Old 10-30-2020, 09:58 PM   #15
Never mind the sound you hear when stopped. You are listening extra hard and have now noticed what's called neutral rollover, or something like that. It's the clatter of all your gears rotating freely but also getting kicked by the pulses of the engine at idle.
One thing about fifth is that the transmission isn't actually doing anything. It's a straight shaft from the front to the back. That you don't hear anything on acceleration means that it's not in the transmission. It is odd only hearing it during engine braking. Is the driveshaft rubbing on something?
edit: nah. that's not driveshaft rubbing. Diff mount blown out?
jcw99 (09-18-2021), kevaughan (10-02-2021), NoHaveMSG (10-31-2020)
Old 10-31-2020, 07:36 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
5th is straight? Not 4th (for which reason usually used in dyno runs)? I thought that both 5th & 6th on ours were overdrive?
Old 10-31-2020, 01:34 PM   #17
They are for the automatic.
Old 11-01-2020, 04:10 AM   #18
ALWYZBZ
Drives: 86
Spot on. It’s only during decel and no sounds on accelerating. I checked the middle trans mount bolt and Recentered after reading another thread. It seemed to have helped some but the sound is still present
ALWYZBZ is offline   Reply With Quote
Old 11-02-2020, 12:44 PM   #19
Was the rear trans mount torn/blown? I saw your other post.
ALWYZBZ (11-04-2020)
Old 11-04-2020, 03:25 AM   #20
ALWYZBZ
Drives: 86
Trans mount was not torn or blown.
The rattling:
Removing Whiteline Rear Diff + Whiteline trans bushing brought down the noise by 90%. The odd deceleration rattle is still feintly present but much more tolerable.
The weird clunking:
This was caused and fixed by centering the T bolt on the trans bushing. I guess it’s easy to overlook when tightening the bolt after removing the Whiteline trans bushing.
The Following User Says Thank You to ALWYZBZ For This Useful Post:
Ultramaroon (11-04-2020)
Old 09-16-2021, 07:43 PM   #21
Azazel.86
Azazel.86's Avatar
Exclamation Hold on! Same here!
Thanks for the input guys, I checked all the under panels and can’t find anything loose.
Previous owner out in an Action Clutch.. I wouldn’t even put those in my old Honda lol
Here is a video in 5th gear, noise is heard when the gas pedal is released then eventually it “settles” down. If I release the gas pedal softly the noise is reduced
Video:
https://streamable.com/s9rigv
In the video I accelerated in 5th, let off the throttle, accelerated and let off again
I'm having the same issue! I just had an Action Clutch installed two weeks ago, and the second I left the shop, that buzzing started. It buzzes the most in 2nd, 3rd, and 5th gears for me. The owner told me it was because of my Verus Clutch fork... Has anyone found a solution? Or is it just a bad clutch kit?
-PS. This is my first post I hope I didn't screw it up
Azazel.86 is offline   Reply With Quote
Old 09-17-2021, 02:38 AM   #22
Welcome, Azazel. Post is fine. So is the Verus fork. Not sure about the clutch. Owner is trying to avoid a do-over. Can you record a clip of the sound and post it on youtube for us?
Old 09-26-2021, 10:48 PM   #23
Turdinator
Señor Member
Turdinator's Avatar
Does the kit you used come with a light flywheel?
1974 TA22 Celica
2013 86 GT
Old 11-23-2021, 09:39 PM   #24
jrhudson
Drives: 2016 scion frs
The rattling:
The weird clunking:
I had the same issue or similar to what you had. 5th gear decel, particularly at 2500-3000rpm, a loud rattle in the rear of the car. I tried everything, even removed the trunk heat shield.
I have Whiteline diff cradle inserts and Whiteline position traction kit(rear subframe inserts) I removed the diff inserts and can confirm just removing that reduced most of the rattle, if not all. Removing the subframe inserts would probably eliminate all of it.
I also have STI mounts if that matters.
jrhudson is offline   Reply With Quote
Vibration at 2500rpm when decelerating Andy2002a Engine, Exhaust, Transmission 9 11-09-2019 09:29 PM
Vibration at 2500rpm when decelerating Andy2002a Engine, Exhaust, Transmission 2 09-30-2019 11:23 PM
Crunching Noise When Decelerating In 2nd/3rd idkwhatimdoing Issues | Warranty | Recalls / TSB 37 01-10-2018 09:30 PM
Hum/whine when decelerating GeeTee86 Issues | Warranty | Recalls / TSB 10 08-11-2016 12:01 PM
White smoke decelerating azynneo Engine, Exhaust, Transmission 6 07-23-2016 10:14 AM
