Old 09-30-2020, 02:39 PM   #1
ThaDonJsuan
Drives: 2020 Subaru BRZ Sport-tech
How often do you get an OIL change when tracking weekly?
Hi all,
I am new to track driving (I have a stock BRZ).
How often should I get an oil change if I am tracking once a week? (with little to no driving in between/during the week).
Some people I met said every 3 track days. Does that make sense?
Thanks.
ThaDonJsuan is offline   Reply With Quote
Old 09-30-2020, 02:50 PM   #2
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Get an oil analysis and determine based off of that. Are you running an oil cooler and keeping your oil temps in check?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
The Following 3 Users Say Thank You to the new guy For This Useful Post:
NoHaveMSG (09-30-2020), soundman98 (09-30-2020), x808drifter (09-30-2020)
Old 09-30-2020, 03:02 PM   #3
ThaDonJsuan
I typically only do 2 or 3 hot laps and then cool off for 15-20 minutes (thats what I was told). I also check the oil before each track day for volume and color - but I don't know of any other special sort of analysis. I don't think I have an oil cooler since the car is stock - or could it have come with an oil cooler?
Old 09-30-2020, 03:40 PM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@ThaDonJsuan
Based on experience, I've been able to go 2-3 track days plus full mileage interval confirmed with oil analysis.
However, it will depend on the tracks and your local conditions. Best bet is to do 2 track days and get an oil analysis (where you send an oil sample to a lab for longevity/lubrication analysis & results). From there, adjust how much more you're comfortable with.
FRS/BRZ/86 don't come with an oil cooler from factory. It is recommended you install an aftermarket one. Oil thinning due to high oil temperature is a key concern on this car when driven on the track; has led to many-a blown engines. This doesn't have to do with cooling-off post session. It happens in the middle of your session, when you're running hard and load/revs/temperatures are at peak. If you're approaching 260F/126C, it's time for a cool-down lap MID SESSION.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Old 09-30-2020, 05:16 PM   #5
PenGun
Drives: Red 2019 Subaru BRZ
I have to say after my first oil change: Damn that's easy.
I have ramps and tools, and it was so nice to just spike the oil filter with a screw driver and twist it off while standing there.
PenGun is offline   Reply With Quote
The Following User Says Thank You to PenGun For This Useful Post:
Old 09-30-2020, 05:22 PM   #6
Jdmjunkie
Drives: Scion FR-S 10 Series
https://www.blackstone-labs.com/test...dard-analysis/
Jdmjunkie is offline   Reply With Quote
The Following 2 Users Say Thank You to Jdmjunkie For This Useful Post:
Old 09-30-2020, 05:23 PM   #7
ThaDonJsuan
Originally Posted by EndlessAzure View Post
@ThaDonJsuan
Thanks for this info - that's new to me. I'll look into getting an after-market oil cooler as I certainly don't want to blow my engine!
Old 09-30-2020, 05:31 PM   #8
86league
Drives: '13 BRZ Limited
For another data point - I have Blackstone analysis after 6 track weekends (so 12 days of 4 ~20 min sessions each) and about 4000 mi total. They saw no reason I couldn't go to a longer oil change interval.
86league is offline   Reply With Quote
The Following User Says Thank You to 86league For This Useful Post:
Old 09-30-2020, 06:05 PM   #9
ThaDonJsuan
Just wondering - do you have an oil cooler? can you suggest any brands?
Old 09-30-2020, 06:11 PM   #10
EndlessAzure
Wheels for Brains
@ThaDonJsuan
For my first ~6 track days, I didn't have one, though I was diligent about watching my oil temperature on track.
Now, I have an oil cooler. I went with the Blitz Racing Oil Cooler RD.
There are others out there that will do the job. Depends on your budget and what design/style/features you're looking for. Brands that come to mind: Blitz, Greddy, HKS, JDL, Jackson Racing, Perrin. Mishimoto is okay on a budget, but I would personally spend a little more based on leaks and failures I've seen on theirs.
For kits similar to Jackson Racing and Perrin, you can likely source all the pieces yourself (like the radiator core, hoses, fittings, thermostatic adapter plate) and assemble them yourself for a little cheaper. There are threads on this forum describing that.
Old 09-30-2020, 09:50 PM   #11
Code Monkey
Drives: Subaru BRZ
I change mine every 3 track weekends, which is usually about 2,700 miles.
Code Monkey is offline   Reply With Quote
Old 09-30-2020, 10:04 PM   #12
new2subaru
Weight Weenie
Drives: 15 FR-S
I change mine every 3rd track day. I get Mobil1 on sale for $30 CDN for 4.78L In total I spend about $35. I change the filter twice annually for $12-15 on sale.
The test is $30 USD...
Old 09-30-2020, 11:01 PM   #13
86league
I do have an oil cooler. Got the Jackson racing radiator/oil cooler because I was convinced when I got the car that I'd probably get a supercharger and that one integrated well with and intercooler.
I never did get a supercharger - waaaaaay too many track acquaintances blew their engines with FI. Staying NA ones seem /more/ reliable and it's fun driving a slow(er) car fast.
The JR dual radiator/oil cooler kept my oil temps below 238F on track even when it was in the high 90s ambient. Seemed to work well, but it's not the most budget friendly option out there.
Old 09-30-2020, 11:37 PM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
I change oil after 2 events, 4 track days (~4x 15-minute stints per day).
I don't run an oil cooler, and I run 5w30 synth.
Oil temp stabilizes at ~272F indicated on the factory gauge, I've never seen it go up from there no matter what the ambient temp.
Tracking the F's Gearbanger Tracking / Autocross / HPDE / Drifting 13 08-07-2016 06:42 PM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Weekly Cruise-In in NEO! HunterGreene Great Lakes 2 05-07-2014 02:03 PM
Oil and tracking? SavingManuals Scion FR-S / Toyota 86 GT86 General Forum 11 07-04-2013 06:38 AM
Who's tracking their BRZ? random hero BRZ First-Gen (2012+) — General Topics 11 08-20-2012 11:30 PM
