Old 08-29-2013, 11:09 AM   #15
Dipstik-sportech
Dipstik-sportech's Avatar
http://www.wallaceracing.com/0-60_equation.php
Based on my times with drag radials on an shit track my 0-60mph was 3.5ish seconds. I'll us my phone app and try on the street with the stock tires for fun
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
gt8613 (08-30-2013)
Old 08-30-2013, 12:46 AM   #16
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by StickThatClutch View Post
Hard to say.
Well getting away from a stand still with the manual still requires applying some throttle, unless you let the clutch out real slowly without throttle then mash the gas when it catches. If you did that the auto would probably be a car or two ahead of you before you could apply 100% throttle.
If you held the revs at say 1500 or so just so the car didn't bog when you dumped the clutch might be pretty close, if the auto just mashed the gas from a dig.
I don't think being in manual mode will help the 0-60 time in the auto. It should shift at redline just as fast under full throttle as it does in manual mode.
Drive safe.
What in God's name are you talking about
Sent from my SCH-I545 using Tapatalk 4
DoomsdayJesus is offline   Reply With Quote
Old 09-02-2013, 08:09 PM   #17
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Originally Posted by KelvinBRZ View Post
Would an automatic on manual mode have the same 0-60 times as a manual (assuming driver in manual does not build RPMs & drop that clutch)?
No - the automatic is geared for fuel economy. 4th gear is 1:1 ratio in the 6AT, whereas 5th gear in the 6MT is 1:1.
The gear ratio is responsible for what rpm the engine is at, in a given gear at a given speed. So you can cruise at 60mph in 6th gear in the 6AT, and be turning less engine rpms than 6th gear in the 6MT. The ratio is torque multiplier - and the auto has less torque multiplication per gear.
Also, automatic transmissions tend to "eat" a bit of hp, so 200hp at the crank will lose more when it gets to the wheels of the 6AT than the 6MT.
Long story short - that's why the 6AT is a full second slower to 60, but also why it gets 4-5mpg better than the 6MT.
ashtray is offline   Reply With Quote
Old 09-02-2013, 09:37 PM   #18
Suberman
Drives: Subaru BRZ Sport Tech Satin White
The new computer controlled lock up automatics are more efficient than a manual box because the planetary gearset uses less energy and the lockup clutch takes the torque converter out of loop.
The automatic could be quicker than the manual if the ratios were correct, but that would never do or a sportscar.
BMW now fits the ZF 8 spd automatic to many models because it is quicker and uses less fuel.
Suberman is offline   Reply With Quote
Old 10-06-2020, 03:05 PM   #19
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
No it had to do with NOT being able to launch the auto from a dig
ojuniour is offline   Reply With Quote
The Following User Says Thank You to ojuniour For This Useful Post:
Dadhawk (10-06-2020)
Old 10-06-2020, 03:17 PM   #20
I agree. The AT will do 60 in second gear, saving a shift over the MT. Also, if I remember correctly the 5-60 rolling start times are similar. I believe with a decent launch control the AT would be much closer to the MT in 0-60, if not better.
Old 10-07-2020, 08:25 AM   #21
Baldeagle
Drives: VW GLI 6MT
https://www.motortrend.com/cars/suba...ic-first-test/
Baldeagle is offline   Reply With Quote
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Fun times John.Hong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 07-24-2013 03:46 AM
0-60mph Times boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 81 03-03-2013 02:43 PM
How many times have you been pulled over? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 71 11-28-2012 11:28 AM
Visconti 0-60 times cuddefred Engine, Exhaust, Transmission 0 09-26-2012 08:06 PM
