Old 10-20-2020, 01:22 AM   #1
JR23
Drives: 2015 FRS
Is it risky buying a used Airlift 3p kit?
Hello everyone, I’m in the market to finally get an airlift 3p system but I was wondering if it’s risky buying a used compared to getting it brand new? I don’t really know much about air suspension so I thought I’d come and ask on here. Thanks guys!
JR23 is offline   Reply With Quote
Old 10-20-2020, 09:11 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
everything's got pro's/con's.
buying a used kit means that everything is cut to the right length, and was working at one point.
but if you've never done anything similar to an air ride system, it means that there's no company support, and all you've got is a few random forums, and youtube to help you if you get stuck
the cost will be significantly less than a new kit.
but air ride is something that tends to leak once fittings are messed with. take a sealed system all a part, ship it across the country, and re-assemble, it's likely to leak.
i would say if you're a seasoned pro with electrical and pneumatic systems, building a self-sponsored show car, the lower cost of entry is worth it despite the possible hassles.
if this is on your only car that you need up and running for work in 3 days, and it's one of the first times doing air ride, get the new kit, from a reputable source, so when/if there's problems, you've got someone to lean on.
Old 10-20-2020, 09:58 PM   #3
HaXx
Drives: jrsc_brz
The way I understand it, these things leak new or used. So I'd go used. A wrx friend just went on air, new. Hes already dealing with leaks and stuff. It just happens. It the nature of the setup. My vote : used.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 10-21-2020, 11:10 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
buying anything used always has risks, and there is no warranty to back it up. So if it is that much of a worry save more and buy new
Old 10-22-2020, 06:45 PM   #5
glutenpoops
glutenpoops's Avatar
Drives: 2015 Subaru BRZ Limited
I found my dual compressor 3P kit with only 40 miles on it, drove 6 hours to the guy's house to pick it up because he was reliable. His gf didn't like air ride so he sold it and bought KW V3s lol. He sent me videos of it operating before he took it off his car. He showed me how he routed everything too and gave me advice and offered to help. The controller still had the screen protector on it everything was basically new. Just find the right person and ask why they're selling.
Installing it myself I saved more than half of what it would have been for a new kit + install. Get new airlines for sure, they're cheap, then to be extra safe just redo the leader-line connections with new teflon tape. I've only been on my used kit for about two months, but no problems at all. The connections are the most important part, just make sure you use the line cutter that comes with the kit, and follow the leak test directions - overnight, and using soap on the connections. Make sure your clearances are all good - no rubbing on the bags, no lines catching on moving parts.
Bagriders has an "emergency air ride kit" that I'm probably going to buy. Anything goes wrong it saves you from getting stuck aired out.
I say go used just be ready to be on the search for a while and find the right kit that hasn't been abused. There's always a risk yeah - worst case the manifold goes bad there's no warranty - I think a new one is around $800.
Airlift 3P | ESR RF2 | OFT E85
glutenpoops is offline   Reply With Quote
The Following User Says Thank You to glutenpoops For This Useful Post:
soundman98 (10-22-2020)
Old 10-29-2020, 12:42 PM   #6
Ernest72
There’s this indian proverb that’s says basically pay more you cry once, pay less and cry over and over. Obviously the details mean everything. If it looks like a good deal go for it.
Old 11-12-2020, 12:45 AM   #7
JR23
Drives: 2015 FRS
I decided to go with a new kit like most people said because I got a 3p system for 2600 which I think is a killer deal.
I did have a question for you, how does the Air Ride emergency kit work? I think it’s also smart getting it and I’m definitely looking into investing in one.
FRS from Vroom - RISKY? Cosa Scion FR-S / Toyota 86 GT86 General Forum 14 10-21-2018 09:27 PM
Risky Devil BRZ - Daily / Driftcar ill roller Member's Car Journals 222 12-10-2014 08:11 PM
Two wrongs don't make a right - Risky Devil BRZ's ill roller BRZ Photos, Videos, Wallpapers, Gallery Forum 230 07-21-2014 02:16 PM
Risky Devil BRZ - Daily / Drift car ill roller Member's Car Journals 32 12-11-2012 08:26 PM
8000K HIDs...too risky in Cali? KGFRS86 Southern California 12 10-14-2012 09:44 PM
