Old 11-28-2020, 06:35 PM   #22597
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Grady View Post
Also looks like the light is pointing straight up?
no, it's facing back and down slightly. if you look down the center, you can see the 5mm led's horizontal with the circuit board connecting facing vertical.
Old 11-29-2020, 06:18 PM   #22598
Kaotic Lazagna
Drives: GR Corolla
Tried out my QuickJack.
The Following 4 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Bonburner (11-29-2020), new2subaru (11-29-2020), Tcoat (11-29-2020), Ultramaroon (11-30-2020)
Old 11-29-2020, 07:17 PM   #22599
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Continued the great Dynamat experiment this weekend, getting the back seat area done. Next up will be yanking out the front seats/console/carpet to do the rest of the floor. Gotta say I'm pretty happy with the results so far, considering I've only added about 3.6lb to the car. Might get away with skipping MLV altogether.
Cephas is offline   Reply With Quote
The Following 3 Users Say Thank You to Cephas For This Useful Post:
Bonburner (11-29-2020), Kaotic Lazagna (11-29-2020), Tcoat (11-29-2020)
Old 11-29-2020, 07:17 PM   #22600
soundman98
soundman98's Avatar
^it looks weird to see someone actually use sound dampening as it should be used instead of slathering every panel with full sheets of the stuff
nice to see someone with a backup plan!
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Dave-ROR (11-29-2020), Kaotic Lazagna (11-29-2020), Tcoat (11-29-2020)
Old 11-29-2020, 07:41 PM   #22601
Kaotic Lazagna
Drives: GR Corolla
Can never be too safe. I put a pair of stands under the front too after I snapped the pic.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
soundman98 (11-29-2020)
Old 11-29-2020, 07:49 PM   #22602
q335r49
Drives: 2013 scion fr-s
Yep, believe it or not, I correctly installed a part that wasn't specifically designed and manufactured for my exact car and it didn't explode
q335r49 is offline   Reply With Quote
Old 11-29-2020, 07:54 PM   #22603
q335r49
Originally Posted by Overdrive View Post
I don't think he was trying to be rude, just making an observation...
I don't think I was trying to be rude either, just trying to thank him for improving the dialogue with his keen observation
Old 11-29-2020, 08:03 PM   #22604
soundman98
soundman98's Avatar
i installed the cdc mustang brake light in that location.. by all merits, it should make me more prone to sideswiping crowds. since installing it, 1st-2nd gear change has resulted in more pendulum effect leaving cars and coffee.
Tcoat (11-29-2020)
Old 11-29-2020, 08:18 PM   #22605
Cephas
Cephas's Avatar
Oh also, TIL that there's a timer on your dome light to save your battery. But there is no such timer on the little light in the trunk, which will drain your battery dead over the course of a weekend. Whoops.
The Following 2 Users Say Thank You to Cephas For This Useful Post:
Myriad (12-06-2020), soundman98 (11-29-2020)
Old 11-29-2020, 09:22 PM   #22606
saltywetman
Drives: 2020 Toyota 86 GT 6M
where are the jackstands supporting on rear and front? i've only ever used the pinch welds but would be good to know of other jack points besides the central front and rear area
saltywetman is offline   Reply With Quote
Old 11-29-2020, 11:55 PM   #22607
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't even remember when my set were that clean!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Kaotic Lazagna (11-30-2020), Tcoat (11-30-2020)
Old 11-30-2020, 12:41 AM   #22608
soundman98
soundman98's Avatar
You can use the suspension mounting points. If it holds up the car in a turn, it'll hold up on a jackstand!
Kaotic Lazagna (11-30-2020), saltywetman (12-01-2020), Tcoat (11-30-2020)
Old 11-30-2020, 01:06 AM   #22609
Kaotic Lazagna
Drives: GR Corolla
I placed the stands under the rear LCA, and under the front subframe. They actually aren't touching the car tho, and are there for "just in case" reasons. All four of my stands don't go as high as the QuickJack itself.
Haha. That just means you got your money's worth and then some out of them.
soundman98 (11-30-2020)
Old 11-30-2020, 09:05 AM   #22610
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Ordered an OFT and bought a used gruppe-s header from a friend.
Going back to a stock catback and will be selling my Corsa setup once I uninstall it.
