| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#701 |
We haven’t had any issues with them. It has completely changed the feel of the car. All for the better. We just try not to take too sharp of turns when it can be helped.
#702 |
Drives: 2018 Subaru BRZ Premium, Blue
#703 |
Drives: 15' FRS
Love breaking out my 2.5RS wheels for winter
#704 |
Can finally post to this thread - I don't plan on keeping this setup but I'm really liking how this looks. Some iPhone pics from when I had them installed.
| The Following 5 Users Say Thank You to blackstripe77 For This Useful Post: | bcj (11-01-2020), FLIPDADY (11-04-2020), grumpysnapper (11-01-2020), NLSP (11-02-2020), venturaII (11-13-2020) |
#706 |
Sorry - realized I failed to list the specs!
These are stock GB5 Legacy GTB wheels in 16x6.5+55 with 25mm spacers. 205/55R16 Bridgestone RE003s are mounted. I'm really digging this look, but am not looking forward to having to clean brake dust out of those spokes. The conservative fitment is also exactly what I was looking for, but I'm not too keen on running 25mm spacers long term. S Will see how it goes. If I love my next set up this much then hopefully these will find a new home. |
#707 |
Only users lose drugs.
Drives: All the time
So that's effectively a 16-6.5 +30ET. Very nice fitment, and a perfect size for the 205/55. If you eventually move up to a 225/50, a 7" rim is all you need.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | blackstripe77 (11-06-2020) |
#708 |
Drives: '17 BRZ
Since you're all running 16's on your cars, maybe you can advise me on something?
I've been looking to get a set of 205/55/r16 for the winter - and budget-wise, am looking at used wheels. Found someone selling pretty new winter tires 215/55/r16. He's not sure about the width, though. They did come off of a Subaru, but not a BRZ. Would such wheels for sure fit with thinner 205 tires, a few seasons down the line? I've been searching online, but I'm pretty new to everything about wheels. |
#709 | |
Drives: 2015 Subaru BRZ Sport Tech
The 205/55R16 should fit no problem on those wheels. Do you have pics of the wheels? Sent from my LM-G900 using Tapatalk |
| The Following User Says Thank You to FLIPDADY For This Useful Post: | ymshulman (11-05-2020) |
#710 | |
Drives: 2017 Toyota 86
Since I like throwing my hunches out there, my bet is the rims are 6.5" width since that's a common OEM sizing. IIRC the stock 16" BRZ rims (International markets only) are 6.5" wide and shared with a bunch of their other lower-spec models. |
| The Following User Says Thank You to anticubus For This Useful Post: | ymshulman (11-05-2020) |
#711 | |
Drives: 2014 Ultramarine FR-S
205/55/16 have a wheel width range of 5.5" to 7.5". So based on that, you should be fine. Most 16" wheels with a 5x100 bolt pattern usually have a width of 6.5" or 7". The size of the wheel might be stamped on the inside of the wheel if they can check. |
| The Following User Says Thank You to NLSP For This Useful Post: | ymshulman (11-05-2020) |
#712 |
Drives: '17 BRZ
Thanks for all of your replies! I'm attaching a photo - they aren't stock Subaru wheels, they were just on one before (so I know the 5x100 pattern is accurate). He says they're "ASA JH3 Revolution" wheels.
#713 |
A few years ago I ran the same style ASA wheels from a Legacy but in 17"
#714 |
If they can flip a wheel over and look at any engravings on the back of the spokes, most wheels should have the size and offset stamped.
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 05:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 07:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-28-2012 12:20 AM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 09:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 12:17 PM |
