Old 09-26-2020, 09:24 PM   #18705
norcalpb
norcalpb's Avatar
Be prepared to to possibly add endplates or dive planes to go with the wing.
Oh yeah I forgot about the dive planes. I’ve been holding off on those until now to avoid moving the aero balance too far forward. Luckily I have the end plates already but they are hard to see in the pic. Little mpg killers those are.
Depending on how big of a wing I get, I may install splitter diffusers. How do you feel about the Sard reps? $1k cheaper than the Verus small wing but I know one is obviously way better than the other...
Old 09-26-2020, 09:30 PM   #18706
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am not familiar with the Sard rep wings. I have the APR GTC200, it is under 1K and works very well. I have it at the minimum AOA the included brackets will allow and it understeers without endplates and dive planes. Wanted the Verus wing but 1900 was a little too hard to justify.
https://www.counterspacegarage.com/a...g-brz-frs-gt86
norcalpb (09-27-2020)
Old 09-28-2020, 12:39 AM   #18707
HaXx
Drives: jrsc_brz
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following 4 Users Say Thank You to HaXx For This Useful Post:
JD001 (09-28-2020), MJones_RB (09-28-2020), new2subaru (09-28-2020), soundman98 (09-28-2020)
Old 09-29-2020, 10:30 AM   #18708
LancePower
Drives: 2020 BRZ tS
Originally Posted by marky View Post
put Red Vinyl Pinstriping my aero kit
Tell us more.
What exactly is it?
Where did you get it?
How does it go on? Adhesive, snap over?
How is the color match to Cherry Blossom?
LancePower is offline   Reply With Quote
Old 09-29-2020, 10:46 AM   #18709
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
My hood would lift when the little rubber height adjusters were set too low. Maybe yours weren’t fully adjusted from the factory. Try shaking your hood from where it hangs over the headlight. It shouldn’t move at all.
I'll be damned if this didn't calm down most of the hood lift. It still ever so slightly lifts at higher speeds now, but doesn't lift near as much as it did before. Thanks, norcalpb.
The Following User Says Thank You to dragoontwo For This Useful Post:
norcalpb (09-29-2020)
Old 09-29-2020, 08:41 PM   #18710
HaXx
Drives: jrsc_brz
here she is
The Following 11 Users Say Thank You to HaXx For This Useful Post:
Baldeagle (10-01-2020), BirdTRD (10-02-2020), Busybee (10-08-2020), DarkPira7e (09-29-2020), dpfarr (09-29-2020), JD001 (09-30-2020), marky (09-30-2020), MJones_RB (09-30-2020), new2subaru (09-30-2020), norcalpb (09-29-2020), thomasmryan (10-21-2020)
Old 09-30-2020, 10:07 PM   #18711
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Originally Posted by LancePower View Post
Tell us more.
What exactly is it?
its just red.. cant find a cherry blossom to match but it looks good in person tho.. if you find a cherry blossom let me know
its a adhesive tape.. works good just need to clean and wipe before putting it on.. sticks good and comes off easy and dont leave any sticky residue
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Following User Says Thank You to marky For This Useful Post:
LancePower (10-01-2020)
Old 10-03-2020, 07:18 PM   #18712
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Swapped the STI brake pads for O.E. because the squeaking was not worth it for the daily drive. Also my HOA complained lol
MS, CSCS, TSAC-F, CPT
Old 10-03-2020, 09:00 PM   #18713
soundman98
ProCrastinationConsultant
soundman98's Avatar
I would leave them in just for the HOA
Old 10-04-2020, 01:40 AM   #18714
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Changed my engine oil and differential oil today. Here is what my differential drain plug looked like with 32k miles.
Oxyg3n is offline   Reply With Quote
Old 10-04-2020, 03:32 AM   #18715
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Can you suggest any of the STI parts that is definitely worth the installation without sacrificing the daily drivability of the car?
Old 10-04-2020, 05:48 AM   #18716
LancePower
Drives: 2020 BRZ tS
Those must have been some crazy aggressive pads.
I know they are JDM, but are they sold as "street" pads or "race" pads?
Old 10-04-2020, 05:51 AM   #18717
LancePower
Drives: 2020 BRZ tS
Can go wrong with the Body Kits pieces.
STi/tS Springs
I have the Short Shifter and Trans Mount.
The Following 2 Users Say Thank You to LancePower For This Useful Post:
Busybee (10-08-2020), nikitopo (10-04-2020)
Old 10-04-2020, 09:20 AM   #18718
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I believe lowering springs and front lip compromise ride height and clearance on speed bumps.
