Old 10-06-2020, 01:23 PM   #211
sato
sato's Avatar
Drives: Dodge Patitas
So, power was cutoff at 6600rpm, more or less? The effect looks similar to the crawford power blocks. If it has a full exhaust, then how can we tell those results are direct result of the ITB? Any before Dyno results for comparo on that page?
sato is offline   Reply With Quote
Old 10-06-2020, 03:03 PM   #212
PulsarBeeerz
Drives: JRSC BRZ SOLD
The before and after dyno is shown. It had a full exhaust and was tuned then they added the ITBs and tuned them.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
sato (10-07-2020)
Old 10-06-2020, 06:20 PM   #213
Tokay444
Juice ain't worth the squeeze folks.
Old 10-06-2020, 07:43 PM   #214
PulsarBeeerz
I think most had come to that conclusion with the lack of results awhile ago. I will say they seem work better without a plenum but require a standalone to be optimized.
Old 10-06-2020, 10:17 PM   #215
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by PulsarBeeerz View Post
I stand corrected. IIRC the one who lost power may of had cams. Here is an otherwise stock long block with a full exhaust on 93 using the supplied IM.
You'll have to do some sifting but the info is there.
https://www.facebook.com/groups/NaturallyAspirated86
I don't think its a total loss. It looks like a solid torque increase up until 6k rpm. The car would probably be noticeably quicker than stock. If you had the time to play with runner lengths and maybe even the throttle size i am sure you could shift the torque higher and make more power.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
Hades (10-07-2020), Lantanafrs2 (10-07-2020)
Old 10-06-2020, 10:48 PM   #216
PulsarBeeerz
One of the owners agree with that sentiment. The other one says he is determined to extract more from them so how.. Presently both used the supplied IM so I don't think they can play with runner lengths. It's pretty obvious the butterflies are undersized for a 12.5:1 comp 2.0l engine and unfortunately the TBs are already bored over from the original 45mm to 48mm so there isn't much material left to get to 50-52mm. However like I said earlier with a standalone and runners open atmosphere they start to makes more sense. This was on 94oct.
Old 10-07-2020, 09:48 AM   #217
sato
sato's Avatar
The those are some nice gains indeed!
The Following User Says Thank You to sato For This Useful Post:
Hades (10-07-2020)
Old 10-07-2020, 05:13 PM   #218
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Yea, that actually looks pretty good. Sure, we all want more peak power, but the powerband is wider & stronger which would result in a quicker car. Downside is less high RPM fun... perhaps with some further tuning/development we could see better results up top.
Hades is offline   Reply With Quote
Old 10-08-2020, 09:11 AM   #219
Tokay444
Needs larger diameter throttle bodies.
The Following User Says Thank You to Tokay444 For This Useful Post:
nikitopo (10-09-2020)
Old 10-10-2020, 02:24 PM   #220
PulsarBeeerz
Correct, as I said earlier..
However at that point you might as well make your own custom kit and forgo the Greedy kit completely as you wouldn't be using much of it at all. Past racing classifications and novelty the cost to source50-52mm ITBs for this layout for the mid-range and last 10whp NA one could build a legit 2.2-2.4L for the same cost and not need a standalone to run it.
Old 10-10-2020, 10:40 PM   #221
Turdinator
Señor Member
Turdinator's Avatar
Why do you think that and not different runner lengths?
1974 TA22 Celica
2013 86 GT
Old 10-11-2020, 12:52 PM   #222
Tokay444
Because the restriction is in the diameter.
Old 10-11-2020, 09:16 PM   #223
Turdinator
Señor Member
Turdinator's Avatar
It seems like they are using 4AGE 20v ITBs. The start of the thread lists the throttle sizes as 45mm for the Sard and 48mm for the Greddy. I would have thought the 48mms would be enough for this motor. Do we know which was used in for this dyno? The Sard does seem to have a greater volume plenum and shorter runners which I think would be preferable. Maybe a mix and match would net better results. I also know you can get 50mm TBs from people like Toda. So if its only the TB size that is restricting things there are ways around that if you are prepared to spend a little extra.
1974 TA22 Celica
2013 86 GT
Old 10-11-2020, 09:29 PM   #224
Tokay444
54mm should be the minimum.
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 669 06-07-2020 06:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 04:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 12:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 01:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
