Drives: '13 BRZ Limited
Valve spring issues - Not in recall
Hey all,
I have a 2013 BRZ that has a VIN and production date outside of the recall, but I just experienced the valve spring failure. It is currently in my local mechanics shop with no compression in cylinder 4, stalling, dead. Can't drive, just loud angry noises if I try to start it. My local dealerships have told me there is nothing they can do, my car is not part of the recall, it doesn't have the valve spring issue, etc. My car was produced in 6/13, and they claim the issue starts with cars in 7/13. Ridiculous. Anyone have any experience with this, a contact who can help me? Advice? Feel like I am fighting an uphill battle and getting stonewalled on every corner. |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
Contact Subaru Corporate.
#3 |
#4 |
LMGTFY
Who knows.
Car is off the supposed coverage area by a single month. I'd call that a reason to suspect you may have also had the bad springs. You only really have 2 choices. Make a big stink about it and try to get it fixed by Subaru. Or suck it up and pay out of pocket. How far you go with option 1 is up to you. |
#5 | |
You can check out all the documentation here. Also, use your VIN and check to see if it was part of the recall.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | jeconti (11-30-2020), x808drifter (12-01-2020) |
#6 | |
My VIN in the VIN check tool shows not part of this recall. My VIN is JF1ZCAC16D1611651. Even the link you provided does not show my car as having an associated recall. The only recall it showed and I repaired was the fuel pump chirp. |
#7 | |
If you bought the car used, it's possible the recall was already performed on it if it was eligible. The site I sent only shows incomplete recalls. My car no longer shows when I check it because I had the recall completed.
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (11-30-2020) |
#8 |
Have they actually pulled it apart and checked to see if it is a spring? The compression test could mean a few things not just a spring.
If it did have the recall done it may have spun a bearing. If it isn't covered by recall then the warranty is well over. You will need to talk to Subaru to determine if the recall was done for sure.
#9 | |
#10 |
If you are certain it hasn't had the recall done (which obviously you would be) and it doesn't show as effected by it, even if it is the Valve spring, you may be out of luck.
#11 | |
If it is a spring then let them know. Probably will do you no good but worth a shot. If it isn't a spring well, you are on your own. It is a 7 year old car and they will not goodwill repair it.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (11-30-2020) |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
