Drives: 2017 Subaru BRZ
CSG Spec C2 Brake Pads Review
- CSG C2 Brake Pad Review -
When I started tracking the goal was to keep cost down. I bought Winmax W4 a hybrid street/track pad. They were a compromise in both cases, not good enough on track and sub optimal on the street. They wore down quickly so I jumped to Winmax W5 and ultimately W6 when my pace increased. Then I went to my first race pad and purchased Project Mu 999 pads. They were great on track with strong initial bite and plenty of capacity with absolutely no fade. The biggest con with those pads was they were an on/off pad with minimal modulation. Finally I jumped to the CSG Spec C2 pads and they have been amazing! Just as much bite compared to 999, but much better modulation. My pace is even faster now and the pads won't fade whatsoever. Not to mention they last forever! I've done 9 track days on them so far and as you can see in the photos they have plenty of meat left. Higher cost yes, but they last twice or even three times as long so they end up saving money in the long run. Highly recommend!
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
| The Following User Says Thank You to EINSTEIN562 For This Useful Post: | jflogerzi (12-08-2020) |
#2 |
you swapping pads for DD driving and rotors?
2013 Series 10 FRS #553
#3 |
Señor Member
Drives: '17 BRZ PP
My bro used to have a Mini with brakes/pads (OEM) that felt ON/OFF too. Worst feeling brakes I have ever driven with. My current OEM PP brembo pads feel the best I have ever driven as well. Perfectly analog modulation, how much brake pedal force you apply is how much braking power you will get. I will either get OEM again or maybe try the CSG pads since their products are always good stuff.
#4 |
How do you stop these pad from squealing? I've been running these for a month or so. Bedded in multiple times. Added Ti shims with a light coating of Brembo shim grease that promptly shot out all over my wheels(maybe it wasn't so light, lol). The Ti shims cut about 50% of squeal, but any hard braking once warmed up still feels like it could blow my ear drums if I have my windows down.
#5 | |
Drives: Scion FR-S 10 Series
These are track pads, are you sure you got them warm enough to transfer pad material? |
#6 | |
I went though the full bedding process twice. I actually managed to boil my fluid the second time. I then bled the brakes, running 2L of Motul through to get as much of factory fluid out using a power bleeder. I added the Ti shims and grease to try and reduce the crazy squeal I get. It cut out about 50% but, if I scrub a good amount of speed down to <15mph or so, they can squeal so loud its painful with the windows down. Like coming down main 55mph road to turn into side street. I get these are track pads, I don't expect them to be quiet. I just didn't expect them to be so insanely loud. |
#7 | |
My best recommendation is to keep bedding them until the noise goes away. Also if you can take a picture of your rotors so the thread can see how much pad material has been deposited. |
#8 | |
I had the blue hazing and smell after I bed them in the first two times. What should the rotors look like now? front: ![]() rear:
#9 | |
Drives: Subaru BRZ / Toyota 86 Experts
2. In terms of heat, the pads do need more heat than the normal sprint compound. It does, however, run "cooler" than other compounds considering its application window. On paper, CSG compounds appear to have a more narrow optimal temp range than competing compounds, but the operating window and max performance ceiling you will experience is consistent while other compounds drop off with heat. 3. Proper bedding provides a nice transfer layer on the disc. If you're putting in tons of street mileage and ultra light braking, the transfer layer will eventually wear off (think of sandpaper rubbing on wood). You'll want to bed (or also known as burnish) the discs again to create a good transfer layer. That transfer layer acts as a little lubricant and that effectively reduces the harshness of NVH. 4. Out of the many brake pads for large caliper setups, CSG C2 has been consistently reported as lower NVH than competing compounds. Of course, disclaimer is always, this is a race product and it's what our racing clients use to find an edge against their competitors. 5. Match up with stickier tire compounds and the brakes will feel confident and assuring. The stiffness and linear consistency is key so you, as the driver, can modulate the right amount of pressure to provide the optimum braking force required to slow down.
#10 | |
Once you do this, the noise should be minimal, and only manifest at low speed low pressure stops. If you are using brake temp paint, you need green and orange to be oxidized. Pink/red doesn't need to be. If you're boiling your fluid doing this, either you need a higher grade fluid, or you're inadvertently getting ABS intervention, or possibly both. Your rotors look good, but if your pads smoked both times you went to burnish them, then they're probably not done burnishing. Expect judder during the burnishing process. |
#11 |
Drives: '24 GR86
Here's mine after the last event.
![]() My first event on these pads was done with stock tires/wheels and suspension. This time I was on KWs and 18x9.5s with 255 width 200tw tires. Additionally, the last track was pretty much all 2nd and 3rd gear, where as this track was 3rd and 4th, and one straight long enough for 5th. Long straights down to 2nd/3rd gear hairpins essentially. So much tougher on brakes. The brakes did get pretty hot. I got ONE instance towards the end of the day where I noticed a slight bit of fade and the pedal getting slightly mushy, but I finished that lap as a cooldown lap and then carried on without issue; perfectly firm pedal again. After some discussion with Mike, the wear pattern suggests that the fact I've been using the same rotors between street and track pads (switching before/after events) has caused some built up material. So I'm gonna get another set of rotors. Aside from that though, I'm really happy with the pads. Easier to modulate than my old PMU CRs I've run, and a bit more braking force, and a lot more fade resistant. They worked pretty well on the stock tires, and they worked great on these 255s. Expensive, yes; but if I'm able to get as many events as some of the other people in this thread, I'll be pretty happy.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | CounterSpace Garage (12-18-2020) |
#12 | |
Looking forward to more feedback.
| CSG Spec Brake Compounds Review Thread | FirstWinter | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 105 | 11-27-2023 12:25 AM |
| Brand new CSG Spec C1 brake pads front and rear | Chuckable | Brakes, Suspension, Chassis | 7 | 10-02-2019 06:56 PM |
| My Review of Winmax Brake Pads | ichitaka05 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-31-2014 12:11 AM |
| FS: GT spec brake upgrade package (front disc & pads) | Fizz | Australia Classifieds | 0 | 05-28-2014 01:33 AM |
| [SYD] CHEAP Project Mu B-Spec Brake Pads | omgwtfbbqsauce | Australia Classifieds | 4 | 06-28-2013 12:10 PM |
