Old 09-28-2020, 02:55 PM   #72857
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
First off, there are meds for that.
Second off, I suggest you take a weekend for your drives. Sleep in on Saturday, get up, take a Prozac, drive to the Hill Country, drive around a bit, get a motel room, take a nap, eat supper, take an evening drive.
Sunday morning, get up, drive around the Hill Country, have lunch, head back to Austin.
There ya go, having fun and relaxing -
Thats the thing. It was a Sunday evening. It shouldn't have been so busy
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following User Says Thank You to weederr33 For This Useful Post:
humfrz (09-28-2020)
Old 09-28-2020, 03:31 PM   #72858
OK, plan B - move to Arkansas -
humfrz is offline
p1l0t (09-28-2020)
Old 09-28-2020, 03:37 PM   #72859
Can you drive after taking Prozac?
I can -
humfrz is offline
JD001 (09-28-2020)
Old 09-28-2020, 03:39 PM   #72860
JD001
JD001's Avatar
Drives: Subaru BRZ
I can -
Ermmm... I think there are some side effects, reversing becomes a small problem.. it's in the small print.
JD001 is offline
The Following 3 Users Say Thank You to JD001 For This Useful Post:
humfrz (09-28-2020), NoHaveMSG (09-28-2020), soundman98 (09-28-2020)
Old 09-28-2020, 04:05 PM   #72861
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is retractable! I bring it up for trailering and beaching but it's a 3ft keel when it's down. This boat is nearly impossible to flip when it's down.
It's an 8" draft retracted and 3ft extended
That makes sense now. I thought only really tiny boats had that but it's apparently more common than I thought.
Also, challenge accepted.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
p1l0t (09-28-2020)
Old 09-28-2020, 04:13 PM   #72862
p1l0t
p1l0t's Avatar
Well it's only a 15ft boat so it is pretty small.. it does have a little cabin though (you can only sit not stand though inside). I've been as far as 35 degrees over, which is nothing really. Megan starts to freak out 20 degrees which is optimal really though for speed. I even get a little nervous after 30 though. At that point it's probably over powered anyway though. My inclinometer goes up to 50 degrees and I suppose* it's relatively safe up to almost 90 degrees as long as you don't fall into the water, haha. Which is most what scares Megan. She does better when she is sitting on the high side of the boat. Most wind I've really been out in is about 15kts though..
p1l0t is offline
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
NoHaveMSG (09-28-2020), soundman98 (09-28-2020), Spuds (09-28-2020)
Old 09-28-2020, 04:18 PM   #72863
hmmmm......I never read the small print on medications - it's too scary -
humfrz is offline
JD001 (09-28-2020)
Old 09-28-2020, 04:23 PM   #72864
The best part is the replacement core doesn't come with the proper outlet tubes, they are only available from Nissan as far as I can tell. Guess which part of it is leaking ? I will be keeping a piece of 3/4 tube and a couple hose clamps in it just incase
That dreaded statement from the parts guy, "No longer available."
Ultramaroon is offline
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
NoHaveMSG (09-28-2020), soundman98 (09-28-2020), Spuds (09-28-2020), Tcoat (09-28-2020)
Old 09-28-2020, 04:32 PM   #72865
Spuds
The Dictater
Spuds's Avatar
All reminding me that I need a boat...
Spuds is offline
p1l0t (09-28-2020)
Old 09-28-2020, 04:36 PM   #72866
Spuds
The Dictater
Spuds's Avatar
Talking about TVs, we had a very amusing story this week...
https://www.google.com/amp/s/www.bbc...wales-54239180
Is this the first time you are mentioning it? I swear I read or heard something about this at some point last week.
Spuds is offline
JD001 (09-29-2020)
Old 09-28-2020, 05:22 PM   #72867
Many schooners up to 150 feet had them. Some went down 30 feet. Used them in the ocean but could then come right into shore and up rivers.
Tcoat is offline
p1l0t (09-28-2020), Spuds (09-28-2020)
Old 09-28-2020, 05:54 PM   #72868
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Can't hardly walk today WTF
NoHaveMSG is offline
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
humfrz (09-28-2020), p1l0t (09-28-2020), soundman98 (09-28-2020)
Old 09-28-2020, 07:30 PM   #72869
Something that the dude asking if he should buy an RX-8 would hear. ALOT!
Tcoat is offline
soundman98 (09-28-2020), Ultramaroon (09-28-2020)
Old 09-28-2020, 09:18 PM   #72870
I used to have days like that -
humfrz is offline
NoHaveMSG (09-29-2020), p1l0t (09-28-2020)
