Old 11-07-2020, 11:44 PM   #1583
Originally Posted by gravitylover View Post
How big is this motor? Would it fit inside a typical full sized SUV? I think I found one finally and need to go get it.
Easily
Old 11-08-2020, 09:56 AM   #1584
gravitylover
Easily
Thanks. Looks like I'm taking a ride to the Chicago area this week.
Hmm, what does it weigh?
Old 11-08-2020, 09:59 AM   #1585
Depends on how stripped down. Between about 350 and 380 pounds.
Old 11-08-2020, 10:01 AM   #1586
gravitylover
Not too bad at all. I can make this happen. Hopefully be driving it again by the end of the month if this comes together.
The Following User Says Thank You to gravitylover For This Useful Post:
Ultramaroon (11-09-2020)
Old 11-17-2020, 06:33 AM   #1587
DoubleV
Drives: 2013 Toyota GT86
If Subaru/Toyota were a proper car manufacturer, the valve spring recall would include the complete timing kit and the VVT sprocket replacement.
In my country some cars are returning to Toyota due to high clearance on the valve shimmings because Toyota doesn't adjust the shimmings to the right spec after replacing the valve springs.
The result is a high metallic noise like valve tapping. I guess the recall procedure doesn't include it, so they don't measure it
DoubleV is offline   Reply With Quote
Old 12-04-2020, 04:19 PM   #1588
gravitylover
That last one didn't happen for a few reasons but one just popped up close to home that isn't hammered or unnecessarily expensive. I know there's a difference between manual and auto blocks, can I use a '16 (11/15 build) auto motor in my '13 manual car? What modifications need to be made?
Old 12-05-2020, 12:54 PM   #1589
gravitylover
Answer took too long and the motor is already sold
I should know for the future though, can an auto motor be used easily in a manual car? It looks like the biggest issue is they use different oil pans and camshaft cover so are these parts interchangeable from my old motor?
Old 12-05-2020, 07:29 PM   #1590
daniloneil8
What is the latest status on the valve spring recall?
Are people still doing it? Or did everyone who is gonna do it, already do it?
I never did the recall. I doubt I will bother at this point.
Who else decided to skip the recall ?
daniloneil8 is offline   Reply With Quote
The Following 2 Users Say Thank You to daniloneil8 For This Useful Post:
humfrz (12-06-2020), Opie (12-08-2020)
Old 12-05-2020, 08:24 PM   #1591
Yes, interchangeable, however, understand that we are not talking about that bottom steel pan. On this engine, that is the "lower" oil pan. The "upper" oil pan is a key component of the actual block. It's also the part of the engine that has the studs which fit into the transmission bell housing.
gravitylover (12-06-2020)
Old 12-06-2020, 04:59 AM   #1592
I've skipped the recall.
If it ain't broke ........
alxtheoreo (12-06-2020), Opie (12-08-2020)
Old 12-06-2020, 03:18 PM   #1593
gravitylover
Safe assumption new gaskets or sealant are needed?
Old 12-06-2020, 03:35 PM   #1594
dat gloo doe
Old 12-08-2020, 08:25 AM   #1595
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If Subaru/Toyota techs would follow the specified recall procedure you wouldn't have those issues as the recall precedure clearly tells them to measure and shim as needed;
7) Measure and record the cam clearances following the procedure in the applicable Service Manual.
Bulletin Number: WTY-84R; Revised: 05/06/20 Page 8 of 42
Continued...
IMPORTANT NOTES: The purpose for performing these cam clearance measurements is to
compare the “before” and “after” values and confirm there was no change.
If the clearances are out of specification, obtain the required shims for installation prior to
reassembly.
• If the clearances are all within specification at this point but after reassembly, some are
found to be out of specification, it is likely some of the shims were miss-positioned during
reassembly. CAREFULLY Re-adjust as necessary to insure all clearances are within the
following specifications:
Standard values (cold engine):
○ INTAKE: 0.10 to 0.16 mm {0.0039 to 0.0063 in.}
○ EXHAUST: 0.21 to 0.27 mm {0.0083 to 0.0106 in.}
8) CAREFULLY remove the timing chain cover, timing chain and all related components following
the existing procedures in the applicable Service Manual.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
Dadhawk (12-08-2020), Ganthrithor (12-23-2020), Ultramaroon (12-08-2020)
Old 12-09-2020, 09:20 PM   #1596
cnk
Drives: '13 DGM BRZ Limited
I skipped it.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
