file finish.
It was not as difficult as expected so as long as I can manage the heat I have a lot more confidence in the project now.
My Build Thread
The Following 4 Users Say Thank You to DIY For This Useful Post:
Ash_89 (03-02-2021), DustinS (01-02-2021), NoHaveMSG (01-05-2021), solidONE (01-01-2021)
