Old 12-09-2020, 10:11 AM   #1
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
Drivers Side DRL flickered then turned off
So i have been building my Frs for a little over a year. I bought it used, with low mileage. I am happy with it, i have not done anything electrical, or jumped into power adders just yet. I have focused on cooling system, braking upgrades, and fine tunning handling. I have noticed two problems which i was going to address once i started the cosmetic portion of the build, minus of course any maintenance.
1) i noticed from when i purchased the car, the foglights do not work. Everything is installed, even the push button just does not work, and it caused my passenger side turn signal to blink rapidly.
2) The reason for this post, my drivers side DRL flickered the other day at a stop light. Once i accelerated, nothing hard it turned back on. Today, it is completely dead.
I have searched for a solution, even if there is a bulb but nothing. Is it a resistor? A bulb? Electrical? I need some help. I appreciate you all, and your time
Fa20Toybaru is offline   Reply With Quote
Old 12-09-2020, 02:20 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It's impossible to say with certainty without knowing how the previous owner wired up the car.
With regard to the DRL, the easiest thing to do is pull the bulb and make sure it's not burnt out.
Other than that, you'll need to look under the hood and/or pull the bumper off to trace the wiring for the fog lights.
EndlessAzure is offline   Reply With Quote
Old 12-09-2020, 11:26 PM   #3
Fa20Toybaru
FA20ToyBaru
Drives: Manual
I appreciate the information. I figured, i would have to trace or re-wire the fog lights. As for the DRL if it is as simple as changing a bulb ill start the diagnostic there, and work my way through.
Old 12-10-2020, 07:08 AM   #4
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Sounds like the bulbs are already dying out especially if they are halogens. Try to buy a set of 9005 halogen bulbs for your high/drl first. Unfortunately, you can't use LED for high/drl as that's a reflector portion of the assembly & it's illegal to use LED for reflectors in North Am.
I'm not sure what bulbs your fog light uses. If a new set of bulbs doesn't work, you may want to consider upgrading to LED's or upgrade the entire system entirely like Diode Dynamics SS3 (8yrs warranty). They also have the cheaper Luxeon LED fog light assembly with 3 yrs warranty. Check the fuses too. If you decide to stay halogen & the wires are the problem, you'll have to get a new foglight relay wiring kit. Diode Dynamics has this https://www.diodedynamics.com/foglig...iring-kit.html. It's tapped on the low beams so that when the low beams are on, the fogs turn on as well.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Drivers Side DRL flickered then turned off Fa20Toybaru Issues | Warranty | Recalls / TSB 0 12-09-2020 10:11 AM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 04:53 PM
OEM DRIVERS SIDE TAIL ZaneRL9 Exterior Parts (Aero, Lighting, Etc.) 10 11-24-2014 09:30 AM
WTB: drivers side door TAKS 86 Want-To-Buy Requests 1 07-14-2014 11:30 AM
