Old 10-01-2020, 09:20 PM   #3921
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by ShibusaTouge View Post
My FRS weighs about 2300 lbs (fully gutted, caged, no ac). And it's about ready to go on the road. Would I need to order custom valved/dampened/spring rate coilovers due to change in weight distribution and weight overall?
Get somemthing OTS that can be revalved later down the line. You can do all the calculations and obsess over it before even testing, or get the ball rolling asap.
I myself spend countless hours devising what I would think make an existing 2 way shock work. Did all the work and then some. Threw them on the dyno.. Turns out the compression adjustment dont add anything but extra hysterisis... Wasted time and energy that I could have just avoided had I not been so obsessive about details.
Edit:
Rebound adjuster.. not bad not as digressive as I would have liked
"Compression adjuster" response...
Hmm.. the pictures are not showing?
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
strat61caster (10-02-2020)
Old 10-02-2020, 09:23 AM   #3922
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
Originally Posted by Takumi788 View Post
Still need to know how you got down to 2300 lbs with a cage! lol. I am out of things to remove and apparently my car is still fat.
Cut out all the metal from the doors, tomei since it's the lightest, carbon roof, carbon trunk, mph fab hood, essex sprint bbk, "swiss-cheesed" where applicable
ShibusaTouge is offline   Reply With Quote
The Following User Says Thank You to ShibusaTouge For This Useful Post:
Old 10-04-2020, 12:43 PM   #3923
Alarik
Drives: BRZ '13
Need an advice about further suspension spec. What we've got now is 2013 brz on stock shocks and Eibach sportline springs +camber bolts on front(-2 camber atm). This car is mainly used for track days and i don't care about ride comfort, only performance matters There're still a lot of things to be done with the car for track days besides the suspension so the question is should i go for some kind of coilovers like BC racing DS series or they aren't worth it and it's better to buy new B6 for my Eibach springs and save money for other mods?
Alarik is offline   Reply With Quote
Old 10-04-2020, 04:05 PM   #3924
churchx
churchx's Avatar
Drives: 2014 GT86
Alarik: more, more, MORE camber, if for track. Move up to -3 to -4 in front, depending on tires/track.
Old 10-04-2020, 04:48 PM   #3925
Alarik
Drives: BRZ '13
Easier said than done, it's almost max camber with this spec. That's one of the reasons for BC's coz i'll get camber adjustments
Old 10-04-2020, 05:07 PM   #3926
churchx
churchx's Avatar
Drives: 2014 GT86
You can add front camber with stock shocks if you add eg. pedders eccentric rubber topmounts and/or powerflex front lca rear bushing on top of camberbolts. Or camberplates.
Old 10-05-2020, 01:26 AM   #3927
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
If you want to read about weight loss you should have a read of this thread.
His second post in the thread details all the weight savings.
CSG Mike (10-14-2020)
Old 10-05-2020, 06:43 AM   #3928
new2subaru
Weight Weenie
Drives: 15 FR-S
And this thread. @SuoerTom is doing a great job with his build.
https://www.ft86club.com/forums/showthread.php?t=118243
Old 10-05-2020, 07:21 AM   #3929
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I attached that exact thread and mentioned it in my original question on the last page of this thread. lol. That thread is bookmarked
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Captain Snooze (10-14-2020)
Old 10-05-2020, 09:41 AM   #3930
Racecomp Engineering
What other options do you have?
What kind of tires do you use?
- Andrew
Old 10-05-2020, 10:50 AM   #3931
Alarik
Drives: BRZ '13
- Andrew
atm only spec that i described +intake, if it matters. But i got plans to reduce weight a bit, headers+exhaust and dyno tune. Wheels 7.5J, tires Federal RS-RR\Rs-Pro, Hankook RS4 215 or 225 width, depends on local series regulations.
Old 10-05-2020, 11:22 AM   #3932
Sorry I meant what other choices for suspension do you have? KW maybe?
- Andrew
Old 10-05-2020, 11:42 AM   #3933
Alarik
Drives: BRZ '13
- Andrew
Oh, my bad KW, ST, Eibach, Bilstein and Tein can be bought here, i guess. Something else will require shipping from US +taxes.
Old 10-05-2020, 11:45 AM   #3934
Most of those (including Tein) are much better than BC. We like KW and Bilstein a lot but they don't always come with camber plates.
- Andrew
Alarik (10-06-2020)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
