#1457 |
Drives: SSM LT MT BRZ
given that he has boost creep from 3-4 PSI I think it is safe to assume he is just running the lightest TiAl spring in his wastegate.
EDIT: Beat me by a second lol |
#1458 |
We just went out and retest the 2 cars side by side.
1 Go Pro inside the vehicle and 2 GoPro HD's outside back to back. That way we can show forward and reverse. This video is much better quality than the original. Going to start editing tonight to make a promotional video. We did a 10mph Roll I topped out 3rd gear and he was just about to make the shift into third he tells me. Judging by the lines on the Rd. I count 6-7 Cars roughly. I let him drive the car for the first time and he was amazed at what the difference was. "Theres No way thats only 50hp more" - Jeff Camp! Don |
| The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post: | cobrabyte (07-25-2012), TouchMyHonda (07-25-2012) |
#1459 |
Drives: 2013 Black FR-S
Is there room to just place a flat/short mushroom filter straight onto the compressor? That way it takes in air from below?
#1460 |
#1461 | |
Drives: '06 AM V8V Coupe
Also I believe the windshield angle's effect on drag is more about how much air gets pushed to the sides over the A pillars and then back around the C pillars, but not sure on that either. |
#1462 |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
Don, this has been an exciting project and you have done an excellent job with the design, engineering and execution. The only thing I see happened is that you let the cat out of the bag too early. You should have kept it top secret until you where done. You would have saved countless hours of answering questions and answering the same questions numerous times. You did an awesome job and the people that appreciate it will purchase it and be very happy. It's unfortunate that the critics are not building and showing us how they would of done it so much better. They just have time to try to rattle your cage. There is fifty different ways to get the same results. Your way is very smart and easy for anyone to install without being a fabricator. Do not let anyone suggest that you took any shortcuts or did anything wrong or should of did something different. You did a great job and my hats off to you for doing it and dealing with all the BS people have thrown your way. Good luck with your Stage I.
| The Following 2 Users Say Thank You to Roadstercycle For This Useful Post: | HotLeopardMama (07-25-2012), sirus (07-26-2012) |
#1463 |
Drives: Past S13 S14 350Z, Future FRS
^This, way to go Don!
#1464 | |
Thanks. I appreciate that. I've been in the business for almost 15 years. Not all criticism is bad. It gives me alternative angles that I just don't see myself. For instance the cold air intake system I made today that routes into the factory pickup location behind the bumper and requires Zero Modifications to the Body!!!!
| The Following User Says Thank You to Don@Accelerated For This Useful Post: | HotLeopardMama (07-25-2012) |
#1465 | |
Vtec Jesus
#1466 |
#1467 | |
Spaceman
Drives: 2013 Firestorm Scion FR-S
Sent from my Galaxy Nexus using Tapatalk 2
#1468 | |
Vtec Jesus
[ame="http://www.youtube.com/watch?v=i98OzHtXbW0"]http://www.youtube.com/watch?v=i98OzHtXbW0[/ame] |
#1469 |
I just Drive.
Drives: in the womb still
I don't like the placement either, however the manufacturer themselves stated they couldn't fit a turbo under the hood because of hood line...
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#1470 | |
The manufacturers have restraints. I could clearly put the turbo in the engine bay. I felt there were to many compromises and to much heat passing by vital engine sensors. |
| Accelerated Performance 2013 BRZ Intake Dyno Testing Video | Don@Accelerated | Engine, Exhaust, Transmission | 109 | 05-17-2013 11:24 AM |
| Accelerated Performance 2013 BRZ Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 135 | 09-03-2012 11:24 PM |
| Accelerated Performance 2013 BRZ/FRS Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 24 | 07-07-2012 07:05 AM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 08:14 PM |
