Old 02-24-2020, 10:17 PM   #141
CSG Mike
CSG Mike's Avatar
Originally Posted by ROGUEI4IHIRE View Post
So is there a head unit that can run EcuConnect app or not? I’ve seen a lot about jail breaking and Bluetooth naming convention issues. I’d really like to throw an android head unit in download the app on it and be able to do everything without my phone.
Any android head unit.
Old 02-25-2020, 01:28 AM   #142
tomm.brz
Drives: brz 2017 hksv2
i use xtrons head unit with it, but they are bugged and do not work with the ecutek bluetooth
actually is the bluetooth on the obd That is bugged and ecutek is not willing to fix
but it works with the miniusb connected so it s ok
Old 02-25-2020, 11:03 AM   #143
ROGUEI4IHIRE
ROGUEI4IHIRE's Avatar
Drives: 2017 Toyota 86 860 W
Thank's Mike!
ROGUEI4IHIRE is offline   Reply With Quote
Old 05-12-2020, 08:17 PM   #144
Jdmjunkie
Drives: Scion FR-S 10 Series
Does anyone have a custom dashboard background or a link to a place to find them?
Jdmjunkie is offline   Reply With Quote
Old 05-13-2020, 05:35 PM   #145
Kodename47
Kodename47's Avatar
Drives: UK GT86
Google images?
Seriously, I just went online and found pics and used an app to get them to the correct size. I have a GRMN logo on a black background. Dark works best if you might use the app at night IMO.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-13-2020, 05:42 PM   #146
tomm.brz
everyday i wish ecutek would allow custom inputs integrated into dash to create the definitive dashboard
Old 05-29-2020, 09:47 PM   #147
randomthoughts
Drives: 2014 White BRZ
Dashboard
I started messing around with the dasboard in the app today. Although it's customizable it has a lot of limitations in term of astethics.
Anyways here is my first attempt at a custom dashboard. Doesn't look nearly as nice a the torque one I created.
I made this in the demo mode so the values are messed up.
Still lots of tweeking before I'll be happy. The first one will be my dataloging screen.
randomthoughts is offline   Reply With Quote
Old 05-30-2020, 06:16 PM   #148
Kodename47
Kodename47's Avatar
Drives: UK GT86
@randomthoughts that looks like it would be really hard to actually read when driving and there is repetition across the screens/tabs.
I have 2 main screens with actual useful info that you might want for driving and then the rest are there just for datalog info. While it's great to fill a screen with info, much better to have minimal info of useful data.
Why RPM? - it's on the dash in front of you
Throttle angle - not useful unless mapping the throttle (even then I'd just mark and use logs.)
AFR - I think the graph works well with target and output
Temps - Air/Oil/Water - set on dials with min and max set works well
MAP and MAFs - same as above
VVT on - Is 1/0 so you can have that as a bar/number/dial as you see fit
VVT angles - also a worthwhile parameter
Here's mine for ref:
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-30-2020, 07:25 PM   #149
randomthoughts
@Kodename47 It is much easier to read on my Tablet. I am not sure why the screen captures turned out so dark.
As for the the first page, I realize now after I have been playing with the app that the data logging parameters are selected in another menu. For some reason I thought it would log what was on the screen (hence the busy screen). I should have known better as my OFT tablet has a separate menu for logging channels. I just picked what was used for logging on OFT but I see this can log many more parameters.
The parameters I choose on the other screens were some what random just to play with aesthetics.
My final setup will have more appropriate parameters. And thank you for the suggestions I will definitely consider some of them.
I will connect the Bluetooth to the ECU tomorrow ans try it out. I am still on an OFT tune so I assume the RaceRom features will not be available as well as some parameters until I have an RaceRom tune. I am new to Ecutek.
Old 06-01-2020, 05:08 AM   #150
tomm.brz
i too keep the most valuable voices on main dash board
but if you make multiple pages on dasg that you won t even ever look at, and you put all the normally logged valuea by "Datalogging" it permits you to eventually log from dash without going back to dataloggin
Old 10-28-2020, 02:36 PM   #151
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Originally Posted by wparsons View Post
I would bet the BT could still flash if there's already a license on the ECU, but not sure.
3 second hold or pedal dance should light both the TC and VSC lights (yellow on an FRS, not sure on a BRZ). There's a third light, the green VSC sport, it shouldn't be lit.
I'd double check that, pedal dance absolutely does not turn off ABS.
Thread revival instead of making a new one.
Why is that coolant gauge behaving like that?
Faulty sensor?
Gauge malfunction?
Or blown Fuse?
Thanks.
Thefalls is offline   Reply With Quote
Old 10-28-2020, 02:49 PM   #152
wparsons
wparsons's Avatar
Faulty sensor?
Gauge malfunction?
Or blown Fuse?
Thanks.
What issue exactly? What do you think is wrong with the coolant gauge? There's no issue in that cluster image.
flickr
Old 10-28-2020, 02:59 PM   #153
Thefalls
Thefalls's Avatar
Drives: Corolla GT
The coolant gauge has the gradient markings missing.
Long story cut short, i had accidentally 'long pressed' the centre button on the steering wheel controls and the coolant gauge turned to this blank look without any numbers. Another long press brings back the numbers on the scale for the coolant temps.
I admit to not knowing this before. Just discovered this.
Old 11-06-2020, 05:05 PM   #154
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
With the long press it switches to a more "normal car" hot cold range versus actual temp. I don't know why anyone would want the hot cold range vs the numbers imo lol.
aKaGorganZola is offline   Reply With Quote
Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM DeliciousTuning Software Tuning 331 06-17-2025 02:36 PM
My Bluetooth in my 2014 FRS so stay connect Case1010 Electronics | Audio | NAV | Infotainment 3 02-24-2016 06:57 PM
Header/overpipe interface misooscar Engine, Exhaust, Transmission 4 11-22-2014 11:21 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 04:38 PM
