Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-18-2020, 10:03 AM   #533
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
WHAT A DUMPSTER FIRE. Subaru website down for maintenance?
Summerwolf is offline
The Following 4 Users Say Thank You to Summerwolf For This Useful Post:
Dadhawk (11-18-2020), Spuds (11-18-2020), Tcoat (11-18-2020), Tokay444 (11-18-2020)
Old 11-18-2020, 10:06 AM   #534
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
What did you expect? It's 2020.
Guru Woodman is offline
The Following 3 Users Say Thank You to Guru Woodman For This Useful Post:
Ash_89 (11-19-2020), Dadhawk (11-18-2020), Spuds (11-18-2020)
Old 11-18-2020, 10:06 AM   #535
Damned COVID
Tcoat is offline
Old 11-18-2020, 10:07 AM   #536
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
2.4 NA D4S, 228hp 184ftlb
Nominal torque curve at 2:18 btw
Spuds is online now
The Following 5 Users Say Thank You to Spuds For This Useful Post:
Copy (11-18-2020), Lightened (02-18-2021), Ohio Enthusiast (11-18-2020), Spacemane969 (11-18-2020), Wally86 (11-18-2020)
Old 11-18-2020, 10:11 AM   #537
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by Jfheisenberg View Post
Not a fan of the front and rear changes. The rear has a lot going on and tail lights remind me of the new civic. The side view still looks good, just need more low and bigger wheels. First gen looks cleaner and sexier imo.
Personally, i like the new interior changes but they did crew up the new dash. Subaru had the chance to make a digital dash like the new 400z! .
Wanted to like this car dang!! maybe it’ll grow on me in person
The 2022 civic.... looks like a jetta.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline
The Following 2 Users Say Thank You to Wally86 For This Useful Post:
Dzmitry (11-18-2020), Jfheisenberg (11-18-2020)
Old 11-18-2020, 10:14 AM   #538
Originally Posted by Opie View Post
We'll see how close I am:
Company Built By: Subaru [CONFIRMED]
Plant Produced In: Subaru – Gunma Prefecture, Japan [CONFIRMED]
Platform: Subaru Global Platform v2 with revised Sub frame assemblies for a lower center of gravity & 40% Stiffer than v1 [SUSPECTED]
Power plant possibility #1: FA24 - 2.4L boxer 4-cylinder - Normally Aspirated (86/BRZ specific, not used in any other model) Power: 215 – 225 HP, 170-200ft/lb. torque [SUSPECTED]
Weight: Under 2,881lbs [SUSPECTED]
Suspension changes: 5x114.3 lug pattern, larger STI style wheel bearings [SUSPECTED]
Aluminum knuckles [SUSPECTED]
Models/Trims/Pricing (MSRP): [SUSPECTED]
Subaru: BRZ Limited – MT or AT w/Eyesight - $29,915 (MT) / $31,715 (AT)
Performance Package adds $2,975 - $32,890 (MT) / $34,690 (AT)
TS – MT Only (Released 1 year after) - $35,245
Toyota: 86 – MT or AT - $28,975 (MT) / $29,715 (AT)
TRD Package adds $2,975 - $31,950 (MT) / $32,690 (AT)
GR86 – MT Only (Released 1 year after) - $34,845
Official Announcement Date: November 18, 2020 [CONFIRMED]
Projected Release Date: Spring 2021 [SUSPECTED]
Originally created on: 02/17/2020
Updates: 11/17/2020
2022 Subaru BRZ
BRZ Limited 6MT
PRICE STARTING AT: $29,923
Vehicle
EPA Classification: Subcompact Cars
Drivetrain: Rear Wheel Drive
Engine Type and Required Fuel: Premium Unleaded H-4
Displacement (liters/cubic inches): 2.4 L/146
Fuel System: Gasoline Direct Injection
Maximum Horsepower @ RPM: 221 @ 6000
Maximum Torque @ RPM: 193 @ 4400
Number of Transmission Speeds: 6
First Gear Ratio (:1): 3.63
Second Gear Ratio (:1): 2.19
Third Gear Ratio (:1): 1.54
Fourth Gear Ratio (:1): 1.21
Fifth Gear Ratio (:1): 1.00
Sixth Gear Ratio (:1): 0.77
Reverse Ratio (:1): 3.44
