#15 |
Because compromise ®
Drives: Red Herring
Might there be an option for 2 piece rotors for the Sprint kit?
#16 |
Drives: 2jz
here's a question
By upgrading the front brakes and leaving the rear ones stock, will this disturb the brake distribution balance in the car ? I am aware that front brakes cop most abuse |
#17 |
Drives: Lots of Toyota
AP Racing makes real performance BBKS!
#18 |
Drives: BRZ WRB
Nice to hear that the dust seals would be an option, cause we live in a dirty world )
Also would it be an option to have the non-full-floating discs, as they claim to squeal on low speed ? Or maybe you could provide a set of bobbin springs to carry this full-floating-peculiar squeal and shudder away under low-load conditions? |
#19 |
Drives: scion fr-s (RIP)
umm yup you can sign me up for this kit asap!!!
#20 |
Drives: 2012 86GTS Race Car #86
I like these brakes and I am in .... provided they fit under the 17" rims.. Our production racing rules mean keeping to specs so if there is another 17" or I need a 35 - 38 offset no probs. Keep me on the list for your first production run.. Mine is in for the cage next week !! Any time frame for manufacture .. delivery??
Chris |
#21 | ||||||||||
Drives: 2012 BRZ Premium WRB 6MT
The smaller, 4 piston, front Formula system will clear the stock wheel. Quote:
Also, we need to be clear on what exactly we're talking about. Dust boots are the little rubber bits out on the edge. I'll try to dig up some pics and post them so this is clear. The calipers in our competition kits have high temperature seals that prevent debris from getting down alongside/behind the pistons. There shouldn't be any concerns about them getting contaminated and having to rebuild them constantly. People who only sell street brake systems try to scare people about this issue, but it just isn't the case. We have hundreds of vettes, evo's, sti's, M3's, etc. running our CP8350's under all types of harsh environments (think summertime at Willow Springs, with dust and dirt everywhere), and we haven't had a single claim of any debris getting into piston bores. Also, if when it does come time to rebuild calipers, we offer a caliper certification service (we are AP's exclusive rebuild center in North America). You just pull the calipers, send them to us, we freshen them, and send them back. You don't even get that dirty. At any rate, dust boots are only useful up to the point where you incinerate them, which in some cases is as soon as you take the car on the track. So, if you only ever plan to drive on the street, they are a great addition. But if you plan to wail on the car at the track, they may not be of any value to you at all. Quote:
![]() Quote:
The Sprint system will have a fixed hat as described above, and will therefore not have any rattling noise or NVH. Squealing is typically a function of pad noise, and how the hat is mounted wouldn't typically have any impact on squealing noises. Shudder or judder would usually be created by uneven pad deposits on the disc. Our systems don't have any judder or shudder through the pedal. That would usually only occur if you overheated the pad material and smeared it on the discs in an uneven fashion. Quote:
Both of the Competition systems (Endurance and Sprint) will fit under many aftermarket 17" wheels. That was a high priority during development, as we knew those most interested in these kits would be wanting to run the smallest, lightest wheels possible. On our car we will be running them under 17" Enkei RPF1's, and they should clear many other 17's without any problem. We already have wheel fitment templates drawn for these kits, which will allow you to check a specific wheel for clearance. I'm reluctant to post them on our site until we've completely finalized design, since the offsets could change slightly if we need to make a revision to the kit after test fitting the prototypes. We're supposed to test fit later this week, so I can post the templates as soon as we've verified fitment or decided to make any changes. That means you could order wheels, or confirm fitment on existing wheels, as early as next week. After test fitment these will go into production. It will likely be 6-8 weeks after that before everything is manufactured and ready to ship. Therefore, I'm hoping these will be on cars by early September. Quote:
Black Friday 2025 at Essex/AP Racing is 11/10 - 12/5/25!
