Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest
1 19 7.20%
2 25 9.47%
3 62 23.48%
4 104 39.39%
5 54 20.45%
Voters: 264. You may not vote on this poll
Old 11-20-2020, 07:01 PM   #617
Originally Posted by black bnr32 View Post
So...what do we know about this new rear suspension?
It is supposedly a double wishbone but they called the current that as well and it is actually a wishbone and a double link.
Other than that not much.
Old 11-20-2020, 07:13 PM   #618
Ohio Enthusiast
Drives: 2018 BRZ
Wow, didn't know that. Googling for the 2013 BRZ press release gives this:
Suspension - Rear: Double wishbone, coil springs, stabilizer bar
Comparing the specs tables in the press releases side by side, they look nearly identical (minus the obvious changes).
Old 11-20-2020, 07:15 PM   #619
brillo
Drives: 2013 Firestorm FR-S
Originally Posted by Red-86 View Post
I’m referring to manual.
PDrive here have tested numerous manual twins downunder for 0-100kmh and always get mid-high 7s. And they don’t exactly exactly launch them with mechanical sympathy.
Examples:
2015 86:
7.4s
2017 86:
7.79s
2019 BRZ:
7.77s
Maybe Australia gets the Friday afternoon builds.
Isn’t this an issue of needing to shift to 3rd to hit 100kph? Another shift will cost you one sec for sure. I think the twins can just barely hit 60mph in two shifts right?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 11-20-2020, 07:34 PM   #620
About half way down
https://www.edmunds.com/car-reviews/...alkaround.html
Ohio Enthusiast (11-21-2020)
Old 11-20-2020, 08:18 PM   #621
the specs I've seen show the MT requires a shift to 3rd in 0-60, the AT can do it in 2nd, at least with the 2013. Not sure if that changed later as they tweaked things.
Spuds (11-20-2020)
Old 11-20-2020, 08:30 PM   #622
Never tried but I feel I could have pulled it off in the FRS. The 86 with the changed final drive not a hope in hell.
Old 11-20-2020, 08:38 PM   #623
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
FR-S was 58mph at redline in 2nd per my calculations. 86 would have been closer to 52mph at the top of 2nd. While it hurts the 0-60 numbers, I miss the short gears on the twins. My current car will do ~70 in 2nd and the steps are just too big with 1:1 being 4th and a 3.7 final drive. Gearing is so important for making a car engaging to drive.
Quentin is offline   Reply With Quote
The Following 3 Users Say Thank You to Quentin For This Useful Post:
Dadhawk (11-20-2020), Dzmitry (11-23-2020), jeffchap (11-22-2020)
Old 11-20-2020, 09:01 PM   #624
vh_supra26
Site Moderator
Drives: Supra
Originally Posted by gymratter View Post
anyone recall the time differences of when the 1st gen debut?
About the same time at Tokyo.
https://global.toyota/en/detail/1739...659.1605923917
https://media.subaru.com/pressreleas...ils-subaru-brz
vh_supra26 is offline   Reply With Quote
Old 11-20-2020, 09:20 PM   #625
Lantanafrs2
Drives: 2013 frs red
Examples:
2015 86:
7.4s
2017 86:
7.79s
2019 BRZ:
7.77s
Those are way slow. Fuel quality?
Lantanafrs2 is offline   Reply With Quote
Old 11-20-2020, 09:22 PM   #626
Lantanafrs2
112kw is low too
Old 11-20-2020, 09:29 PM   #627
I've done it on a taxiway with the AT (advantage of a small airport with zero traffic most the time I'm there). It definitely hits 60 right before the redline in 2nd, but only just before redline. Didn't time it though.
Old 11-20-2020, 10:16 PM   #628
brillo
Looking back at the videos and ride along videos I’m thinking the engine might be a bit under rated given the power i’m seeing put down with two in the car. At least it appears the car isn’t over rated. Possible the torque is closer to 200tq at the crank? In any event a flater tq curve and more torque should make for a faster car and better magazine numbers.
Old 11-20-2020, 10:23 PM   #629
anticubus
Drives: 2017 Toyota 86
It can hit 60 in second if you have a 25" tall tire and smack the redline hard. The stock all seasons mine came with were only 24.5" tall and topped out at ~57MPH even though the dash will indicate 60MPH.
That's all technical though, the experience and joy of doing it isn't worth the effort more than a couple times.
anticubus is offline   Reply With Quote
The Following User Says Thank You to anticubus For This Useful Post:
Tcoat (11-20-2020)
Old 11-20-2020, 10:26 PM   #630
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
All-New 2022 Subaru BRZ Makes Global Debut
I want to see the new exhaust manifold. I can’t get over how different it sounds.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
JesseG (11-22-2020), Spuds (11-20-2020)
2022 Subaru WRX Spy Shots via Car and Driver R_E_L Other Vehicles & General Automotive Discussions 230 01-03-2023 01:23 PM
2017 BRZ Hig Res - Courtesy Subaru Global Media Trap63 BRZ First-Gen (2012+) — General Topics 10 07-11-2016 09:53 AM
Subaru global brz web page Gaen BRZ First-Gen (2012+) — General Topics 4 06-15-2012 01:32 AM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
FT-86 makes UK debut at Goodwood Moving Motor Show Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 28 07-09-2010 02:57 PM
