| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
| View Poll Results: How would you rate the design of the 2nd gen? 1 lowest & 5 highest | |||
| 1 |
19 | 7.20% |
| 2 |
25 | 9.47% |
| 3 |
62 | 23.48% |
| 4 |
104 | 39.39% |
| 5 |
54 | 20.45% |
| Voters: 264. You may not vote on this poll | |||
#519 | |
Drives: 2013 frs red
#520 | |
Drives: '23 BRZ
You are so very credulous with "official sources"! Spokespeople and press-release writers don't necessarily know what they are talking about, and when they do can spin things to seem more impressive. *Maybe* the engine is indeed lower relative to fixed chassis points, but I'm betting they just lowered the car... Or yeah, combination, for sure the current cars engine sits awfully high... |
#521 | |
I will wait.
#522 | |
You only use the data point that agree with your theories? Cherry pick much? Sure it may be off a bit but is what we have for OFFICIAL data right now.
#523 | |
Drives: '23 BRZ
The "official" narrative might not be the simplest explanation, they tend to play things up and make even a relatively minor change seem like a host of "big improvements"... |
#524 | |
TRACKBREAD
#525 | |
"The tidy coupe design is just over an inch longer and almost half an inch lower than its predecessor, resulting in a low and wide frontal area" We will not know ride height until we see some road clearance data. The pictures sure don't make it look lower to the ground.
#526 | |
#527 | |
Drives: '23 BRZ
Anyway, speaking of "official" data sources, they ain't always right... From the Subaru site: The 2.4-liter naturally aspirated engine redlines at 7,000 RPM and delivers a 15-percent increase in torque. Peak power is at 7,000, redline is likely 7500rpm (indicated, anyway). Peak torque is actually up 18% (184/156 = 1.18) and it's likely 20% or more up through much of the rev range given higher compression ratio and 1.2x displlacement. I've had to write vehicle specs myself, and sometimes the editing goes a little wonky... Anyway, "official" data isn't always 100% correct. |
#528 | |
We will see what is what when we finally get a road clearance number.
#529 | |
Drives: '23 BRZ
We ALL know that nothing means anything to you until the almighty manufacturer lists "official" info. Even though that is not always accurate... |
#530 | |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"I gotta rock." -- Charley Brown |
#531 | |
Logic and reason resulting in assumptions and theories do not equal knowledge. They just simulate it. Some of the "more knowledgeable" contributors here are full of shit about 90% of the time so that is not a reference for their qualifications. We will eventually get some more FACTS and see what is what. At this point the known aspects of the lower COG are a lower engine, lighter upper body panels and weight redistribution through smaller upper greenhouse. Not sure why the assumed lower ride height even has to be considered. LOL we dodn't even know what the actual new COG is beyond "hyper car". We could be debating a few millimeters.
#532 | |
Drives: '23 BRZ
Usually I don't believe official factory numbers until they're independently verified myself... Particularly curb weights and weight distribution (latter of which the official numbers have *always* been more optimistic than reality). In any case, we are here on these forums to talk about cars, share our thoughts, and yes, at times to speculate a bit. If that bugs you so much why not just hang out at the Subaru and Toyota sites all day and wait for "official" info to be "officially" disbursed? |
| 2022 Subaru WRX Spy Shots via Car and Driver | R_E_L | Other Vehicles & General Automotive Discussions | 230 | 01-03-2023 01:23 PM |
| 2017 BRZ Hig Res - Courtesy Subaru Global Media | Trap63 | BRZ First-Gen (2012+) — General Topics | 10 | 07-11-2016 09:53 AM |
| Subaru global brz web page | Gaen | BRZ First-Gen (2012+) — General Topics | 4 | 06-15-2012 01:32 AM |
| Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show | C-Bone | BRZ First-Gen (2012+) — General Topics | 39 | 03-24-2011 09:22 AM |
| FT-86 makes UK debut at Goodwood Moving Motor Show | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 28 | 07-09-2010 02:57 PM |
