#29 | |
Nothing wrong with replacing the pump assembly. It would eliminate 1-3 in one fell swoop. You still have to drain the tank to replace the pump. 300 bucks would buy lots of pressure gauges. ![]() Definitely check the charging system. Do the headlights dim at idle? Does the engine stumble when everything's turned on? Cabin fan, headlights, brake lights all at once? It occurs to me that we haven't discussed relocating coil packs. If the misfire is consistently on 5 and 6, swap a couple. They don't last forever. Worn (or conventional) plugs are hell on coil packs.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-07-2020) |
#30 | |
The Dictater
Drives: '13 Red Scion FRS
Fuel pump pressure is controllable electronically, so the best guess is it lowers the target pressure at lower rpm to put less strain on the pump, then steps it up as more fuel is needed. At some point that increase results in enough pressure to keep all 6 injectors going. It may not have a feedback loop in the control of the pump, so it is not adapting to increased pressure demand. I think I might have a fuel pressure test kit from my grandfather, probably need a bunch of modern connectors though lol. What should the pressure be? I cannot seem find specs using my apparently weak google-fu. I suppose if it's lower at idle than it is primed but no flow that is evidence that the filter is the problem? Everything electronic I can control works fine all together, and ecu voltage is still reading 14.2ish so I think charging is fine? Engine stumbles at low rpm as described, and is remarkably consistent. Yeah I hear you on coil packs, but the chances of two different packs on different banks going at the exact same time are pretty low. I cleared the codes and checked again, still 5 and 6. I suppose it's cheaper to try to swap coils around before getting that in-tank assembly though... |
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (11-07-2020) |
#31 |
Drives: hyper blue
reset the codes, swap the coil packs to 1 and 3, drive and then check codes.
if it stays on 5 and 6, check the plugs. if the plug holes are swimming in oil, get the valve cover gasket kit for both sides. |
| The Following User Says Thank You to thomasmryan For This Useful Post: | Spuds (11-07-2020) |
#32 |
Is that a thing for these engines? I can picture it.
#33 |
The Dictater
Spent a few hours this morning shuffling plugs and coil packs around, using every single socket, wrench, and adaptor in my arsenal of course (ok just the 10mm and 12mm sockets and wrenches). Reset codes, still reports misfiring on 5 and 6. No visible damage to coils, plugs were dry and looked fine.
Sooo, fuel supply next? At least I can say I've done spark plug stuff on a Subaru lol. |
#34 |
Drives: TBA
Another long shot: The misfires are isolated to #5-6, it isn't coil packs so yeah, something's off with fuel delivery.
I recall that D4-S mapping is compound DI/Port at lower rpm, exclusively DI at midrange, then both again at the high end. So, could the #5-6 port injectors be clogged? Maybe bench testing them would help. |
#35 |
Drives: hyper blue
see if the intake manifold bolts are tight on the drivers side. (it's an o-ring type gasket.)
#36 | |
The Dictater
#37 |
The Dictater
#38 |
Drives: TBA
#40 |
pessimistic skeptic
coil packs
spark plugs injectors valve springs My FR-S was checked in that order for the exact same problem. It was valve springs. |
| The Following User Says Thank You to mrg666 For This Useful Post: | Spuds (11-12-2020) |
#41 |
The Dictater
#42 |
pessimistic skeptic
| Troubleshooting a Leak with OFT | Lakitu | Software Tuning | 27 | 06-22-2018 03:31 AM |
| Troubleshooting Idle | bfsnail | Forced Induction | 3 | 12-03-2016 06:05 PM |
| BRZ DRL Troubleshooting | MaximaZero | Issues | Warranty | Recalls / TSB | 2 | 11-17-2015 04:31 AM |
| Troubleshooting with a KW c38 | pgranberg11 | Forced Induction | 7 | 10-13-2015 08:05 AM |
| Need troubleshooting help. | Camop82 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-14-2013 02:16 AM |
