Old 10-10-2020, 09:02 PM   #1
tjohnson104
Drives: brz
will not go into gear!
Hello everybody.
So the other day my car died on me in the middle of the road. When I mean die I mean that it would not go into gear. Any gear. If the car is off it will easily glide into every gear just fine. Its only when the car is running that I can not go into any gear preventing me from moving. I started it in first and chugged my way home. Some times (once it is running) I could easily go to 2,3,4 but some other times it was almost impossible. I am talking about using 2 hands to yank it down from 1st gear into 2nd gear. I did some research and looked at the clutch master cylinder. I topped it off with fluid and it worked for about 1 hour worth of driving until it broke down again.
I took out the clutch master cylinder today and cleaned it because this YouTube video showed the same issue and that was what worked for him (it was dirty and fully of black gunk at the bottom) but once I filled it up and bled it I am having the same issue. Can not go into gear.
My car is turbo but I don't race or launch it.
My clutch is a competition stage 2 with lightweight flywheel (about 2-3 years old) and it has the Verus clutch fork
Before I swapped clutches I had the original throw out bearing go out and I remember how loud and awful that noise was. I do not have that now.
I don't have any odd noises besides the normal chatter sounds due to the light weight flywheel.
I am at a loss on what to check for next. It could be the master cylinder is dead even though the pressing the clutch the fork moves just fine.
If the car is running and I have clutch down, when I move the shifter knob to try and go into any gear, its like its just hitting a wall. I can feel it want to engage because it tries to grab on and pulls the car forward a tad bit.
I watched videos of a slipping clutch and I don't have that. I had plenty of power when I was making my way home once I got it into gear. I really dont want to drop the transmission and buy a new clutch kit.
Any ideas are greatly appreciated!
Thank you!!
tjohnson104 is offline   Reply With Quote
Old 10-10-2020, 09:04 PM   #2
Gloonge
Drives: 2013 frs raven
"If the car is running and I have clutch down, when I move the shifter knob to try and go into any gear, its like its just hitting a wall. I can feel it want to engage because it tries to grab on and pulls the car forward a tad bit."
This part tells me the clutch is not disengaging the engine. Master cylinder is probably bad if you didn't hear the clutch fork pop and you're not getting any tob noise.
Gloonge is offline   Reply With Quote
Old 10-10-2020, 09:06 PM   #3
Ashikabi
Ashikabi's Avatar
Originally Posted by tjohnson104 View Post
Hello everybody.
Thank you!!
Sounds like clutch to me. Something broke if the clutch fork moves fine then it's it's gotta be between the clutch and the transmission. I guess unless it's the transmission itself but I don't think so
Sent from my ONEPLUS A5010 using Tapatalk
Old 10-10-2020, 11:16 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
What 'stage 2' clutch do you have?
Old 10-11-2020, 12:59 PM   #5
tjohnson104
Drives: brz
the brand is competition.
https://www.ftspeed.com/part/fr-s-br...3#.X4M5uWhKhPY
I believe its this guy, unless they changed it through the years
When I ordered it, mine came with a lightweight flywheel as well
Old 10-11-2020, 01:39 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This really sounds like the car just isn't allowing the clutch to separate from the flywheel. Bring it to a shop and let them diag/fix the issue.
Old 10-11-2020, 01:50 PM   #7
Ashikabi
Ashikabi's Avatar
Right? Sounds like maybe the clutch itself is broken or the fork isn't moving far enough to actuate the clutch
Old 10-11-2020, 02:01 PM   #8
DarkPira7e
DarkPira7e's Avatar
Maybe if not the master cylinder, the clutch fork is getting very weak and only actuating intermittently, like a real fork that's been bent back and forth a bunch and is about to fail, but physically is still held together
Old 10-11-2020, 02:02 PM   #9
Ashikabi
Ashikabi's Avatar
Pretty sure he said he has the Verus fork
Old 10-11-2020, 02:06 PM   #10
DarkPira7e
DarkPira7e's Avatar
Ah yup. Then it's got to be the master cylinder. Unless he's neglecting to mention that his clutch pedal is stuck to the floor
Ashikabi (10-11-2020)
Old 10-11-2020, 05:32 PM   #11
tjohnson104
Drives: brz
yeah I do have the verus fork and pivot ball as well.
No, the pedal is working just fine. Its not getting stuck and feels normal as it always has.
Old 10-11-2020, 05:33 PM   #12
Gloonge
I thing fluid is escaping around the piston inside the cylinder. I would hit a junk yard and grba one for cheap to test.
Old 10-11-2020, 05:37 PM   #13
Ashikabi
Ashikabi's Avatar
I literally just threw mine away. RIP
Old 10-11-2020, 05:45 PM   #14
Gloonge
F
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-18-2020 11:43 PM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
