Old 11-25-2016, 06:20 PM   #1
Teseo
Drives: frs
Whiteline springs
Thoughts?
http://www.whiteline.com.au/product_...UB006&sq=22282
Old 11-25-2016, 07:35 PM   #2
Racecomp Engineering
Since they don't publish spring rates all I can say is: ¯\_(ツ)_/¯
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (11-26-2016), Clipdat (11-25-2016), Spankopotomous (12-14-2020)
Old 10-19-2020, 04:37 AM   #3
Enigmeerkat
Enigmeerkat
Enigmeerkat's Avatar
Drives: 2015 Toyota 86 GTS
Thread revival. Just bought a set of these (kit includes the sways), anyone have any experience?
2015 Toyota 86 GTS
- Ecutek w/ Flex Fuel, Xtreme Stage 1 Organic Clutch
- PSR UEL Header, Invidia R400 Catback
- Whiteline Swaybars, 18" ROH Blue Evo R
Enigmeerkat is offline   Reply With Quote
Old 10-20-2020, 10:38 PM   #4
norcalpb
norcalpb's Avatar
Excited to have you tell us.
The Following User Says Thank You to norcalpb For This Useful Post:
JohnJuan (10-22-2020)
Old 12-11-2020, 02:00 PM   #5
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
So uhhh... Hows it going, or should I ask How are they going?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 12-13-2020, 07:22 PM   #6
Enigmeerkat
Enigmeerkat
Love the look, and love the lower centre of gravity for handling, gotta be a bit more careful with potholes (etc.) than before.
However they've exposed an issue in the struts where now they are leaking, and knocking, and need to be replaced. Basically at this stage I am weighing up cost of getting some new/used struts to replace the existing ones, vs. moving to coilovers.
2015 Toyota 86 GTS
Old 12-13-2020, 11:44 PM   #7
jflogerzi
jflogerzi's Avatar
If you can find a nice low mileage take offs then its worth it. If not get a of Bilstein dampers unless you really need camber or adjustability. Tien Flex A's is what I would get for a solid cheap coilover.
2013 Series 10 FRS #553
Old 12-14-2020, 03:37 AM   #8
LancePower
Drives: 2020 BRZ tS
I saw Springs Rates on their website.
LancePower is offline   Reply With Quote
Old 12-26-2020, 03:11 PM   #9
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Whiteline Springs deliver improved vehicle performance whilst maintaining safety and ride quality characteristics. This kit contains 3.0kg/mm (168lb/in) front rated springs that provide a 25mm drop while the 4.1kg/mm (229lb/in) rated rears deliver a desirable 25mm to the vehicle.
Copied from the whiteline site.
Thefalls is offline   Reply With Quote
| Exxel Distributions | Whiteline Lowering Springs Special!!! ExxelDistributions Brakes, Suspension, Chassis 31 01-05-2017 07:45 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
SOLD: Whiteline Rear Lower Control Arms + RCE Yellow Springs septiq Brakes, Suspension, Chassis 3 11-01-2015 12:07 PM
***MEGA THREAD*** Tein & Eibach Springs | Cusco | KW | Whiteline | DBA | Stoptech | FT-86 SpeedFactory Brakes, Suspension, Chassis 59 11-07-2012 09:10 PM
