Old 09-30-2020, 02:07 PM   #22373
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Originally Posted by thekevinvo View Post
Installed the Verus Engineering brake cooling kit today
Love your videos. Very concise!
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
beltax90 (09-30-2020)
Old 09-30-2020, 09:21 PM   #22374
Originally Posted by WNDSRFR View Post
Changed my battery today.
Forgot about the cigarette lighter trick so I had to reset the clock, radio presets, rev limit and light and the gear indicator. Why is the default for the gear indicator "off" anyway? Why would anyone not want to know what gear they're in?
After I reset everything I still had the tire low pressure light on. I figured "maybe I have to drive a while and it will go off." Nope.
Maybe I have to turn the car off and restart it. Nope.
Maybe a tire is low. Yep
All 4 tires were low. How did changing the battery decrease the pressure in all the tires?
It didn't.
It was a complete coincidence that the light came on after changing the battery.
What happened is.....
It's been about 95 degrees everyday for as long as I can remember. Today it's 70 degrees.
I'll bet in a couple days when it's 95 again my tire pressures will be over 35 PSI.
Because ........ iffen you're driving a MT car and you don't know what gear you are in ...... you should be drive-en an AT car -
UNLESS you are over 75 years old and in that case, it would be handy so as you don't try to start off in 3rd gear - my FR-S don't like that -
Wally86 (10-01-2020)
Old 09-30-2020, 10:33 PM   #22375
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Installed a Perrin tube-y thinger
And installed some smoked side marker thingers lol
Sent from my iPhone using Tapatalk Pro
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
JesseG (09-30-2020), MJones_RB (10-01-2020), pallen (10-01-2020)
Old 10-01-2020, 11:47 AM   #22376
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Clutch replacement at 74k miles, $1350
Spark plug change, $550
I knew the plugs wouldn't be cheap, but dayum!
Sent from my moto g(8) power using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following User Says Thank You to jeffchap For This Useful Post:
humfrz (10-01-2020)
Old 10-01-2020, 12:18 PM   #22377
DarkSunrise
DarkSunrise's Avatar
Ouch! Are those dealership prices?
2022 BRZ Build
2013 FR-S Build
Old 10-01-2020, 12:19 PM   #22378
jeffchap
jeffchap's Avatar
No, a private repair shop I've used for 20 years. They are *always* cheaper than the dealership.
Old 10-01-2020, 12:38 PM   #22379
DAAAAMN - I reckon when my 2013 gets to needing that, I'm just going to trade it in -
Old 10-01-2020, 12:49 PM   #22380
jeffchap
jeffchap's Avatar
Had I checked in advance what it was going to cost, I would've traded mine too before the clutch went out. I didn't expect it so soon. I've always driven Hondas prior to this car and I've *never* replaced a clutch before. I've put up to 200k miles on some of them. I knew the plugs would need replacing at some point, but for some reason I had 100k in my head. It's actually 60k.
The Following 2 Users Say Thank You to jeffchap For This Useful Post:
humfrz (10-01-2020), MJones_RB (10-01-2020)
Old 10-01-2020, 01:50 PM   #22381
DarkSunrise
Ah got it. I had quotes a bit less than that when I had my clutch done, but worth it if you’ve got a shop you trust and takes care of you. Great feeling having a smooth quiet clutch!
2022 BRZ Build
2013 FR-S Build
Old 10-01-2020, 05:25 PM   #22382
MJones_RB
MJones_RB's Avatar
Clutches generally last around 60k. Honda clutches are pretty robust. My GS-R went to 90k before I had to change mine out. I'm not sure if RWD cars wear their clutches out faster.
Old 10-01-2020, 06:44 PM   #22383
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Installed ejecto seato in my car lol
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
bcj (10-09-2020), MJones_RB (10-02-2020), Ultramaroon (10-08-2020)
Old 10-01-2020, 11:28 PM   #22384
arxm
Drives: 2013 FR-S, 2023 BRZ
flushed my clutch fluid, best thing i ever did lol
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 10-02-2020, 10:03 AM   #22385
HaXx (10-08-2020), ichitaka05 (10-02-2020), soundman98 (10-02-2020)
Old 10-06-2020, 03:42 PM   #22386
thekevinvo
Drives: 2014 Scion FRS
Installed the Verus Engineering Hood Louvers today!
thekevinvo is offline   Reply With Quote
The Following 3 Users Say Thank You to thekevinvo For This Useful Post:
beltax90 (10-07-2020), jcw99 (10-07-2020), MJones_RB (10-08-2020)
