Old 10-23-2020, 04:37 AM   #18761
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Dzmitry View Post
Should have no issues with speed bumps. Stock ground clearance is 4.9" on the tS which comes with STI lowering springs and front lip. Not exactly sure how that's true as the stock BRZ comes with the same ground clearance. But the lip doesn't actually do much lowering, as the bottom of it aligns with the bottom of the skid plate. STI springs only lower the car about 10mm. So you're still looking at over 4" ground clearance likely.
As you said the ground clearance is measured in a different area. Not in the front area. Well, check how many members scrapped their STI lip. It depends also on specific roads or if you have to get in or out a garage ramp. I suppose most issues come not with the tS springs, but with more aggressive lowering springs. The tS springs as you said lower the car only 10mm, which is very minimal for most of user tastes.
The Following User Says Thank You to nikitopo For This Useful Post:
Dzmitry (10-23-2020)
Old 10-23-2020, 10:14 AM   #18762
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Are STI springs something you're considering? I know you mentioned an OEM+ build. I personally see the STI lip as a guard, too. Sure it scrapes, but it doesn't scrape the actual bumper so in the end, I don't mind. Plus the lip is easier to sand and buff.
MS, CSCS, TSAC-F, CPT
Old 10-23-2020, 12:47 PM   #18763
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have the STI springs in my old car, but again the lowering was mild in the range of 15mm. I am done with mods .. I have to worry about other things currently.
Old 10-23-2020, 01:08 PM   #18764
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Yes, I actually find this quite useful. I have the HT Autos front lip which is even more aggressive but I have not experienced any problems with it for the most part when it comes to scraping. But the two or three times I've bumped into the parking guard in front of me or scraped, the lip has helped keep the front bumper from getting damaged. The HT Autos lip is a little more of a rugged design though, which I like for exactly that reason, as it still looks brand new. The STI lip has more of a gloss to it, so scraping it would probably make the damage more prominent.
Dzmitry is offline   Reply With Quote
Old 10-23-2020, 01:48 PM   #18765
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Stephen W. View Post
Not that my car will ever see snow but, after last year's fiasco with trying to boost start the wife's car with my tS I thought I'd better be ready.
I found a used set of forged TRD wheels off of a FR-S Release Series 2.0 with snows already mounted. The clear coat is coming off but they look good from a distance.
Anyway, they're more for protection of the summers than actual winter use.
Autumn is such a wonderful season.. So colourful..
The Following User Says Thank You to JD001 For This Useful Post:
Stephen W. (10-24-2020)
Old 10-24-2020, 01:42 PM   #18766
JAS4
Drives: 2020 BRZ Limited PP
Today I installed STI JDM flexible v-bars and draw stiffener. Me likey so much!
JAS4 is offline   Reply With Quote
The Following User Says Thank You to JAS4 For This Useful Post:
MrSkubi (10-27-2020)
Old 10-25-2020, 02:19 AM   #18767
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Fitted some PSR UEL Headers and O/pipe.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
MJones_RB (10-27-2020), norcalpb (10-25-2020)
Old 10-25-2020, 07:07 PM   #18768
therealstoly
therealstoly's Avatar
Metallurgically speaking, I'm curious as to the thought process behind wrapping the header and, in addition to that and as a follow-up, the five 'sun spots' you obviously didn't wrap with intent.
therealstoly is offline   Reply With Quote
Old 10-26-2020, 08:06 AM   #18769
Dzmitry
Dzmitry's Avatar
No expert here, but wrapping the header is simply for preventing heat dissipation and improving heat insulation to increase exhaust flow. In the case of leaving the open spots, as far as I know, this is exactly what you DON'T want to do as you will allow water to get caught and buildup in the wrap and form rust and that sort? Haven't read on this stuff in a while, but that is the general idea I believe.
The Following User Says Thank You to Dzmitry For This Useful Post:
gen3v8 (10-26-2020)
Old 10-26-2020, 05:08 PM   #18770
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
All of the above, so I believe? With the holes rust bit not quite right. The wrap is thick woven heat resistant material, it will absorb and hold moisture(Capillary action?) anyway it does when cold and will gather salt also. The chances of them getting wet before being hot enough to dry is slim also no salted roads around here and the`re Stainless.
Old 10-26-2020, 07:15 PM   #18771
pope
has a funny hat
Drives: 2014 BRZ Limited
BRZ tucked away for a long winter nap.
Might get a car capsule though. Still debating the cost/benefit.
pope is offline   Reply With Quote
Old 10-26-2020, 07:36 PM   #18772
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is what they claim, the main benefit is protecting the rest of the engine bay from heat soak.
Most 300 series stainless steels will rust. Heating it hot enough pushes the carbon out to the surface making it susceptible to corrosion. It is called heat sensitization. It is accelerated even more if you push it past it's transition temperature. There is also passivation baths of the part that can be done which reduces the free irons in the surface which will propagate more corrosion if untreated.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (10-27-2020), norcalpb (10-27-2020), soundman98 (10-26-2020)
Old 10-27-2020, 01:42 PM   #18773
Ernest72
You can drive that in the winter. Get some snows and have fun.
Old 10-27-2020, 03:17 PM   #18774
pope
has a funny hat
I could, but I’d rather keep the car nice and not deal with rust restoration in a couple years. I have no intention of this Texas sourced car ever seeing the northern devil (road salt).
