Old 10-13-2020, 09:02 PM   #1555
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Well, THAT sucks -
Im more mad that I won't hit 200k miles on the original motor. She was still purring at 175k, then CA ruined it for me
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
Clipdat (10-22-2020), humfrz (10-13-2020)
Old 10-13-2020, 09:10 PM   #1556
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Had the recall done early May. Last week the engine began knocking as I headed to Yosemite. Got it towed yesterday and they will begin teardown Friday it sounds like. They have already agreed to cover repairs and a rental car if its due to excessive sealant. Will update next week hopefully
I was around 3500 miles post recall.
That is just so wrong.
I hope you get a new motor out of it.
Old 10-13-2020, 11:40 PM   #1557
DarkSideFRS
Drives: 2013 pearl white FR-S
I have driven my car 600 miles post recall.. good thing I am selling it this weekend! No more headache!!!
DarkSideFRS is offline   Reply With Quote
Old 10-14-2020, 02:06 AM   #1558
finch1750
finch1750's Avatar
A buddy had his motor go having the recall done at the same dealership. He got a lower mileage used engine so that's what I am expecting at this point
Old 10-14-2020, 08:33 PM   #1559
gravitylover
You guys getting replacement motors are making me sad. My car is a planter in the driveway since my motor blew in August 13 months and 16k miles after the recall work was done. Trying to sell it but that's tougher than it should be with all the cars with dead motors now.
Old 10-14-2020, 08:51 PM   #1560
Worn rod bearings rattling until pressurized oil hits them. Your next stop on the fail train will be when that sound doesn't go away.
edit: I'm wrong here. Opie has MUCH more likely explanation below. Fits perfectly.
Originally Posted by Opie View Post
I would suspect that the timing chains tensioner was not adjusted correctly, the manual says something along the lines of "tension to the tightest notch, then go one notch further"...if not done correctly it causes the slack in the chains to tap when first started.
Never seen it cause any damage, but they'd need to pull the front timing cover to readjust them.
Well, dammit. I should've bet you a beer, or something. I remember also hoping that you were right.
Opie (10-15-2020)
Old 10-21-2020, 08:34 PM   #1561
finch1750
finch1750's Avatar
Screenshot from a video I was sent. They are claiming this is not enough sealant to cause starvation. Also pointed out that it is factory sealant as the recall uses gray sealant. Though that doesn't mean it isn't debris I guess
They are still doing more teardown to check internals. This is just what they got to so far
Old 10-22-2020, 04:46 PM   #1562
MikeMont
Drives: Black 2013 FRS
Spun Rod Bearing - 19 months and 20k miles since recall.
Vehicle Mileage: 88k
Vehicle Make: Scion FR-S 2013 MT
Mileage After Recall Performed: 20k
Symptom(s): Cruising on highway, engine knocking, then stalled. Would not turn over.
Failure: Spun Rod Bearing
State: Pennsylvania
Dealership Offering Repair: TBD. Recall done at Thompson Toyota, Doylestown, PA. Car is currently there, I’m awaiting further information.
MikeMont is offline   Reply With Quote
Old 10-22-2020, 05:02 PM   #1563
I think that's the downstream side. It looks like there could be significant buildup on the other side, no?
Old 10-22-2020, 05:05 PM   #1564
finch1750
finch1750's Avatar
its shadow on the right side. I could see it clear in the vid. Its just the little chunks on the edges
Ultramaroon (10-22-2020)
Old 10-22-2020, 07:29 PM   #1565
dasting
Drives: 2013 BRZ Limited
I thought the issue was two possibilities. It could also break off in the head and clog the return oil passages leading back down to the oil pan/sump, starving the crank.
Just because the sump isn't clogged doesn't mean the silicone at the valve cover gasket isn't blocking other areas. Right?
2013 BRZ Limited, NASA Instructor, ex-spec miata racer
dasting is offline   Reply With Quote
The Following User Says Thank You to dasting For This Useful Post:
Tcoat (10-27-2020)
Old 10-22-2020, 11:33 PM   #1566
finch1750
finch1750's Avatar
they are still tearing down the rest of the engine. here a another pic I was sent today and a zoomed in area that looked excessive to me. Im not sure what the lip looks like in person of if anyone spots something else I should ask for a better pic of
Old 10-23-2020, 12:39 AM   #1567
DarkSideFRS
And this was the reason I sold my car right after performing the recall... Didn't want to deal with this headache
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Clipdat (10-24-2020)
Old 10-23-2020, 03:51 PM   #1568
That doesn't look bad. Were the o-rings on the timing cover in place? Not distorted? If not properly seated on assembly, they pop out under pressure.
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
