| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
| View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest | |||
| 1 |
19 | 7.20% |
| 2 |
25 | 9.47% |
| 3 |
62 | 23.48% |
| 4 |
104 | 39.39% |
| 5 |
54 | 20.45% |
| Voters: 264. You may not vote on this poll | |||
#729 |
Drives: 86 (sold), 370Z
If for no other reason, the Toyota is probably the one to go for because it is most likely to have a much cleaner front nose design from what we can make out on the test mules. I had hoped the BRZ nose would grow on me, but I think it is looking worse the more I look at it.
#730 |
Yes, the earlier pics of the test mules clearly show functional vents around the front wheels. You can literally see the air channels in the wheel well.
![]() ![]() How much actual aero benefit they provide I'll leave up to your judgement. Last edited by Red-86; 11-22-2020 at 11:01 PM. |
#731 |
The Dictater
Drives: '13 Red Scion FRS
I think the front looks fine. Looking at the fender, door and skirt area is killing me though. It's like they took a smooth curvy design and decided it needed some jarring angles and lines that don't match up with anything else.
Maybe it will look better in person, with a more top-down perspective rather than low shots everyone seems to want to take. I am hoping it does, because I like how the specifications turned out. Like, I would be ok with it if they could show me legit wind tunnel and cfd data proving they chose function over form, but the form is just a bit disjointed as it is now. Hell, I might be ok with it anyway if it is a blast to drive. |
#732 |
Drives: RX-7 / BRZ
Did they ever claim the body was an improvement in aero?
They mentioned more torsional rigidity and a lower center of gravity. While body lines do add strength to metal panels, I'm guessing it has more to do with the new aluminum panel construction and some clever chassis reinforcement. Lower center of gravity could also be the aluminum parts and the engine weighing a bit more shifting it lower.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#733 |
Pavement Grey
#734 | ||
The Dictater
#735 |
#736 | |
They added front cold air ducts, rear hot air vents and out of the goodness of their hearts threw in a stock oil cooler. Now, we know there were heat issues on the track with the first gen. This is indisputable from the number of people that had to resolve it. Now they put a larger displacement, higher compression engine in roughly the same space. This will create even more heat. If you were designing a car and had some serious heat issues how would you resolve them? I personally would bring in some cold air, vent the hot air and install an oil cooler. Now the very last thing that the marketing crew wants to do is say "yep we had a nasty heat issue but we fixed it". Doesn't " resulting in a low and wide frontal area set off by large functional air intakes" and " functional side vent reduces drag by ducting air from under the hood and fenders. The released air is directed to a side sill spoiler that creates downforce at speed." put a much more appealing spin on things? Now of course I can not prove any of this and that is why I present it as a hypothesis and not a theory but it makes so much sense.
#737 | |
The lower COG is interesting in that their whole statement is "even lower than the previous BRZ and on par with exotic hyper-cars". What does that mean? Is it 4 inches lower? One? 3/16? They claimed as low as hyper cars in the first gen so really without knowing how much they lowered it this is a meaningless statement. The use of the aluminum roof and fenders would certainly help. Depending on your interpretation of the marking claims it seems they placed the engine lower and that would help as well. There is some debate whether the .4" height reduction is through suspension drop or actual body height but either way that would lower COG as well. It was obviously a target of theirs though so I would think it is a significant reduction but the real data remains to be released.
#738 |
Drives: ‘16 4Runner, ‘19 Corolla HB
All-New 2022 Subaru BRZ Makes Global Debut
The logic they are using regarding the aero is sound. If you are moving air out of the engine bay, you don’t want it going under the car (ex: splitters make downforce by pushing air over the car rather than letting it roll under). The side sill keeps the air from rolling under the car as well. The negative space behind the vent likely creates a low pressure zone that helps pull air through the engine bay to increase that cooling efficiency.
Also, airflow around wheel wells is notoriously messy, so it is a good place to add small aides to clean things up a bit. We see this on the rear fenders. Sent from my iPhone using Tapatalk |
#739 | |
#740 | |
The Dictater
#741 | |
They are very clear with their statement on the vents "functional side vent reduces drag by ducting air from under the hood and fenders"
#742 |
Drives: '23 BRZ
I've never had oil or coolant temp problems with my '17 at the track, even on 95F days when my '11 2.9 Cayman would have coolant temp creep up and I'd have to back off after a few laps. Coolant and oil temps in the BRZ always stabilized. I've never had to back off or come in due to climbing temps.
| 2022 Subaru WRX Spy Shots via Car and Driver | R_E_L | Other Vehicles & General Automotive Discussions | 230 | 01-03-2023 01:23 PM |
| 2017 BRZ Hig Res - Courtesy Subaru Global Media | Trap63 | BRZ First-Gen (2012+) — General Topics | 10 | 07-11-2016 09:53 AM |
| Subaru global brz web page | Gaen | BRZ First-Gen (2012+) — General Topics | 4 | 06-15-2012 01:32 AM |
| Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) — General Topics | 39 | 03-24-2011 09:22 AM |
| FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 02:57 PM |