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 07-26-2012 at 08:51 AM. |
| The Following 3 Users Say Thank You to JRitt For This Useful Post: |
#22 |
Drives: Brz, Legacy
Great. Decision on brakes made
Trackday ride with built motor
Mods: Going, Stopping, Handling Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX |
#23 |
I just pulled together a quick summary of the fixed vs. floating attachment systems. Hopefully that adequately explains how the systems differ and work:
http://www.essexpartsblog.com/news/f...ng-brake-discs
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() |
#24 |
Drives: Attitude
When I say dust seals I mean piston boots. I'm aware they burn up, but a boot-less design leaves me scared of road debris (95% street driving!) destroying the piston bore seals and scarring the bores themselves. You're marketing to a more hardcore crowd; I both understand AND respect that. It's just that when I want to upgrade (let's be real, floating calipers look stupid) I want it to be a functional upgrade and I'll pay for that functionality.
Is there a weight difference between the fully floating discs and the fixed aluminum hat discs? |
#25 | ||
Formula Front System 1: Four piston, 343mm x 26mm disc, painted red, black, or silver. Fits under OEM 17" wheel. Formula Front System 2: Six piston, 350mm x 32mm disc, painted red, black, or silver. Requires 18" or larger diameter aftermarket wheel. Formula Rear System: Four piston, 335mm x 24mm one-piece disc with integral parking brake. Mates up to either of the Front Formula Systems (4 and 6 piston above). Fits under OEM 17" wheel. We went with a one piece rear disc to help keep the cost down and accommodate the parking brake. These systems are using new caliper designs from AP, and they are going to be beautiful kits. I saw a sneak peek of the six piston, and it is a extremely nice looking piece of kit! They will be serious head turners. We're still finalizing disc options, fixed vs. floating, etc. Price will be assigned after we've established the final specification on these. Again, I will repeat that they are going to be a bit more expensive than the Competition Systems. I would estimate that retail prices will start in the mid to upper $2k range on the Formula front kits, vs. the low $2k's on the Competition kits. Also, I want to be clear that these Formula Kits are in no way a poser, aesthetic-only upgrade. The AP Racing Formula systems are just like the ones on M3's, Evo's, GT-R's, S4's, etc. tearing up tracks all over Europe. These kits will provide a huge range of benefits over the stock equipment. They just aren't quite as hardcore as the Competition Systems, which have the anodized calipers, piston springs, etc. The Formula Kits will look a little prettier, but they will still have plenty of teeth for serious use! Quote:
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 07-25-2012 at 03:29 PM. Reason: Added info |
#26 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
wait, so the formula kits are less hardcore than the competition kits, but more expensive? what are the advantages to the formula kits aside from the dust boots and larger brake discs? i guess we'll know when you post more details.
| The Following User Says Thank You to cyde01 For This Useful Post: | schtebie (07-25-2012) |
#27 |
Drives: Attitude
It's a more streetable application. The price increase is at least partially coming from those HUGE discs. Unless they've got aluminum hats those are probably heavy as shit. For comparison's sake, the STI rides on 326mm front discs.
#28 | ||
![]() We (Essex) are putting together the Competition Kits in the USA, using AP Racing competition components. We have our own engineering staff, and we have a full-time AP Racing engineer who lives in the US and works out of our office. The components we use in these kits are used in a range of racing environments, and are relatively low cost due to the volumes we import and sell. For example, we have stacks of the CP3862 discs to the ceiling in our warehouse. We import most of these parts in bulk and package everything here. The Formula Kits are fully designed, built, assembled, and packaged in England by AP Racing. In this case, we've given some input on the design, what we'd like to see, shared some data, etc. The Formula Kits are lower volume items, and some of the associated costs with producing them are higher. The discs are larger, the calipers have to be painted, they come with brake fluid and pads, more labor & materials to pack them in England, etc. Therefore, the prices to the end-user are a little higher. The Formula Kits will offer many of the same benefits as the Competition Kits. I can't get too specific because I don't have all the details yet, but generally speaking they have the attributes below:
Jeff Ritter|Mgr.- High Performance Division www.essexparts.com ![]() Last edited by JRitt; 07-25-2012 at 05:17 PM. |
| The Following User Says Thank You to JRitt For This Useful Post: | GT86_PRAGUE (06-07-2015) |
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| SS Racing Brake Line | K1 Motor Works | Brakes, Suspension, Chassis | 5 | 06-29-2012 03:36 AM |
| Essex/AP Racing Competition Brake System in Development | JRitt | Brakes, Suspension, Chassis | 1 | 06-14-2012 02:32 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
