| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
| View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest | |||
| 1 |
19 | 7.20% |
| 2 |
25 | 9.47% |
| 3 |
62 | 23.48% |
| 4 |
104 | 39.39% |
| 5 |
54 | 20.45% |
| Voters: 264. You may not vote on this poll | |||
#533 |
That was my immediate thought. The current model's CG was already just 46 centimeters (18 inches). Given that it can't be below the bottom of the car, there isn't a lot of room for movement there and still be road driveable.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#534 |
Drives: 2013 frs red
My first mod will be a light weight crank pulley.
#535 |
Oh dude you do not want to jump straight to a 400HP equivalency!
#536 |
#537 |
Drives: '04 STi, '12 Mazda 3 Hatch
Anyone else stoked to see the wing replaced with the duck tail? I expected it but was still happy to see it.
Anyone else notice that the BASE new Civic has a turbo and more power? I get all their arguments but as the rest of the industry marches forward this car will still feel comparatively underpowered, even with the new stronger engine, and ESPECIALLY at altitude. I need to test drive it at home between 9,000-11,000ft before buying to see if it has enough torque to break the tires loose in 2nd gear without a clutch pop. |
| The Following User Says Thank You to Lelandjt For This Useful Post: | Dadhawk (11-20-2020) |
#538 |
Well it depends on where it falls in height on the car. If above the line it will lower it. If below the line raise it. My knowledgeable assessment it is would raise or lower it .00000001 MM.
Data for this assessment was pulled outta my ass so 100% correct!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Dadhawk (11-20-2020), Jordanwolf (11-20-2020) |
#539 |
Drives: 2017 Toyota 86 (860 SE)
Did I see somewhere that the Base trim will still have 17s? I feel like 18s on this platform end up with too little rubber for regular streets.
#540 | |
Pavement Grey
unless im going up a hill in 5th gear (i'd have to drop it to 3rd) Then again im only 3500ft above sea level..... Or maybe im just a sloth in real life..... |
| The Following User Says Thank You to Sasquachulator For This Useful Post: | Tcoat (11-20-2020) |
#541 | |
Hot Dog
Drives: quicker than arghx7
The press release states the wheelbase increased by 0.02", which is inaccurate. Ditto the typo regarding the height delta. Like @ZDan said; press releases are occasionally incorrect, this isn't news. The press release even says it in bold: "Preliminary Specifications. All data estimated and not final." Reading the quotes you've taken out of the press release tells me you're searching for words to support a conclusion instead of inferring the most probable answers. Relax, the "final answers" will come in 9 months or so.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#542 | |
Who cares if the base Civic has more power? A quick look shows the base has a blistering 0 to 60 of 8.1. Even the R is only 5 and the only one that I would expect to be better than the Gen2. Stop playing the HP numbers game and look at the whole picture.
| The Following User Says Thank You to Tcoat For This Useful Post: | HKz (11-20-2020) |
#543 | |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
#544 | |
"Wheels 17-inch aluminum alloy on Premium" Did anybody else actually READ that info?
#545 | |
Drives: Q5 + BRZ + M796
#546 | |
Drives: '23 BRZ
215/45 R17 87W Premium 215/40 R18 85Y Limited I'm hoping that 17s will still clear the hopefully-forthcoming PP model brakes... |
| 2022 Subaru WRX Spy Shots via Car and Driver | R_E_L | Other Vehicles & General Automotive Discussions | 230 | 01-03-2023 01:23 PM |
| 2017 BRZ Hig Res - Courtesy Subaru Global Media | Trap63 | BRZ First-Gen (2012+) — General Topics | 10 | 07-11-2016 09:53 AM |
| Subaru global brz web page | Gaen | BRZ First-Gen (2012+) — General Topics | 4 | 06-15-2012 01:32 AM |
| Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) — General Topics | 39 | 03-24-2011 09:22 AM |
| FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 02:57 PM |
