Old 11-02-2020, 07:03 AM   #1
fog
Drives: 2014 86 - Invidia Q300, Tomei UEL
engine ticking noise at idle
Hi all, recently I've been getting this constant ticking noise at idle. Can't really tell if its present above idle as I have an aftermarket exhaust.
Doing some research such as this thread I'm really hoping that it's not rocker arm failure. However, that thread the ticking seems far more intense. Anyone had this sort of noise before/any indication of what it could be? It doesn't really sound similar to the DI crickets. It's a MY14 which I've read pre-15's have some problems with rocker arms
fog is offline   Reply With Quote
Old 11-02-2020, 10:47 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Sounds normal to me
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
NWFRS (11-02-2020)
Old 11-02-2020, 11:08 AM   #3
Originally Posted by BigTuna View Post
Sounds normal to me
Yep me too.
I would be much more worried if mine stopped making those sounds!
JesseG (11-02-2020), NoHaveMSG (11-02-2020), norcalpb (11-02-2020)
Old 11-02-2020, 11:24 AM   #4
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
The crickets are very distinctive sounding, which btw they are back with me, I almost missed them
OP, did your car have the valve spring recall?
JesseG is offline   Reply With Quote
Old 11-02-2020, 12:37 PM   #5
His info say it is a 2014 so no.
Old 11-02-2020, 12:45 PM   #6
Agreed, sounds normal.
I reckon it's just the valve lifters indicating that they have some clearance - which is a good thing.
Back in the day, with solid lifters, if you didn't have that sound after you adjusted the valves, it usually meant that they were adjusted to tight and one could expect some burnt valves on down the road.
Old 11-02-2020, 04:20 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The rocker pivots are solid. They are not lifters...kinda. Valve lash is a bucket that goes over the top of the end of the valve stem. You swap out different sized ones to set valve lash.
The rocker pivot sits in an oil galley in the head. One end of the rocker arm sits on the pivot, the other end sits on the top of the valve stem with the bucket lash adjuster in between. There is a roller in the center of the rocker which is driven by the cam.
Most noise that we hear is either the DI injectors firing, or the HP fuel pump. The HP fuel pump is to the right of the oil filter(if you are facing the engine bay from the front) and is driven by 3 lobes on the intake cam. If you set your hand on it with at an idle it pulses.
Rocker failure will always throw a code for a miss fire. That is if the rest of the engine doesn't let go in the process.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (11-02-2020), JesseG (11-02-2020), Tcoat (11-02-2020)
Old 11-02-2020, 04:28 PM   #8
JesseG
JesseG's Avatar
Ahhh ok, I thought maybe the recall extended into 2014 MY’s
Old 11-02-2020, 05:40 PM   #9
Good clarification -
I reckon I got lost back in the old days when most gasoline engines had either "solid" lifters or "hydrolytic" lifters - or at least that's what we called them. Or at least that's what Bubba and I called them.
NOW, I can go take a peaceful nap because at least I know what I was talken about.
ZZZZZZZZZZZZZ
Old 11-02-2020, 06:01 PM   #10
It doesn't ever cover all of the 13s. Just one run of them.
Old 11-02-2020, 08:05 PM   #11
fog
Nah specifically went for the 2014 and checked the VIN to make sure it avoided the recall.
The Following User Says Thank You to fog For This Useful Post:
Tcoat (11-02-2020)
Old 11-02-2020, 08:07 PM   #12
fog
Ok thanks everyone, seems the consensus is that the sound is normal. It's just that it was never there before and only started recently.
Old 11-02-2020, 08:19 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Rocker geometry was improved in MY14 and up. The pocket for the rocker pivot is deeper, valve stem is longer.
Old 11-02-2020, 08:51 PM   #14
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Tappy valves wuz happy valves.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
humfrz (11-02-2020)
Engine Stalled, Rough Idle And Knocking Noise On Startup Slade Issues | Warranty | Recalls / TSB 49 09-28-2020 11:13 AM
Ticking/Rattling noise at idle. Razgriz Issues | Warranty | Recalls / TSB 4 08-17-2017 10:02 PM
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Squeaking/ticking noise coming from engine bay klus95 Issues | Warranty | Recalls / TSB 7 11-18-2016 12:56 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
