Old 12-02-2020, 11:15 PM   #29
Originally Posted by TommyW View Post
Good ol Calif. for how beautiful it can be it can totally suck.
There's plenty parts of the US (and the world) that are just as beautiful, without the sucky bits.
Tcoat (12-03-2020), Ultramaroon (12-03-2020)
Old 12-02-2020, 11:37 PM   #30
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
My engine was subject to the recall. I'm currently at 180k on original valve springs and have had no issues. I'd rather run the risk of it maybe happening versus having some 9-5'er open up my engine.
B-R-Z is offline   Reply With Quote
Old 12-03-2020, 01:24 PM   #31
dodj
Drives: Rallye Blue BRZ
IMO, changing valve springs can be done almost anyone. It's not a hard job. Hard to screw up, but not hard to do right.
Had my recall done and they threw in a new serpentine belt and changed the plugs free of charge
dodj is offline   Reply With Quote
The Following User Says Thank You to dodj For This Useful Post:
Tcoat (12-03-2020)
Old 12-03-2020, 03:20 PM   #32
Haha... no. It's a MAJOR undertaking requiring careful attention to many many details along the way. It's very easy to screw up.
DarkSunrise (12-03-2020), TommyW (12-03-2020)
Old 12-03-2020, 04:11 PM   #33
Any second year apprentice with half his wit about him could do it. There are techs that do far more complicated work every single day without screwing up. The sad part is they didn't even screw up the harder parts. It was the simple thing that they probably didn't even bother to check the special instructions that they messed up.
dodj (12-04-2020)
Old 12-03-2020, 05:03 PM   #34
This engine is particularly unforgiving of those who don't follow the exercise to the letter. I will say again, in a well qualified criticism of my service industry peers, there are many among us who do not respect the basics.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
DAEMANO (12-04-2020), dodj (12-04-2020), RToyo86 (12-04-2020), Tcoat (12-03-2020)
Old 12-04-2020, 11:01 AM   #35
dodj
Following the exercise to the letter is the same for any multi part mechanical device. Leave a part or step out and it aint gonna work right.
Looking at a BRZ head.....I'm not a mechanic, but looks pretty standard as far as springs? Ya know, remove cams, remove springs/retainers, install new ones. reinstall cams in same spot. Time them. Close it up and start.
Other than being horizontal, whats majorly different from any other ohc engine?
The Following 2 Users Say Thank You to dodj For This Useful Post:
Tcoat (12-04-2020), Ultramaroon (12-04-2020)
Old 12-04-2020, 11:46 AM   #36
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Timing cover on the front and all the timing valves on the cams are exposed.
Scrape all the sealing goo into the oil passages and sump then spooge new goo all over everything.
That's pretty non standard opposed to popping off the valve cover.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Ultramaroon (12-04-2020), x808drifter (12-04-2020)
Old 12-04-2020, 12:08 PM   #37
TommyW
TommyW's Avatar
Drives: '13 Whiteout
The weak link in the process is the timing chain cover sealant both in removal of old and application of new. ANY excess whether from scraping off the old or the new application that gets into the engine can and will clog oil ports. This is a ticking time bomb especially for those that see track time.
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
DAEMANO (12-04-2020), Ultramaroon (12-04-2020)
Old 12-04-2020, 12:33 PM   #38
Other engines aren't glued together. There are many places where improper surface prep, and adhesive application will cause catastrophic failure from blocked oil galleries. There are also places where o-rings under pressure will blow out because they weren't inserted carefully. Most commonly, carelessly removed old sealant makes its way back to the pan and ends up clogging the oil pickup screen.
This is a unique engine. I love it, but it requires special care.
edit: yeah... what bcj and Tommy said.
Old 12-04-2020, 01:17 PM   #39
LOL something that I was told many times was IMPOSSIBLE prior to the recall failures. There were at least 20 reported failures in 13s straight from the factory that all pointed to this. Robots screw up too!
I still maintain my stand that any half competent person can do this repair. It wasn't a matter of skill that caused issues it was a simple failure to follow instructions and take the proper care.
Dadhawk (12-04-2020), dodj (12-04-2020)
Old 12-04-2020, 01:29 PM   #40
Like I've said a million times, you can't pay people to give a shit. That's precisely why I never roll the dice with things I hold dearly. Hell, now that I think of it, you've seen how I suffer playing slots! It all fits.
edit: something else I just considered... Given the choice, I'd gladly pay a certified A&P mechanic with zero experience on this engine than I would any dealer shop. This shit rarely happens with aircraft, and heads roll when it does. If we were truly concerned about safety over litigation, that's how we would treat automotive service.
bcj (12-04-2020), Tcoat (12-04-2020)
Old 12-04-2020, 02:04 PM   #41
Old 12-04-2020, 04:29 PM   #42
dodj
Quite a few are. Not just car engines either.... for decades.
I haven't done the job on this engine (I've 'glued' together other engines though) and I can't say I think doing a good job removing the old sealant and applying a proper amount on reassembly constitutes a 'difficult' repair.
I respect your opinion, but,
I think I will go with the 'agree to disagree' on this.
Dadhawk (12-04-2020), Tcoat (12-04-2020)
JO2 RECALL - ENGINE FAILURE David242gt AUSTRALIA 44 07-01-2020 03:50 AM
Engine Recall work Riftur Southeast 7 06-09-2020 09:40 PM
Catastrophic Engine Failure After Recall Work? MJones_RB Issues | Warranty | Recalls / TSB 20 06-09-2019 09:54 PM
(Boosted) Blown Motor Advice - AFTER RECALL pbirmingham1988 Forced Induction 27 05-07-2019 01:34 PM
valve spring recall-engine oil leak TYinhouse Issues | Warranty | Recalls / TSB 13 01-17-2019 11:09 AM
