Old 10-11-2020, 07:06 PM   #15
tjohnson104
Drives: brz
im torn. I would love to replace just the master cylinder, but the first few reply's from people think its a dead clutch. 2 very different, expensive, and time consuming things lol.
tjohnson104 is offline   Reply With Quote
Old 10-11-2020, 07:08 PM   #16
Ashikabi
Ashikabi's Avatar
MC definitely easier. Maybe Google will tell you how to diagnose MC leak
Sent from my ONEPLUS A5010 using Tapatalk
Old 10-11-2020, 07:11 PM   #17
Gloonge
Drives: 2013 frs raven
As far as I know the only way the clutch could cause this is if fingers on the pressure plate broke off, or the tob failed both of which you would hear. Clutch failure usually manifests in slipping not gear engagement failure.
You can also pickup a second hand master cylinder for less than $50 and replace it in under an hour.
Gloonge is offline   Reply With Quote
Old 10-11-2020, 07:15 PM   #18
Gloonge
Hallmark sign of internally failing MC is no loss of fluid and difficult or impossible shifting.
Old 10-11-2020, 07:22 PM   #19
tjohnson104
Drives: brz
thats what I am hoping for. I took it out, deep cleaned it and refilled. and still nothing.
If there was a leak inside of it or its just broken or whatever, would my clutch pedal feel normal? My pedal feels/felt normal
Old 10-11-2020, 07:29 PM   #20
Ashikabi
Ashikabi's Avatar
I think if you push it in and hold it in, then release, it will stay down of MC is bad. Because there won't be any pressure from the clutch to force it back
Old 10-11-2020, 08:03 PM   #21
Gloonge
The assist spring sends it back up.
Old 10-11-2020, 08:03 PM   #22
Ashikabi
Ashikabi's Avatar
Assist spring should hold it down
The Following User Says Thank You to Ashikabi For This Useful Post:
Ultramaroon (10-11-2020)
Old 10-11-2020, 08:06 PM   #23
Gloonge
The spring wants to be in its neutral position, without the mechanical leverage of your foot holding it down it will come back to center.
You also have to consider that the master cylinder has not completely failed its still retaining some pressure. As noted by him saying that he can see the fork moving. It's just not moving enough.
Old 10-11-2020, 08:24 PM   #24
No. It's an over-center mechanism, like a traditional light switch.
Even if the pedal is mushy, with a shitty cylinder on either end, you should still be able to give it a quick pre-pump just like with a failing brake master.
I vote for sticky pressure plate on the input shaft splines, or some other B.S. under the bell housing.
Old 10-11-2020, 08:39 PM   #25
TOB
It will still move but no longer throws out
Old 10-16-2020, 01:03 AM   #26
tjohnson104
Drives: brz
okay thank you everybody for all the insight. I am going to have a shop do the work this time around (pain in the ass first time). IF it is the clutch that needs a complete replacement, does anybody have good recommendations that will work fine with the SBD turbo? my current clutch is "competition stage 2" and i will stay away from this brand due to the early failure of this clutch.
Old 11-27-2020, 02:56 PM   #27
ls1ac
ls1ac's Avatar
What did the shop find out?
Old 11-28-2020, 11:07 PM   #28
tjohnson104
Drives: brz
not sure yet. its still sitting dead in the drive way. I actually last week replaced the master cylinder and that didnt fix it :/ so its most likely a clutch problem.
Im still researching what clutch to get.... so many damn mixed reviews about everything that is making it hard to decide. but I gotta take advantage of this black friday weekend sale lol
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-19-2020 12:43 AM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 08:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
