Old 12-03-2020, 10:30 AM   #1
Anar1988
Misfire problem
Good afternoon
I would like to tell you about my 2018 Subaru BRZ car, 10.600 mile
which I bought at an auction in 2020 in disrepair (Damaged from the back side) and brought it to Azerbaijan ... see photos
Tuned car (Delicious tuning):
Jackson racing supercharger
Flex fuel kit
JDL auto design
Borla exhaust
when I started to drive the car after the repair, I felt a strange smell from the muffler and the car began to choke at 2500-4000 rpm. Computer diagnostics showed problems with 1 cylinder, when I pressed the gas pedal, an error appeared in 4 cylinders. We looked at the injectors and the reel, changed the spark plugs (the old ones had a black coating, which is not normal).
I turned to Delicious Tuning who advised me to change the firmware. When I bought my car, there was no flashing device. Can I use my friend's device from GT-86 or should I buy a new one?
Anar1988 is offline   Reply With Quote
Old 12-03-2020, 10:48 AM   #2
Anar1988
Picture with number 4 is a question of our master. He ask that in blue line petrol impedance why so high? the tuning company did it?
Old 12-03-2020, 11:26 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Please take no offense, but if you were to change your diagnostic program's language setting to English, we may be better able to help you.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 12-03-2020, 12:50 PM   #4
Anar1988
next time I will tell the master. to change the language to English
Old 12-04-2020, 12:13 PM   #5
Anar1988
As far as i know this lamp on top cover should work when i start the engine.. in my case it is not.
Please advise is it ok ?.. if not what is the way forward to fix?
Old 12-09-2020, 10:59 AM   #6
Grady
Grady's Avatar
If it is not flashing it is not ok. Have you gotten the App on your phone to see if it will connect? You can get a replacement from Delicious Tuning, or if possibly fix yourself if you or someone you know is great at electronics. Those boxes are not designed well. You have to keep them completely dry or water will get in and damage them.
Old 12-09-2020, 03:16 PM   #7
Anar1988
after that the master opened the box, saw that several parts were blown
can this board be repaired? or replace it?
chip name : T2721
Old 12-09-2020, 03:21 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'd buy a new one. This device is connected to the system controlling your fueling, I would not take any half measures.
Old 12-09-2020, 04:01 PM   #9
Grady
Grady's Avatar
chip name : T2721
Yep water intrusion. Yes it can be repaired, however the technical data and ability to test it is not accessible. Better off getting another one.
Old 12-10-2020, 01:12 AM   #10
Anar1988
Good afternoon. this car transported to Azerbaijan Republic. Note: In Azerbaijan not E85 gasoline only 91 octane gasoline.
Could you please advise required buy D- box or cancel my car .
During cancel D-box required firmware? Or required firmware please advise where can I have?
Note. In my car install Jackson racing super charger.
Old 12-10-2020, 06:23 PM   #11
steve99
Drives: FT86
If your only going to run petrol\gasoline and not E85 then you dont need the Dbox or the flex fuel kit. However you will need to alter the tune so its not looking for input from the flex fuel kit and jist get a petrol only tune.
Old 12-14-2020, 11:35 AM   #12
Anar1988
Thanks for the help.
I sent this board to delicius tuning.
They will repair
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Misfire Jono AFRICA 49 12-12-2012 06:01 AM