Final Drive Axle Ratio (:1) : 4.30
Fuel Economy and Range
CO2 Emissions, 15K mi/year (tons): 6.5
Range, city/highway (miles): 283.10 / 371.80
EPA Fuel Economy, combined/city/highway (mpg): 28 / 30 / 37
Fuel Capacity / Gas Tank Size: 13.8
Exterior Dimensions
Wheelbase (inches): 101.7
Length (inches): 164.3
Width, without mirrors (inches): 70.1
Height (inches): 52.4
Front Track Width (inches): 60.1
Rear Track Width (inches): 60.8
Minimum Ground Clearance (inches): 4.9
Interior Dimensions
Passenger / Seating Capacity: 4
Total Passenger Volume (cubic feet): 77.2
Front Head Room (inches): 37.2
Front Leg Room (inches): 42.0
Front Shoulder Room (inches): 54.8
Front Hip Room (inches): 53.4
Second Row Head Room (inches): 35.3
Second Row Leg Room (inches): 30.2
Second Row Shoulder Room (inches): 51.8
Second Row Hip Room (inches): 46.2
Cargo Area Dimensions
Trunk Space (cubic feet): 6.6
Steering: Rack-Pinion (Electric)
Suspension
Front Suspension Type: Strut
Rear Suspension Type: Double Wishbone
Brakes
Brake Type: 4-Wheel Disc
Anti-Lock-Braking System: 4-Wheel
Front Brake Rotors, diameter x thickness (inches): 11.6
Rear Brake Rotors, diameter x thickness (inches): 11.4
Wheels and Tires
Front Wheel Size (inches): 17 X 7.5
Front Wheel Material: Aluminum
Front Tire Size: P225/45YR17
Rear Wheel Size (inches): 17 X 7.5
Rear Wheel Material: Aluminum
Rear Tire Size: P225/45YR17
Spare Wheel Size (inches): Compact
Spare Wheel Material: Steel
Spare Tire Size: Compact
Wheel Bolt Pattern: 5 x 114.3mm
Base Curb Weight (pounds): 2881
Electrical
Cold Cranking Amps @ 0° F: 470
Maximum Alternator Capacity (amps): 190
Close but no cigar.
https://www.ft86club.com/forums/showthread.php?t=143209
Tcoat is offline
Red-86 (11-18-2020)
Old 11-18-2020, 10:17 AM   #539
Frau86
Frau86's Avatar
Drives: 2019 Toyota 86
Not a fan of the styling and agree with others that the front and rear don’t mesh together well. Side view is fine but I think they are trying to improve on near perfection with the first gen’s clean lines. If it was just the bumper I had a problem with I’d be more optimistic that Toyota’s twist might be promising but that rear-end is a deal breaker. I’m sure these cars will grow on me a bit with time but I’m definitely holding onto mine.
Frau86 is offline
The Following User Says Thank You to Frau86 For This Useful Post:
Old 11-18-2020, 10:20 AM   #540
Guru Woodman
Are we getting 3 shpritsers?
The Following 2 Users Say Thank You to Guru Woodman For This Useful Post:
Dzmitry (11-18-2020), soundman98 (11-19-2020)
Old 11-18-2020, 10:41 AM   #541
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
See, this is what happen when you let Subaru engineer it lol jk
Also if you guys wanna know Toyota design, gotta wait til next yr... TAS to be correct. Have I seen it? No, not the final version. Which look the worse? idk.
ichitaka05 is offline
The Following 9 Users Say Thank You to ichitaka05 For This Useful Post:
bcj (11-18-2020), Dadhawk (11-18-2020), daiheadjai (11-18-2020), Ghost of Akina (11-18-2020), Red-86 (11-18-2020), soundman98 (11-19-2020), Spuds (11-18-2020), Tcoat (11-25-2020), Veloist (11-18-2020)
BRZ Unveiling to the Subaru Owners Club of South Africa (SOCSA) Didierm BRZ First-Gen (2012+) — General Topics 6 01-31-2013 08:06 AM
Last 2012 CDC Autocross SATurday November 17th and TNT SUNday November 18th echan Mid-Atlantic 8 11-19-2012 10:40 PM
GT-86 Hits W.A!!! Release date in W.A 18th of June.. FT-86GOD AUSTRALIA 92 06-14-2012 12:52 PM
Subaru commercial previews design? jakub4 BRZ First-Gen (2012+) — General Topics 14 10-24-2011 01:09 AM
