| Southern California SoCal |
Shop to install Trac Spec Hood vents
Anyone know of a place to do this install properly... in the SoCal area. I don't trust myself cutting the OEM hood
2013 Series 10 FRS #553
#2 |
Drives: 2017 toyota 86
Any body shop, but you do have slight room for error. Lots of painters tape and measurements. Go slow it’s more scary than hard. Can make “practice” cuts in the center part you are cutting out. Worst case it’ll give you an excuse for a carbon fiber hood lol.
#3 |
Tried 2 local shops. 1 would not try and other told me 500$. At that price might as well just buy a carbon fiber hood but I like the look oem hood + vents more
#4 | |
BAE
Drives: Asphalt FRS
It just takes time. I cut mine just fine, just measure measure measure and drill holes & cut. I added 3mm rivnuts to mine versus using the supplied rivets so i can add rain guards. Harbor freight sells a cheap cutoff tool that works really well. |
#5 |
Drives: old models
nice
free online assignment help uk provider
#6 | |
![]() Sent from my GM1915 using Tapatalk
#7 | |
BAE
Drives: Asphalt FRS
Here you go! https://www.harborfreight.com/3-in-h...ool-63023.html |
| The Following User Says Thank You to Decimus For This Useful Post: | jflogerzi (09-04-2020) |
#8 |
Well I am finally attempting this install over the weekend
#9 |
Drives: Moped
| The Following User Says Thank You to Lonewolf For This Useful Post: | DarkPira7e (11-18-2020) |
#10 |
Rust bucket enthusiast
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#11 |
got lazy... Will be trying over the holiday break in December. I have 2 weeks off due to budget issue for my institution
#12 |
Drives: 18 brz
With the help of a friend I was able to cut mine. Measuring took ALL DAY to make sure it was lined up correctly. We tried using the linked tool but it wouldnt cut deep enough and once we switched to a jigsaw it was very easy
| The Following User Says Thank You to BROSEIDON3 For This Useful Post: | jflogerzi (11-25-2020) |
| Hood Vents | djezlee | Engine, Exhaust, Transmission | 28 | 05-25-2020 09:18 PM |
| Wtb: hood vents or carbon fiber vented hood | Pooponwindows | Want-To-Buy Requests | 0 | 05-25-2018 02:24 PM |
| WTB. Trac Spec hood | xxGiXxeRxx | Want-To-Buy Requests | 0 | 04-16-2017 09:47 PM |
| Shop recommendation for hood pin install? | Colin86 | Great Lakes | 0 | 09-02-2016 11:48 AM |
| Best way to seal off vents in cf hood so they are for looks? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-01-2014 02:25 AM |
