Old 12-14-2020, 08:24 PM   #15
Copy
Copy's Avatar
Drives: GR Corolla CE
Originally Posted by Plumbus View Post
Thanks dude. I put 83031CA024 on my list, it is the tS push start button from the 2018 model and sells for around $100.
You get your wheels yet?
Nice! No, not yet. Mine is supposed to be here the end of the week. Did you get yours?
IG: grcwicks
Copy is offline   Reply With Quote
Old 12-14-2020, 09:42 PM   #16
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Same here, getting them on thursday if everything goes right. Gotta make an appointment with the tire place now that I remember. Also installing coilovers and rLCAs this weekend, as well as diff and xmember bushings.
Let me know if you take some pics! Can't wait to see our cars sexier than ever.
Plumbus is offline   Reply With Quote
Old 12-14-2020, 11:40 PM   #17
Copy
Copy's Avatar
Definitely start a thread so I can follow your build. I probably won't get the wheels mounted until spring. I am wanting to get Hankook RS4's but they're currently on back order.
IG: grcwicks
The Following User Says Thank You to Copy For This Useful Post:
Plumbus (12-14-2020)
Old 12-17-2020, 08:19 PM   #18
Copy
Copy's Avatar
My wheels came in!
WedsSport TC105X
17x9 +35
IG: grcwicks
The Following 7 Users Say Thank You to Copy For This Useful Post:
Clipdat (12-17-2020), jflogerzi (12-20-2020), Lonewolf (01-30-2021), Plumbus (12-17-2020), Racecomp Engineering (12-18-2020), Spankopotomous (12-18-2020), TylerLieberman (12-17-2020)
Old 01-26-2021, 08:41 PM   #19
Copy
Copy's Avatar
Finally installed the new wheels!
IG: grcwicks
The Following 5 Users Say Thank You to Copy For This Useful Post:
jflogerzi (01-26-2021), KMA KiCKz (01-31-2021), Lonewolf (01-30-2021), Plumbus (01-26-2021), Spankopotomous (01-27-2021)
Old 01-26-2021, 09:19 PM   #20
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
[img]https://i.imgur.com/5ILC4Or.jpgimg]
[img]https://i.imgur.com/eKnIAcF.jpg[img]
They look SO good! What's your drop, camber, and tire specs?
Old 01-29-2021, 02:17 PM   #21
Copy
Copy's Avatar
Thanks!
2" drop
Camber is F -1.3 R -2.8.
Tires are Maxxis VR1's in 255/40/17.
IG: grcwicks
Old 01-30-2021, 07:28 PM   #22
Satanasso
Satanasso's Avatar
Drives: Subaru BRZ - Satin White Pearl
Send a message via MSN to Satanasso
sorry for the dumb question, but has the splitter some upgrades for 13 BRZ ?
i like the way it "blocks" the air above the splitter
Satanasso is offline   Reply With Quote
Old 01-30-2021, 08:24 PM   #23
Copy
Copy's Avatar
Not a dumb question. That's the Verus splitter air dam.
IG: grcwicks
Satanasso (01-31-2021)
Old 04-09-2021, 01:09 AM   #24
Copy
Copy's Avatar
Installed my brembos with DBA rotors and Ferodo brake pads. I'll get better pictures later.
IG: grcwicks
KMA KiCKz (04-09-2021)
Old 04-10-2021, 03:00 PM   #25
warhawk03
Drives: 2018 BRZ
Looks good! Are those the Brembo GT kit or did you get the OEM PP Brembos?
warhawk03 is offline   Reply With Quote
Old 04-10-2021, 11:11 PM   #26
Copy
Copy's Avatar
Thanks! They're the OEM PP Brembos.
IG: grcwicks
Old 04-11-2021, 12:28 AM   #27
jflogerzi
jflogerzi's Avatar
You car is so clean my friend. Well Done. You thread convinced me to finally pull the trigger on the dive planes and the air-dam add-on for my splitter
2013 Series 10 FRS #553
Old 04-11-2021, 12:32 AM   #28
Copy
Copy's Avatar
Installed some MICIEI interior pieces for the tachometer and climate control.
IG: grcwicks
New copy key phongtphan21 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 05-22-2016 04:04 AM
2014 Navigation Maps SD Copy torqueno BRZ First-Gen (2012+) — General Topics 14 11-18-2014 09:54 AM
Five axis copy Hawk77FT Cosmetic Modification (Interior/Exterior/Lighting) 3 10-12-2014 09:46 AM
New asian copy curved intake pipes Wayno Engine, Exhaust, Transmission 6 09-22-2014 03:29 AM
