Old 12-12-2020, 11:31 PM   #15
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Originally Posted by MdNt.exe View Post
i didnt know this was an issue, could you provide more info on this? All oem setup aswell, but may jump on this.
Ok so I have this harness as an example. This one came with a jumper wire, so this one doesn't need to be repinned. Now the CC3 has a ground wire pinned to the slot that I'm pointing to and the pin to the right has the trigger wire. So I swapped the pins.
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 12-12-2020, 11:33 PM   #16
Rican_D
Rican_D's Avatar
Here's the thread on the old Joying units that you had to repin.
Old 12-12-2020, 11:41 PM   #17
Racenut
Racenut's Avatar
I'm curious about a unit like this just so I can run Torque app and use it to display gauges.
Racenut is offline   Reply With Quote
Old 12-13-2020, 12:20 AM   #18
Rican_D
Rican_D's Avatar
Yeah all Android head units can do that
Old 12-14-2020, 02:47 PM   #19
Rican_D
Rican_D's Avatar
I'm trying to run the back up camera, but damn I can't get that RCA cable through that rubber tube
Old 12-15-2020, 04:48 AM   #20
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Santa came early.
This literally comes with all harnesses.
Can you take a pic of back and frame? thx
Trap63 is offline   Reply With Quote
Old 12-15-2020, 08:36 AM   #21
Rican_D
Rican_D's Avatar
I'll try to do that next time I take it out
The Following User Says Thank You to Rican_D For This Useful Post:
Trap63 (12-15-2020)
Old 12-15-2020, 05:01 PM   #22
ermax
ermax's Avatar
Does the now playing screen support any audio playback? For example if I start some playback with Spotify will the now playing screen show that?
Did you manage to feed that RCA cable for the backup cam? I added one on my car and if I recall I used a little Vaseline. It's funny they say the camera is 1920x1080 yet it's running over RCA. RCA doesn't even come close to running 1920x1080. It would be cool if you could tie in a PoE camera as a backup camera. Then you could get some high quality video into it.
Old 12-15-2020, 07:17 PM   #23
Rican_D
Rican_D's Avatar
The widget is only for the built in music player. I can't get the damn thing past the neck of the car side of the tube
Old 12-16-2020, 05:26 PM   #24
ermax
ermax's Avatar
The camera I got had a compact connector that wasn't too hard to pass through the tube. Once it was through you would then connect it to a pigtail that had the full sized RCA connector. I'm trying to remember how I got it through, maybe I used a coat hanger. It's been a while.
Old 12-16-2020, 05:47 PM   #25
Rican_D
Rican_D's Avatar
This one is a full RCA so it's making it tough
Old 12-16-2020, 09:15 PM   #26
ermax
ermax's Avatar
Maybe someone makes an RCA cable with some sort of slim interconnect in the middle.
Old 12-16-2020, 09:19 PM   #27
Rican_D
Rican_D's Avatar
Unfortunately that end runs to radio. Can't get around it
Old 12-18-2020, 10:39 PM   #28
r3myx626
r3myx626's Avatar
Drives: 2015 Subaru BRZ Limited ISM
Use soap and water to lubricate it. Helps to use fish tape.
r3myx626 is offline   Reply With Quote
The Following User Says Thank You to r3myx626 For This Useful Post:
Rican_D (12-18-2020)
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 03:53 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 09:48 PM
WTB: Android HU tonypalomo Want-To-Buy Requests 0 01-12-2015 04:00 PM
Help|Best Android based HU redsuns03 Electronics | Audio | NAV | Infotainment 14 07-28-2013 09:30 AM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 11:37 PM
