Old 11-20-2020, 11:30 PM   #15
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
He was then a week free of issues and had no further starting nor electrical problems other than the fob.
At least he eventually went to step one.
We had a guy on here a few years ago that no matter what the issue was his answer was "your alternator is done you need a new one".
Trunk won't open = Alternator
Tires low on pressure = Alternator
Seat won't move = Alternator
Pretty sure he was in the alternator sales business!
I have no reason not to believe you about that guy selling alternators, and that may be true, but I'm in the troubleshooting and problem solving business, not the sales business. If you go back and re-read what I wrote to him in Post #8, I never told him that he needs to go out right away to replace his battery. I told him that AFTER he checks all his cables, and terminals and then AFTER a good load test of the battery and charging system, or try an overnight trickle charger, then go from there. If it led to that, then he MIGHT need to replace the battery. (I even capitalized the word "after" in that post as well, to make sure that I was being as clear as I could be.)
Replacing parts is the last thing to do AFTER a proper diagnosis. He also said that his battery failed the load test, but he didn't mention if he performed the proper battery maintenance before he had it tested....AND....he didn't say if he had his CHARGING SYSTEM tested at that same time.
Your comment today makes it look like it's MY fault and you're blaming ME that he replaced his automotive battery (whether it was necessary or not) BEFORE he replaced the battery in his transmitter, when clearly, that is NOT the case.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 11-21-2020, 09:50 AM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
methinks you're reading too much into tcoat.
he's about facts, not blame.
i'm also not entirely convinced that most automotive load testers in parts stores aren't biased towards battery failure, but that might be a better talk for a different time.
Old 11-21-2020, 01:07 PM   #17
Tokay444
Tl;dr
If you keep it close to your cell phone, it’ll chew through batteries.
Even with a full battery, it’ll struggle to transmit in close proximity to your phone.
Old 11-21-2020, 01:18 PM   #18
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I'm not reading into Tcoat, I'm reading into his comment and quoting me on mine. Because that's the way it came across.
He certainly has an opportunity to rebutt what I've said......
Old 11-21-2020, 01:26 PM   #19
JD001
JD001's Avatar
Drives: Subaru BRZ
I was trying to compute the above but my battery died!!
Old 11-21-2020, 01:29 PM   #20
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Hah!
Well make sure you find the root cause before you go out and replace it. (And you can quote me on that!)
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
JD001 (11-21-2020)
Tail lights not working, brake lights and turn signals are working Inter Electronics | Audio | NAV | Infotainment 10 09-15-2022 01:50 AM
My Keyless Entry Is Working Intermittently - HELP! crashonice10 Issues | Warranty | Recalls / TSB 20 07-08-2019 01:28 PM
'Brake' dashboard light comes on intermittently speedy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-27-2015 09:35 PM
OFT NOT WORKING HELP ME b1gb2olo Software Tuning 8 08-30-2014 01:27 PM
