#22485 |
Drives: 17 Asphalt 86
Winter rubber is on.
Edit moved the review to the tire thread. Last edited by RToyo86; 10-28-2020 at 11:40 AM. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | FLIPDADY (10-28-2020) |
#22486 |
Drives: 2015 Subaru BRZ Sport Tech
Finally put on the HKS catback. With all the heat going on in Ontario with noise tickets, it's a good setup to stay under the radar.
![]() Sent from my LM-G900 using Tapatalk |
| The Following User Says Thank You to FLIPDADY For This Useful Post: | Tcoat (10-29-2020) |
#22487 |
Drives: FR-S,GTI
I made this bitchin' heavy duty bike rack for my e-bike. Now I can bring it anywhere. I'll bet this thing could hold a motorcycle, it's so strong. The pipe going into the tow hook holes is schedule 80 steel pipe.
#22488 |
Wheels for Brains
How does the pipe fasten to the tow hook holes? Is it a friction fit, adapted to a threaded stud, or machined threads on the pipe?
#22489 | |
The Dictater
Drives: '13 Red Scion FRS
Also, not entirely sure how the uprights are constructed, but that seems to be a large moment to be supported by a small amount of thread under longitudinal acceleration. It's clever, just remember to take it real easy with a load on it. |
| The Following User Says Thank You to Spuds For This Useful Post: | JohnJuan (10-30-2020) |
#22490 |
Drives: FR-S,GTI
It starts with a M16x1.5 bolt (the rarest thread pattern in the world) 7 inches long and a nut. Cut off the head of the bolt and bevel the end slightly. Thread on the nut. Put it in the freezer. Get a 6" piece of 1/2" EMT (metal electrical conduit). Deburr the ends. Put it in a vice and heat it up. Take the bolt out of the freezer and pound it into the conduit. Once it cools it's a press fit but I welded it just to make sure. Now get a 1' piece of 3/4" schedule 80 steel pipe threaded on each end. Cut it in half. It will slide perfectly over the bolt/conduit piece. My first idea was to thread the bolt/conduit into the tow hook hole and slide the 3/4" pipe over it and pin it. But it wasn't sturdy enough, so I welded it to the bolt/conduit. So essentially you have a solid steel rod 1" thick with a 3/4" tapered pipe thread on one end and a M16x1.5 thread on the other. Oh, by the way I had to open up the hole through the rear of the car about .001 (unibit) so the pipe fits tightly into the hole. Then I screwed on the angles and pipe pieces. When I got the angles just right, I loctited the angles to the Schedule 80 pipe with red loctite. So that angle is fixed. The rest is pretty much self explainatary.
| The Following User Says Thank You to WNDSRFR For This Useful Post: | EndlessAzure (10-29-2020) |
#22491 | |
Drives: FR-S,GTI
I don't slide around turns with the bike on like I usually do, but it's pretty secure. The uprights are schedule 40 3/4" steel pipe. The cross supports are a piece of that stuff they use on chain link fence to secure the ends. It's pretty strong. They are connected to the pipes using 1 1/4" conduit clamps bent to fit. They are also screwed together where they cross. So when one is pushing the other is pulling. My biggest concern is the bungy cords breaking. |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Spuds (10-29-2020) |
#22492 |
Drives: FR-S,GTI
It was easy. No line. No problems. Just do it before it's too late.
| The Following 5 Users Say Thank You to WNDSRFR For This Useful Post: | BigHugeFatGuy (11-02-2020), Bobharp (10-30-2020), Dadhawk (10-29-2020), FLIPDADY (10-31-2020), soundman98 (10-29-2020) |
#22493 |
Rice King
Wait noise tickets in Ontario? Are shit boxes finally getting ticketed for having clap boom bang exhausts?
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| The Following User Says Thank You to Jordanwolf For This Useful Post: | FLIPDADY (10-30-2020) |
#22494 |
Drives: 2015 Firestorm FR-S MT
You gotta share a pic of those trueno stripes, my guy. I've been thinking of doing the same lol
#22495 | |
![]() ![]() Sent from my LM-G900 using Tapatalk |
| The Following 6 Users Say Thank You to FLIPDADY For This Useful Post: | bcj (10-30-2020), Legoshi (10-30-2020), soundman98 (10-30-2020), Spuds (10-30-2020), Tcoat (10-30-2020), Ultramaroon (11-01-2020) |
#22496 |
Drives: 2013 FR-S MT Hot Lava
I have this set up as well. I really like that it's not too loud and obnoxious. The weigh savings is pretty substantial too,compared to stock.
| The Following User Says Thank You to Th3rdSun For This Useful Post: | FLIPDADY (10-30-2020) |
#22497 |
Drives: 2016 BRZ Series.HyperBlue
Prepped my girl for her first track day. This included installing dedicated track rotors and pads on all four corners, fluid changes and an oil cooler installation (had to revert to a stock airbox as my aftermarket intake wasn't compatible with the oil cooler I bought.
💻 Openflash Tablet v2 Stage 2+ v4 ❄ Jackson Racing Track Engine Oil Cooler Kit 💨 ProSpeed Racing Unequal Length Performance Headers Suit 💨 Invidia N2 70mm Cat Back Exhaust 🦶 Rays Gram Lights 57CR 17x9 +38 5x100 Ceramic White Pearl Wheels 👟 Hankook Ventus RS4 245/40R17 📉 Pedders SportsRyder EziFit Kit 🎢 Pedders SportsRyder Sway Bar Kit
#22498 | |
Wheels for Brains
That's a lot of work just for the track. I used to tape my front lip up every track day. That didn't last long, and I clearly don't care enough even for that anymore |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | soundman98 (10-31-2020) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 05:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 07:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
