Old 11-25-2020, 12:26 PM   #73851
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
More than likely if its a desktop monitor in a corporate setting its 1920x1080.
If you go into Display Settings (right-click on wallpaper and select "Display Settings)", it will usually be the "Recommended" setting under Display Resolution.
This is where you would also check the scaling. There is an option there for "Advanced Scaling Settings", check that and if it's not set to "Let Windows try to fix apps so they're not blurry" turn that on.
It's Canada, they just have a little bit less of everything up there.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Ultramaroon (11-25-2020)
Old 11-25-2020, 12:32 PM   #73852
OK I had already tried those. Thought you meant something else.
Normally have no issues fixing stuff like this but this one has me baffled. I would call our IT guy but he will just sit in his office and tell me to put in a ticket then I will spend 4 hours on the phone with some guy in Lower Slovobia that I can hardly understand just for them to give up and tell me to use the local IT guy who will then say I can book an appointment for next March because he is too busy on a corporate project that will mess up yet another aspect at the local level and I will get to start all over again.
Tcoat is offline
Old 11-25-2020, 12:36 PM   #73853
Try holding down "ctrl" and hitting "+"
(maybe your eyes are failing because you're getting old - )
[QUOTE=Tcoat;3387624]1680X1050. As high as it goes.
Zoom just gives me bigger or smaller weird font with white spaces in the letters and stacked pixels in the round parts.
QUOTE]
I TRIED THAT IT DIDN'T HELP
It isn't that my fonts is small it is the same size as before it is all just broken up and made of individual visible pixels. The samples I showed don't look as bad as it really is.
Tcoat is offline
humfrz (11-25-2020)
Old 11-25-2020, 12:42 PM   #73854
display scaling plays hell with our Eclipse-based apps. Maybe Tcoat should try the "clear type" adjustment that I hate.
I keep it turned off because I prefer the skinny crisp text.
Oh I don't like that either. I want my skinny text as well but I want it crisp not all broken up.
Tcoat is offline
Old 11-25-2020, 12:56 PM   #73855
OK I had already tried those. Thought you meant something else. .
I'll check with my guys here to see if they have run into this anywhere. Last two things I know to try, but you may have already:
1. Press Windows logo key + R to launch RUN dialog box. Now type sysdm.cpl and press Enter.
2. Go to Advanced tab and click on Settings button under Performance section.
3. Put a check on "Smooth edges of screen fonts" (or try it the other way)
4. Apply the changes
Here's my font settings that seem to work perfectly. Note the URL at the top that will take you directly to them. I know you said you played with the settings, but check the actual fonts being used.
Dadhawk is offline
soundman98 (11-25-2020), Spuds (11-25-2020), Ultramaroon (11-25-2020)
Old 11-25-2020, 01:04 PM   #73856
I will try that when I get a few minutes. My settings are the same as yours pictured except that I have Arial for them all.
Tcoat is offline
Old 11-25-2020, 01:22 PM   #73857
[QUOTE=Tcoat;3387645]
QUOTE]
OKaaaaaaaaaa
humfrz is offline
Old 11-25-2020, 01:28 PM   #73858
That may be it. Arial isn't a Serif font so it could be messing it up. The site here uses san-sarif fonts though so not sure.
Dadhawk is offline
Old 11-25-2020, 01:35 PM   #73859
Ultramaroon is offline
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
NoHaveMSG (11-25-2020), soundman98 (11-25-2020), Spuds (11-25-2020), Tcoat (11-25-2020)
Old 11-25-2020, 01:36 PM   #73860
Spuds
The Dictater
Spuds's Avatar
FYI, this is the fix for aliasing that I was talking about.
Spuds is offline
Dadhawk (11-25-2020)
Old 11-25-2020, 01:56 PM   #73861
p1l0t
p1l0t's Avatar
Are you guys seriously nerding out on fonts? I nerd out on some dumb shit but fonts? Really guys?
p1l0t is offline
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
NoHaveMSG (11-25-2020), Spuds (11-25-2020)
Old 11-25-2020, 01:57 PM   #73862
Fonts pay my bills, Dude.
Dadhawk is offline
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
p1l0t (11-25-2020), soundman98 (11-25-2020), Spuds (11-25-2020), Ultramaroon (11-25-2020)
Old 11-25-2020, 02:03 PM   #73863
p1l0t
p1l0t's Avatar
I mean I program computers when I'm not flying... so I get it. Just surprised to see intrest on FT86
p1l0t is offline
Old 11-25-2020, 02:11 PM   #73864
Well, we can't have @Tcoat not able to read the forum. The per diem post count couldn't take the loss.
Dadhawk is offline
NoHaveMSG (11-25-2020), p1l0t (11-25-2020), soundman98 (11-25-2020), Spuds (11-25-2020)
