Old 10-14-2020, 01:34 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by CrowsFeast View Post
It seems you and I have had significantly different experiences with braking setups. I'm starting to be suspicious it's the S2000's fault! I've always run ATE200 (well, mostly super blue, same thing but blue and discontinued) and the only time I've had an issue with it I had a semi seized caliper (can't blame the fluid for having an issue with that!). Never needed to be re-bled and I think I swapped it after 2 seasons (but I only do ~5 events a season)
Still, I wouldn't say no to name brand dot 4/5.1. Motul stuff is too expensive for my tastes. 2-3x as much as ATE200 where I've looked.
I cooked the ATE pretty quickly as well.
Old 10-14-2020, 03:14 PM   #16
norcalpb
norcalpb's Avatar
I typically wait until it’s pretty dark like it is right now.
I think this is 3 or 4 track days:
The Following User Says Thank You to norcalpb For This Useful Post:
NoHaveMSG (10-14-2020)
CSG Brake Thread - Expert Tuner/Motorsport Brake Advice & Experience CounterSpace Garage Brakes, Suspension, Chassis 14 10-23-2019 01:54 PM
Advice for leaked brake fluid from front lower caliper pin? EndlessAzure Issues | Warranty | Recalls / TSB 17 08-26-2019 09:11 PM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 04:59 PM
Local shop selling Motul 300V, high end brake fluid, etc. for track? mike_ekim1024 Northern California 12 03-09-2014 03:08 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 08:10 PM
