#15 | |
Drives: 2K19 GT86
#16 |
Drives: 2015 BRZ Limited
I ran it for a very long time. Overall, I liked it. I found it easier to remove than the OEM intake box, and I too liked how sealed it was. My filter was so clean every time I removed it to clean it, and I live in dusty Arizona. I was advised by my tuner (CSG) to keep the restrictor in the pipe so that MAF scaling was similar to stock. I was told the scaling without the restrictor doesn't make any sense, and it performs better with the restrictor. The one problem I had was the bolts that hold the filter in the box kept backing out on me ~5000 miles. I'd open the hood and find I had 2 or 3 bolts missing. I ended up using some Locktite to hold them in. Kind of worked. I have recently swapped back to the OEM box because the Jackson Racing oil cooler wouldn't fit with how big the box was.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following User Says Thank You to FunnyGopher For This Useful Post: | czellers (12-23-2020) |
#17 | |
Drives: 2K19 GT86
i have the OFTv2 as well and ill be looking into a way to do a custom tune (if beneficial) to remove the inline restrictor but we'll see i want to learn to tune early and really get a feel for the car prior to stepping up to forced induction.. Thanks for the heads up on the bolts too! |
#18 |
Drives: 17 Asphalt 86
The canned stg2+ tune wasn't amazing on my 2017 manual with an inlet tube and drop in filter. Required a bit of MAF rescaling and the AFR was mostly good but leaned out at points, and fatter on others. I can only imagine an aftermarket intake would make that much worse.
If you have OFT I would data log some pulls and post them in the tuning section/logging thread. Fortunately there are many great people on the forums who can dial in a more custom setup. Steve99 being one. Edit: I have Tomm.brz doing a custom tune for me right now. Last edited by RToyo86; 12-23-2020 at 11:54 AM. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | czellers (12-24-2020) |
#19 |
I recommend not removing the restrictor. As it was described to me, there is no performance gain, if anything a performance loss, from removing the restrictor on an NA car. The turbulence is worse, you don't actually get more air because now the air velocity is less, and the MAF scaling is to just compensate for the lack of air.
| The Following User Says Thank You to FunnyGopher For This Useful Post: | czellers (12-24-2020) |
#20 |
Drives: 2014 GT86
MAF scaling is to compensate different MAF sensor readings to not mess up air to fuel ratios and not let engine run with inefficient too rich on one end, or wearing engine with excessive knocking due running too lean on other end, if running with stock ECU tune.
It's not for "compensating". It's about ecu sensing real amount of air passing to know how much fuel needs injecting in. And if some aftermarket intake messes with MAF sensor readings, one should adjust ecu tune to interpret right way now different sensor readings to know how much air there was. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | czellers (12-24-2020), FunnyGopher (12-24-2020) |
#21 | |
Drives: brz 2017 hksv2
not worth it |
| The Following 3 Users Say Thank You to tomm.brz For This Useful Post: |
| Skunk2 coilovers | Stevenduarte210 | Brakes, Suspension, Chassis | 4 | 05-18-2020 11:01 PM |
| Skunk2 Pro-C Coilovers | Kellhound | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-14-2015 02:10 PM |
| Skunk2 Radiator DIY | post_break | DIY (Do-It-Yourself) Guides | 5 | 03-20-2015 08:47 AM |
| Skunk2 Review. | FirestormFRS | Engine, Exhaust, Transmission | 1 | 12-31-2014 08:55 PM |
