View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-25-2012, 09:47 PM   #477
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
Su003-00328
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 07-25-2012, 10:01 PM   #478
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Lol that pump is 1000-1300 bucks (<3 warranty)...if they are replacing with the same as the old....the problem is just going to come back in a couple hundred miles....
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
csaba (07-25-2012)
Old 07-25-2012, 10:04 PM   #479
OrbitalEllipses
Drives: Attitude
They will keep replacing it under your insistence until there's a TSB or it's out of warranty, in which case you sell the car if there's no aftermarket HPFP that remedies the problem and is affordable.
Old 07-25-2012, 10:06 PM   #480
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
I suppose I could go in and give them a couple hours of my time every two weeks or so
Old 07-25-2012, 10:13 PM   #481
csaba
Drives: scion tc
It was a few posts up man...
Than that's not a fix !!
csaba is offline   Reply With Quote
Old 07-25-2012, 11:42 PM   #482
Marrk
Drives: Honda Fit
Why don't you think that through one more time, son. Would you do this if you were Toyota-Subaru?
Marrk is offline   Reply With Quote
Old 07-26-2012, 12:34 AM   #483
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
When i took my car in about the drl tsb the new ecu pn was the same as the old pn according to their head tech. I thought that was odd, but oh well.
Hawaiian is offline   Reply With Quote
Old 07-26-2012, 01:11 AM   #484
Thunderchicken
Drives: 2008 STi
Most companies keep the same part number but a revision number is changed to denote the change. i.e. old p/n 123-4567 rev(-) new p/n 123-4567 rev(a).. The rev(a) shows that the part has been changed from original when it was 1st released.
The only time a p/n change is required is when you have a major change occur like: a change in a micro-controller, FPGA, new circuit board design basically a physical change.
With the DRL change it could be a firmware change that can only be done at the factory so the easy fix is to swap ECU's and report the cars s/n that it has a the updated part.
Thunderchicken is offline   Reply With Quote
Old 07-26-2012, 01:21 AM   #485
ahausheer
Re-member
Drives: Toyota camry
If the car did not do this during the test drive, and there was nothing in writing or verbally disused do we have a legal right to return the car? Do we have any lawyers on here?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-26-2012, 01:39 AM   #486
Thunderchicken
Drives: 2008 STi
The only recourse is to write, or call Toyota and tell them to correct the issue or have them issue a statement stating that this is normal operation.
Old 07-26-2012, 02:15 AM   #487
dabocx
dabocx's Avatar
Drives: Scion FRS
Mine started today for a few moments and then went away. Im hoping if i have to take it in to get checked out later on the dealer doesnt claim my aftermarket parts caused it.
dabocx is offline   Reply With Quote
Old 07-26-2012, 12:38 PM   #488
Brimford
Drives: Whiteout / MT FR-S
Just a heads up, I took my car in today to get the oil changed, and I mentioned the cricket. They came back after looking at it and did confirm with me that it was the fuel pump (without me mentioning it beforehand) and that toyota is aware but has not taken an action yet. So there we go, straight from the reps mouth and makes me feel a little bit better. Everyone take your cars in for sure if you haven't and mention the issue, the more complaints the better! Im sure they wont want bad PR after all the fiasco they had years ago.
Brimford is offline   Reply With Quote
The Following User Says Thank You to Brimford For This Useful Post:
Marrk (07-26-2012)
Old 07-26-2012, 01:18 PM   #489
OrbitalEllipses
Drives: Attitude
What's the problem, pops? It's not functioning as it should. You bug them to replace it under warranty a few times a year and they better do it. They will do it until there's a TSB for the part with a revised part or until the warranty's over. You're SOL when the warranty's over if this isn't fixed by then, hence the suggestion to sell.
Anything else I should explain, gramps? It's the nature of the car game. BMW replaced HPFPs without changing the part number and continued to do so for the rest of the warranty. It cost them less in the long run than making a revision.
Tomzilla (07-27-2012)
Old 07-26-2012, 01:32 PM   #490
FRSjeff
Drives: FR-S (red manual)
Wouldn't the lemon law then come into play in the above scenario?
FRSjeff is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
