Rear Sway Bar Delete
I'm new to the platform and need a bit of help deciding how to setup my car for next year as a dual purpose SCCA D Street and time attack car.
Rules allow for 1 bar change so my original plan was to pick up a Hotchkis FSB and run it on the softest setting. However, I recently started leaning towards deleting the RSB after encountering inside rear tire spin a few times. As a stock car, I feel like the BRZ already has pretty good roll resistance where I might be able to get away with removing the RSB. Any feedback on how the car performs with either setup (bigger front bar vs deleting rear bar) would be appreciated. Planned mods: OEM crash bolts, 0 toe all around 225/45R17 200TW tires Last edited by SCFD; 12-14-2020 at 06:44 PM. |
#2 |
Rust bucket enthusiast
Removing the rear is fine
I removed mine in winter to help with snow and ice traction. Didn't notice too much until I put the 200tw tires back on
| The Following User Says Thank You to DarkPira7e For This Useful Post: | SCFD (12-14-2020) |
#3 |
Drives: '13 FRS - STX
Front stiffness helps the car transition more quickly in slaloms and a little help in terms of reducing camber loss due to body roll in steady state. You can try no rear, I have, but I don't think it helps as much as a stiffer front.
| The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
#4 |
Drives: '23 BRZ
For a street car, stiffness is OK. For track, stock suspension is way too soft. I'd go the stiffer front-bar route and keep rear bar. And anything you can do to get more front camber would be for the best... I don't think just camber bolts will get you where you wanna be. CAn you run offset top mounts or camber plates?
| The Following User Says Thank You to ZDan For This Useful Post: | SCFD (12-15-2020) |
#5 |
Drives: 13 White MT FR-S
shits gonna push (understeer)
#6 |
Drives: 2016 Scion FRS
Frankly, rear bar delete on a stock sprung car sounds awful.
You won't be able to reduce camber loss and you are giving up overall roll stiffness, both of which are at a premium in Street. Additionally, I think you would introduce some nanny interference weirdness. With that said, it is free to try (outside your time to disconnect/reconnect and your opportunity to try/learn something else during those runs), so go for it. |
| The Following User Says Thank You to steverife For This Useful Post: | SCFD (12-15-2020) |
#7 | |
#8 | |
You are allowed one bar change, so by focusing on the rear bar, you are giving up the opportunity to run a larger front bar to minimize camber loss up front. |
#9 |
Drives: '23 BRZ
Also note that by reducing rear roll stiffness, you're going to get more roll at the rear *and at the front*. Since it sounds like you're gonna be very front-camber-limited, that's not so good. Much better to INcrease front roll stiffness which will reduce front camber loss.
FWIW I've never had serious inside rear wheelspin issues at the track with ~60% stiffer lowering springs and stock swaybars, on RE71Rs. I do get some rear wheelspin out of some lower-speed 2nd gear corners but always both rears. Last edited by ZDan; 12-15-2020 at 12:05 PM. |
#10 |
Inside rear wheelspin on Street class ax setup sounds like a lead foot overwhelming the torsen, won't be able to do much to fix that without going up to STX and getting a clutch type diff. You'll have to change your drive style. That being said unhooking the rear bar is free so just go try it before buying a front bar and see if you like it.
#11 |
Thanks for all the feedback. This reminded me of a setup I previously ran on a FWD car without a front bar. The car was sloppy even with quite a bit of toe-out and heavy springs (suspension frequency of ~2.2Hz).
I think running no rear bar on the BRZ will probably hurt more than help. |
| The Following User Says Thank You to SCFD For This Useful Post: | DarkPira7e (12-15-2020) |
#12 |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 01:00 PM |
| WRX rear sway bar: good front sway bar combo? | LerpK | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2016 07:02 PM |
| <FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar | mav1178 | Brakes, Suspension, Chassis | 2 | 07-21-2016 06:49 PM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 02:20 PM |
| gt 86 rear sway bar | Scottyp | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 04-22-2015 04:29 PM |
